A simple, inexpensive free energy mechancial motor?
  • A simple, inexpensive free energy mechancial motor?
    I've been really impressed by the level of knowledge on display here and other similar sites. But as my username suggests I'm kinda clueless in this field. In a previous life I worked maintaince in an industrial setting and also repairing and painting cars.
    In Dec of '97 I suffered the 1st of four heart attacks, the 2nd in '03 put me on disability. The last one was in '06.
    The reason I bring this up is threefold. First the heart attacks caused some brain impariment and with time I have misplaced a lot of former knowledge on these subjects. Second I had to sell $10,000 of my tools for pennies on the dollar while waiting on disability. And third after 3 heart attacks in 3 years ('0-'06), in '06 I begin to follow an inner guidance. Since then I haven't had another HA. Bascially I listen to professional advice mixed with my intution and formulated a hybrid plan.
    I have a friend who is an electricial engineer who lent me some stuff to play with and I bought a science kit to learn circuits. And I have been fashioning a workbench in the LR (ours is a confined space)to lay the circuits on.
    After reading through hundreds of pages on threads her and OU and other similar sites and following several youtube series along with my friend ( the engineer) some knowledge(from the past) is returning.
    I have had two ideas come to me from out of the blue actually from dreams and from my experience with intuitive prompts on my health I don't dismiss them lightly.I hoped someone here can either (a)critique these ideas and (b) build them to see what the results are.
    I intend to, but I have to gather resources and learn simple circuits first and time I believe is short. I don't care who gets credit as long as something is accomplished. Especially so if it is quick, simple, cheap and it works. I really feel that more people needs to become free of the grid, the energy grid, economy grid and medical grid as I don't fully trust any governments.
    The first is a vision of looking down at a board (wooden?) with nails/pins? drove in a square pattern on this board. Wire is wound around these "pins" and fashions what I assume is a square coil. Though it could be anything.But I'm certain the wire is wrapped around each pin (for grip?) and that there are several windings. I'm not sure about the spacing between each row as I only "saw" it from above. I'm not even sure if anyone has ever wound a square coil or what the properties of such a design might be or how to use it. I'd appreciate any ideas you have.
    The second though is more complete and seems so simple I can't believe it will work but it will only a minimum of parts and time to test.
    Can someone tell me why you couldn't take a piece of plastic pipe and screw on caps and a rod of either plastic, metallic; hollow or solid and place it inside. On either end of this rod fasten a magnet and on the end caps fasten a magnet with the same poles facing. Would they not then repel and travel to the other end where again it would be met with repulsion and move back? Then couldn't you wrap a coil around the pipe and generate electricity with this back and forth motion? I do realize the magnetic force would have to be unequal or the rod would just tremble in the middle. I don't know but that could be benefical? Anyway it seems to me that you could put magnets of different strenghts on each end or a spring on one end or both to counteract the tendency to equalize. Or introduce some type of intermittent shielding effect.
    To be honest this "pipe" motor is part my imagination and part vision. The "pipe" was what I dreamed and I supplied the magnets. Could be the "square coil" and the pipe somehow fit.
    So can anybody supply any thoughts to help me make sense of it these two items or the pipe and magnet motor?
    Thanks again
    -RG
    Is this 1st concept-idea anything like the "Hans-Coler" design as found on the Rex Research site? Hans Coler's "Magnetstromapparat" & "Stromzeuger" (British Intelligence Objectives SubCommittee Report #1043
      It very well could be
      I don't know. From reading that page it seems to me the magnets (coils) were arranged in a manner with enough tension to "straighten" out magnetic lines. That might be similar to the concept in another thread here: "The Electric Field."
      The impression I have (of the "square coil") is similar to the way I assume an electric dog fence works using a transmitter and reciever. My feeling is that if a transmitting type of material was used in the "square coil" and a reciever material (semi-conductor?) was inside the enclosure and collected the energy.
      As i said I'm trying to get my "mind wet". I appreciate your response and maybe something "said" will trigger some memories.
      -RG
        2nd idea
        The second idea is going to wind up with the magnet coming to rest between the two ends of the pipe reaching a static equilibrium. A lot of people have tried to do something similar only with the magnet turning on a central pin with different methods of repulsion or attraction to attempt to get a continuous spinning motion, rather than back and forth.
        There may be some clever way to perturb the magnet so that it doesn't reach a resting state (where no additional energy would be released) but I'm not sure I've got any suggestions on how to do it.
        Good luck in your search, and welcome to the forum!
          The Pipe concept
          seemed to hinge on the idea that the magnets would eventually reach balance between the two points if another variable was not introduced. After writing the post and while I was out and idea came to me.
          If the rod was riding on a "track" and if inside that "track" a lever/mechanism was placed so as to trip a magnetic shield (partial or full) at odd intervals then could you not keep motion "going?" It would probably take two levers (one at either end) and one probably needs to operate on a separate ratio.
          Or maybe a jig could be rigged up where the pipe is suspended between two arms at its ends and magnets as before. If the "arms" were shorter than the pipe length and the stationary magnets were placed at a distance greater than the pipe length then it seems to me you have the same effect as a swing. As before a "lever" could be used to introduce an unbalance in the system.
          I read somewhere that a magnet moving across a pipe would produce some electric flow. If that is true it seems that something could be with this design.
          Thank You for your thoughts. Appreciate it.
          -RG
