Plasma Effect - Cosmic Ray Amplification
  • Plasma Effect - Cosmic Ray Amplification
    this is my findings on semiconductor experiments, nothing to do with Aarons Plasma Plug but it is to explain what causes the plasma effect.
    When a semiconductor silicon diode is pulsed with oscillating DC at high voltage, rapid quenching, it causes the silicon to become superconductive which amplifies the power output.
    I had observed this effect and after researching the net, I found other published papers confirming this effect.
    There are also some published papers on the anomaly of AND gates magnification effect.
    And more weird gains and losses in the Forbidden Zone of semi-conducters.
    I guess I need to be more blunt for you to see!
    Meyes, Boyce, MEG, the secret is Superconduction.
    Please make your own silicon, Toroids, Cores etc.
    Silicon refining is done with a simple HHO torch, broken glass or Heat Resistant Glass works better, make your own composite and alloys. It is easy!
    Take it to Superconductivity and harvest all the ENERGY.
      supercavi, if you're willing to replicate the ou effect of superconductive silicon, lets discuss it here.
        Originally Posted by SuperCaviTationIstic
        I'm listening
        Hi there! What would you like to discuss?
        Originally Posted by power1
        superconductivity and energy amplification properties of silicon, tabu subject but we must let others know.
        you need sinewave ac, rectify and step up to high voltage, circuit setup to achieve disruptive discharge with quenching effect, dont know what you have.
        pulse this through silicon, may be a composite core or transistor and film the ou effect.
        discuss this at my new thread.
        Right now I'm not sure how much experimentation I can do, as I've committed my time in the near future to charitable work, but I'll see what I can do.... I think you may be a little too caught up in 1 specific way of doing things, though I certainly encourage you to follow through with your ideas. Aaron made a very good point, cavitation seems to be responsible for much, if not all, of the overunity devices... Perhaps it is cavitation of the Aether, or of the Earth's magnetic field. I will follow your thread though and provide any insight I can. Where do you live by the way, I'm in central Massachusetts, and I really really need someone to work with, because I have WAY too many ideas, and hardly any motivation to choose one over the other to go with, so I start projects all the time and hardly finish anything.
        if you think so, then let it be.
        i'm private, not a people person.
        understandable.... I do appreciate the fact that you thought enough of me to ask me to try it out, so I will make an effort to. There is something special about silicon.
        yes, very special properties, we're using one of it's property now,right this moment on our computers.
          Originally posted by power1 View Post
          repost, anyone interested?
          power1
          could you please edit this to make it clearer who said what; just the first sentence (Hi there! What would you like to discuss?) were my words.
          I'd love to help.
          So let me make sure I know what you're talking about. You need a d.c. high voltage source (the way you get it is irrelevant). What do you consider high voltage? I play around with a small portable b&w television with 12 volt input, taking power from the flyback and ground strap. A disruptive discharge (can you tell us how you define disruptive discharge? I'd imagine you are talking about a unidirectional impulse that causes electrical breakdown, in this case through the silicon). I'm a bit uncertain what you mean by 'maybe a composite core or transistor'.
          If I understand you correctly, I'm thinking I should take my flyback output, charge a capacitor, discharge the capacitor through a thin piece of silicon, such as a part of an old circuit board? The molecules of silicon will arrange themselves in a manner which allows the superconductivity to manifest?
          Let me know what exactly you had in mind.
          Also, if you would be so kind, please post links to the things that you've read regarding silicon superconductivity
            Originally posted by SuperCaviTationIstic View Post
            power1
            I'd love to help.
            you can use Aarons circuit to drive a load and then post the input/output.
            i am not proficient with the modern electrical jargons, use lead acid battery with a torodial transformer to produce sine wave, rectify output and use capacitor setup like Aarons to achieve quenching, a ignition coil to setup voltage and silicon transistor for disruptive discharge/ pulsing. then drive a load.
            another method is use stepdown small silicon toroid coil transformer instead of sparkplug to drive a load.
            find the voltage needed to cause breakdown.
            i have a tesla pancake coil that I work mostly with.
              its all about structure YouTube - "Free" Energy - The Infinite Battery what this vid is missing is you can use a coil to produce a magnetic field to draw these electrons to your crystal structure so it will work anytime an be amplified.
                Use Aaron's plug to fire electromagnets
                Try air core solenoid with a steal piston....I believe this is what Teal and Gray did
                  no, remove the spark plug and place a load there, or step down transformer to run a load.
                  i have observed this silicon super-conduction after using rectified ac to run tesla pancake coil to step up volt/ frequency then running a circuit similar to Aaron using a SCR for disruptive discharge and capacitor before coil. the output was stepped down with toroidal coil to run different loads.
                  same effect can be produced with Aarons set up or Imhotep's circuit.
                  For Imhotep, 12v battery> toroid JT like >rectify>capatitor>ignition coil>diode chain or scr>step down transformer/ JT toroid>load.=OU effect.
                  i will draw a circuit later
                    i get my toroid transformers from taobao china, they are amorphous silicon metglass like composite, they are $80 shipping included rated for 600 watts, they have lots of them if one need one.
                      have made a circuit with simple modification of Imhotep/ Aromaz work to achieve silicon superconduction.
                      what you guys need to see is that the ignition coil is a tesla coil, invented by Tesla. The SCR is a disruptive discharge in discrete, methods invented by Tesla. All we are doing here is replication of his work using components that we have today.
                      This will be a Reward for Effort only, no free lunches because you will never see Free Radiant Energy if you dont learn and do it. Show me efforts, I give you help.
                      We have been shown how to attach our equipments to the Wheelwork of Nature, but you have been blinded and yet can not see.
                        Yes
                        Yes the coil ignition system in an automobile is a Tesla patent. But does anyone
                        know about the the ignition system in a Model A Ford ? A friend of mine, originally from New York state, told me his brother made a Jacob's Ladder with
                        a coil from a Model A Ford. He said that the coil ran continuous, unlike Tesla's
                        pulsed coil, and that these Model A's ran on kerosene. It sounds like the coil
                        was delivering a plasma spark. Does anyone know ? Or am I wrong ?
                        FRC
                          FRC
                          I heard basically the same stories. Not sure if this is the best place to talk about it. But I have done some tests along that line.
                          -Altrez
                          • #14
                            EnergyMover
                            EnergyMover?
                            • #15
                              Originally posted by chasson321 View Post
                              EnergyMover?
                              no, Superhighway to Energy.
                              Where does it come from?.
