Hi
I was listening to a power supply buzzing away and I wondered if i could use this unwanted characteristic of some voltage regulators to oscillate ,to pulse a coil and this is what i came up with.
I used a TS 2950 3.3v voltage regulator, a coil and an led and it worked.The input voltage is quite important to get the TS2950 oscillating,it needs to be between 1.35 and 1.5v when using the circuit in its simplest form but the input voltage range can be widened by adding a cap and resistor.
By using a 1:1 bifiar coil,you can also charge a battery or cap but what is interesting about this circuit is it will run on microamps and the output voltage when using the bifilar coil is a lot higher than the input voltage or output of the voltage regulator.I have not done much experimenting with this yet but i would be interested to hear what you think.
Here is a vid and circuit diagrams.Jonny
YouTube - Voltage regulator oscillator
from an input of 1.47v at 84uA where 75uA are used up to run the internal circuit
So i think there is a lot more going on here.
. The low voltage one was just a zener diode thing and the other part was a 5volt regulator that would only work at higher voltages.
