Turtur Zero Point Energy Rotor
  • #16
    New paper from Turtur
    Turtur, C. (2011). Construction guidelines for a ZPE-Converter on the basis of realistic DFEM-Computations. PHILICA.COM Article number 233.
    pt
    • #17
      Interesting!
      Here a picture from the same source:
      • #18
        Sorry, duplicate info,
        so bump then
        /Hob
        Hob Nilre
        • #19
          Turtur's "Audio-book: The Zero-point Energy of the quantum-vacuum"
          pt
          • #20
            This is VERY unlikely to run by itself without a kicker coil. The simulator is too optimistic on the ZPE gains. He is expecting the full amount of VARS to be converted to WATTS in practice only about 10% can be drawn out of the system to maintain the correct very slight lagging phase relationship from scalar. So a small 3/4" diametric neo may only be good for about 100 watts at 50,000 rpm in perfect conditions and NOT 1kw. More likely 10-35 watts is more realistic for general replications at 20,000 rpm
            A kicker coil like a bedini pulse coil is required to get the magnet up to and maintain the desired speed. The series cap forces the voltage and current out of phase (again!) to produce VARS its a reactive design like the muller and others. its the only way BEMF can be defeated. Magnet flux charges virtual capacitance around the coil to induce displacement current while the coil becomes a negative inductor and pulls in stochastic electron energy from the ambient. The load matching is critical to desired rpm to run within very tight bandwidth.
            • #21
              Simulation problems...
              Hi All-
              I downloaded and ran 2 of the simulation programs, and while they showed energy gain with the default settings, the gain went away when the step duration was reduced by a factor of 10 (to .01mS), and the number of steps increased by a factor of 10.
              Professor Turtur seems very knowledgeable, and very capable with math and the requisite calculations, but we REALLY need to see and measure a working model to know for sure if this is the real deal.
              -joeelectro
              • #22
                Lifter as ZPE converter..
                Can be possible that lifter is also an ZPE converter? I think that Lifter is based on same theory of Prof. Turtur. I have just modified Turtur design applying lines of forces. If you want obtain mechanical movement you need an force, in my case some lines of force from emitted source amplified the movement.
                Turtur theory ask that an initial high voltage source get energy from ZPE oscillations presents on space around to us. Turtur use for test an disc but you can use an aluminium tube as energy source and rotor can be trasformed in vertical rotor with some blades.
                In that way you can obtain an ZPE field at 360° and the ZPE lines of forces impacts on rotor causing the rotation. Attached images ... Waiting your considerations..
