The Lee-Tseung Lead-out/Bring-in Energy theory
  • #61
    One step away?
    Originally posted by Guruji View Post
    Dear Guruji,
    It will be very educational if we can put in oscilloscopes to capture the Input and Output waveforms. We can also measure the Input Power and Output Power at various points on the circuit. I expect the values will differ greatly at resonance compared with well away from resonance.
    Do you have the setup capable of doing that?
    You may be one step away from a great practical device.
    • #62
      Self resonant
      Originally posted by ltseung888 View Post
      Dear Guruji,
      Hi Itseung888 sorry I don't have the setup for what you're asking and no oscilloscope. Today I was playing with this circuit again after left it for two years or more. But as Guru2you had told me that when one hooks a speaker instead of the cell a buzzing sound is heard. This is true cause I experienced it that it self oscillates.
      • #63
        Self Resonating HHO circuit
        Dear Guruji,
        Sounds like you really have a resonating circuit. When you use the HHO cell, did you notice any gas bubbling up from the cell?
        When you hook it to a speaker, can you tune to get a louder sound?
        Lawrence
        • #64
          Understanding resonance
          @ltseung888,
          Can you explain why that a tuning fork on a resonance box produces a much louder sound than vibrating in air alone?
          • #65
            Dear Guruji,
            Lawrence
            Hi Lawrence first of all this circuit belongs to Alexander Meissner as Guru2you says. Yes when I connect the HHO cell it used to produce bubbles. I am saying it used to produce bubbles cause I had taken of coil windings to experiment but note frequency went down and bubbles stopped. So I have to go back were I was and continue from there. Guru2you had told me that he used to do this on high voltage but I'm using it on 12v bank.
            When tuning the pot ; sound frequency varies even in intensity.
            Thanks for your interest ; you should try this too.
            • #66
              Resonance box
              Originally posted by student8195 View Post
              @ltseung888,
              • #67
                Hunting for a narrow/wide sweet spot?
                In almost all musical instruments such as the guitar with a resonance chamber, the chamber is not rectangular but curved. The curved shape allows many notes to achieve resonance at some section inside the chamber.
                Some resonance guitars sound much louder. Google resonance guitars for more details.
                *** You actually brought out one important point --- some objects help to produce a louder sound for a range of frequencies. This is true in the case of musical instruments. This may also be true for electrical circuits.
                Some circuits can resonate with a wide range of frequencies. This single statement is worth much research. Do we need to hunt for a very sharp narrow sweet spot at all times? Or can we hunt for a wider sweet spot?
                The Rosie circuit has now been demonstrated successfully in South Africa. Is it an OPEN system bringing-in electron motion energy at resonance or pseudo resonance?
                God performed the Miracle as in the Bible. Water turned to wine. We can now all enjoy this wine. Knowledge will not diminish with sharing. Divine Revelation is to benefit all. Amen.
                • #68
                  Miracle from the Almighty?
                  I was calculating how much it would take to set up two oscilloscopes, a signal generator, a DC power supply, some resistors, capacitors, inductors, ferrite rings, rods, tuning forks and miscellaneous items to do the experiments in USA.
                  The minimum estimate using equipment and parts from China is around US$1,000. I was praying on how to get the money. The prayer was answered today. Is this another Miracle or Guidance from the Almighty? Amen
                  • #69
                    Reply to Ominbus at OU
                    From reply 19 of
                    Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
                    No, not clear at all what that is. Never mind universities. It isn't clear how resonance causes OU. Would be interesting how you derive that based on Newton's mechanics. I know Newton's mechanics is incomplete and when properly understood may yield unexpected results but in this case it isn't at all clear that it does what you claims it does.
                    Hopefully, you can now see the beauty of fighting Newtonian Mechanics with Newtonian Mechanics. I regard this as Divine Revelation. The phenomenon and the underlying Physics are available over 300 years. Thousands if not millions of Physics students have done or seen the two tuning fork experiment and heard the louder and longer sound.
                    Why would it wait for this old Lawrence Tseung to point it out in a Public Forum? The discovery is not from the brains of Lawrence Tseung. Lawrence Tseung is just an instrument in posting this Divine Revelation.
                    God provides the Divine Revelations. Men need to read and study to understand them. Amen.
                    • #70
                      Feedback from China
                      The first feedback:
                      Use of two tuning forks is sufficient to show that the resulting sound is louder and last longer. That experiment is a standard in all Physics courses. There is no need to use 3...n tuning forks. That just adds to the uncertainty.
                      My reply:
                      Thank you. There were some comments that the louder and longer sound was from a more efficient use of the striking energy on the first tuning fork. I wanted to show that the sound keeps on increasing in intensity and duration with more tuning forks. Such a phenomenon cannot be attributed to increase in efficiency. But you are right. Keep it simple. Stick to a well known experiment.
                      • #71
                        Picture worth a thousand words?
                        Explaining the two ball collision with the Piston pictorially
                        • #72
                          Outcome of the Japanese Nuclear Reactor Disaster
                          The Japanese Nuclear Reactor Disaster
                          The World and the General Public will now withdraw their support for more nuclear power stations. Almost all proposals for nuclear power plants will be shelved. What does that mean?
                          It is inevitable that the alternative energy option will be re-examined.
                          The three Divine Revelations will undoubtedly shine.
                          1. Kinetic Energy of air molecules can be brought-in at tuning fork resonance.
                          2. Gravitational Energy can be brought-in via the pulse-pushed pendulum
                          3. Electron Motion Energy can be brought-in via LCR resonance circuits.
                          More will turn to God when the Engineering of Men failed. The Divine Revelations are here for all to witness. Amen.
                          • #73
                            Hi ltseung888, thanks for sharing your thoughts.
                            I am curious about the pulse pushed pendulum, have you built one and tested it to see if it can lead out gravitational energy. I know Bedini has a couple pulsed pendulums ive seen, do you know if he's getting an excess output or anyone else that built one.
                            I ask because with all these gravity devices being shown and the huge one shown in the donation thread that makes full rotations, i really would like to build one of these simple pendulum types.
                            I think we could place air-core coils to convert the gravitational energy and if the kinetic energy exceeds what our drive coil inputs, it should be able to self run, i would think. Any reply appreciated, thanks.
                            peace love light
                            Tyson
                            • #74
                              Comment from Chinese Scientists
                              Can you show the pictorial representation of the collision in Chinese?
                              See attached. The English and Chinese slides are shown for comparison.
                              Divine Revelation 1 cannot be wrong. Newtonian Mechanics cannot be wrong in this case. Kinetic Energy of air molecules can be brought-in.
                              • #75
                                Pulse-push pendulum question
                                peace love light
                                Tyson
                                Dear SkyWatcher,
                                I believe you might have read and understood the posts related to the theory behind the pulse-pushed pendulum (reply 3-10) at:
                                Lead-out/Bring-in Energy - The locked teaching thread
