Now that I am starting to realize that there are two distinct fields produced from wires, one being the Magnetic field and one of the Electric field. The Magnetic field has already been just about fully explored. We know it capabilities pretty good but we have very little to describe the Electric Field.
The Electric Field that I am talking about is the type of field like the exciter variety. This field has a mass effect on the particles finer then what is affecting the Magnetic field. This field particle density is vastly huge but of very little mass. So the heavy Magnetic field doesn't effect this kind of particle much. At those dimensions mass = effective pull and subsequent movement from that pull. Basically if it has less mass then it doesn't move much when a heavy pull is on it. But it can move laterally very well. If that process only included reacting to your neighbors.
The Electric field is formed from the source extending outward or to be exact Longitudinally. That way the particles that are attracted to their neighbors self organize to the greatest attraction. This causes a growing like effect of the line it creates. Propagation of the Electric field is a linear growth from the source to the effective length of that strength to organize or keep organized that string. You can imagine millions of threads emitting from the conductor in a 90 degree fashion from the source plane to the end of that string. These string are extremely mobile in the lateral directions and when they mass they act like jelly.
There are two modes to modulate this field. One is to put additional coils around the source to modify it's field through a surface like tension and vibrate the field. The other mode is by turning on and off the source in effect modulating the length of each strand. Since normal space wants to disorganize or change back to the ambient conditions it's relaxation time is about nil. Also it's organization times are about the same nil. That means they can move way faster then traditional Magnetic field technology and I suspect with a greater force or better efficiency.
You got to understand what kind of a field we are talking about here. This is the field responsible for light. That means it MUST be some slight percentage faster then light. It will respond to magnetic energy but it has a different phase to it. A 90 degree phase. No matter what the phase relationship they can be separated. If you short out the magnetic component you are left with the electric field that is still attached to the source. This filed will condense on matter and ultimately is inside all of matter. It just has a lesser density then matter has. But what little density this energy pockets have in between matter it is capable on immense conduction.
This leads me to the phenomena of space and the vacuum. Where little matter exists the network or field is massive. It conducts energy better then anything around because it has little matter to restrict the flow. Matter is a separation of this field which creates surfaces and tensions and are an operable part of that equation.
So how do we utilize this information? Well I was thinking that if these strings move laterally pretty well and magnetic fields can influence their path If we variated the strength of the strings then they would become pliable or even stiff if we wanted to. Just like a cantilever we could use this to our advantage. We could even use great pulses to generate huge amounts of power just like Tesla had envisioned.
What I think is that these strings have great power because they are all around the field. It takes a lot to stop them when they move in unison like jelly moves. With the AV plug that was re-invented by Avramenko we saw the ability to use Tesla's waves only using one broadcast wire.
Here is a good read about the afore mentioned:
Frolov on resonant tuning and the Avramenko plug
If you start reading up on the Exciter pages you will start to see that there is very little field involved. Although I have see 20 foot ranges from a simple exciter circuit the range is limited because the strength of the source voltage is rather low when compared to the 20-50k volt range.
The frequency of the pulsations also is a limiting factor when this type of energy is employed. Thats why Tesla used an analog diode/oscillator called the spark gap. Imagine the millions of cycles that would come from a spark gap. This is where Tesla got the idea to use a magnetic quenched spark gap. He figured out there were two fields at play and learned that when you use a magnetic implement you could control the other field just like his mentor did in the explanation of radiant matter with light propagation. He was able to affect the light because it rode within this other field.
These are not facts in Theory they are observations given by our forefathers. I am merely commenting and gathering up all the observations and linking them together. I could have parts wrong as I am human but these seem to be the meaning of these observations as far as I can tell. Lets discuss this. Maybe we can design proof of this in our experiments.
Then it's like instant freedom in the mind, but the body remains locked into the same old thing. It didn't take too much imagination for me to realise that the thinking part of us, the actual thoughts are pure energy. But it is saturated in the manifestation of mass at the density our own conciousness determins. It's true if we can raise our own relevent frequency maybe into resonance, we can increase the amount of energy present in our mass. Like Qigong
