The 3 plate capacitor can make your drawing above a bit more simplified. It is basically a capacitor with 2 different capacitances used in a circuit for 2 purposes. One to control the pumping of energy, the other to store the pumped energy without affecting the input.
The 3 plate cap isn't anything new - I learned of the concept from Dr. Stiffler in his early works then followed along with ibpointless and lasersabre's use of the same device.
The diagram below shows one way of using it as a full wave rectifier. The second shows it used as an unconventional tank type circuit. It's basically as you drew it in the above diagram as a full wave rectifier charging a main cap only more integrated into the circuit.
The small plate - outer plate has a small capacitance based on the area and can be adjusted by changing the diameter. The inner plates form the main storage.
Now, you can take the small capacitance and run it with a coil using a high frequency. The storage cap can now be used with another tank circuit for yet a much lower frequency... something closer to our normal 50/60 hz that we use normally as shown in the 3rd diagram.
Should I continue or is this just boring everyone....
, I'll also use that to seal the PVC tube inside
