Donald L. Smith
  • #46
    Halide Transformer Specs
    Hi kcarring, Do you have any specs for your transformer Input voltage
    frequency and output voltage frequency? I can only find specs that state
    input specs no output specs. Maybe they have something to hide.
    7imix I have most of the stuff from there, it'll take me a little while to gather
    and upload it, I had intention to do it, so I will. As soon as I can. some of it
    is old info so i'll upload all the new stuff or what is not availiable elsewhere.
    I'll post a link here when I get it done.
    • #47
      Did you liked the exel sheet?
      I think that i wanted to mean that the free electrons would fly from turn to turn aiding the flux cause of the great E-field between the turns.
      Probably, would be perfect if the coil sit inside a glass vacuum chamber and the wires had some high conductive and low work function coating material. But this would be possible only for N.A.S.A tests
      Hope you enjoy
      • #48
        Hope you enjoy
        I haven't had a chance to view the exel sheet yet, i will have to use a
        different computer, when I get permission. I can't see it on mine but there
        are others here I can use soon.
        Thanks very much.
        • #49
          There's a very interesting word document with info on a.o. Don Smith here: http://www.ut27972.narod.ru/Book_2/8...E_ENERGY_1.doc
          • #50
            Oh Ya!!!!!
            This is what I've been trying to tell everyone! you need a pumped phase conjugate mirror! opposing magnetic fields! Duh!
            DON SMITH IS NOT A FRAUD
            HE JUST COULDN'T TELL YOU ALL THE DETAILS, BUT HIS HINTS WITH TESLA GAVE IT AWAY IF YOU REALLY LOOK!
            now go look at some pictures of a magnetron and see that it does the same thing (sort of)
            you feed current into the center neutral node of a phase conjugate (mirror image) resonator....
            It's just like those stupid fusion reactors they keep trying to build, with MAGNETIC CONFINEMENT, those idiots try to put it into continuous mode, rather than pulse it.
            Thanks for the wonderful find Lamare!
            • #51
              Yes i think That very few of those inventors with patents are fraud. Don certainly was not. I see in his eyes that he know what he is talking about.
              If you don't look at it with a point of view from the high to low (superiority) you have the chance to go further and understand what they say, but if you think its impossible you have no chance.
              Tesla was very wise guy!
              Thanks lamar will check that.
              • #52
                Arrgg, I can't view that file either. It says an install on demand componant is needed. Will that make it work ?
                sebosfato I still haven't been able to look at the XLS file either what do I need to see that ? I thought the other computer would do it but it won't.
                Do I need microsoft office or something. I don't use that stuff. I'm not qualified for that. Haha
                I hope to get some copper plate friday.
                I have this circuit that can oscillate a coil with a clean switching mosfet at 1.5 Mhz. Easy 200 Khz, if I can make it oscillate like that with a Hv output coil, it could be usefull to take place of the NST.
                ShotsMhz 002.JPG - Windows Live
                Here's the waveform at 1.5 Mhz. Input is about .5 amp though, maybe I can get it down. It's less than 100 Ma input at 200 Khz.
                • #53
                  Hi all, I found this old thread, started by sebosfato, By my last post here in
                  January last year I was frustrated by my lack of knowledge so I set about
                  trying to understand resonance a bit better. Now I'm ready to have another
                  go at it.
                  I am still to decide exactly how I will make the coils. I'm very much at the
                  beginning of my attempt to produce the desired effect.
                  I think sebosfato gave some good practical tips and some of his opinions may
                  well have some merrit. It's obvious that one year ago when I last posted in
                  this thread I was one years more of a beginner than I am now.
                  Anyway to cut a long story short I'm going to post in this thread so as not to
                  disrupt the other efforts.
                  Ok so I was watching this video again.
                  Don Smith Free Energy - Video
                  From 1:40 mins to 8:20 mins, at 2:08 mins he mentions they are utilizing the
                  casimir effect. At about 4:50 mins he says they are using a special capacitive
                  inversion circuit and utilizing the casimir effect. He seems nervous or hurried
                  and makes a small speaking mistake when he says they are producing AC 120,
                  DC 12, AC 140 and AC 480, he should have said AC 240 instead of AC 140.
                  Honest slip of the tongue.
                  He also talks of a resonant backfeed. The capacitive inversion circuit sounds
                  interesting.
                  He says near the end the system can be closed, which indicates to me that
                  the system he is showing is not closed. This is a bit confusing because I think
                  he says they are using batteries. If it is not closed then that means there is
                  an external input. Or maybe he is saying the batteries can be removed.
                  I'm fairly confident I can get the cap charging action happening, but it's the
                  transformation/conversion to a useful AC output that I see as the problem to
                  overcome. Maybe the capacitive inverter is the trick for dealing with the HV output.
                  EDIT: Oh one other think I thought notable was that I think he said they were
                  using a "variac" to control the output transformer. I wonder how that control
                  is implemented. A Mag-amp or something could be a possibility in my opinion.
                  The first document says they were used to regulate the frequency of the
                  output of an AC generator in German rockets.
                  Magnetic amplifier - Wikipedia, the free encyclopedia
                  • #54
                    Farmhand
                    I knew you were at this long before the other thread got revitalized. If they knew you had been investigating this for so long they might not have been so hard on you at the other thread. I think they took you the wrong way over
                    there. Hopefully they will see the truth of your approach.
                    George
                    • #55
                      Don S. is constantly pointing ot the source of the energy - the ambient.
                      Radiations, particles? Does anyone have an idea what is he suppose to collect?
                      If we know the source of the energy it should be easyer to construct a device to collect it.
                      • #56
                        Very good point, take fishing for example, when I fish for Barramundi I don't
                        just go and throw any old bait on a hook anywhere in the water. I go and
                        catch the small live fish or live prawns that the Barramundi feed on, then I
                        place the bait on the hook so the bait is not killed that way when I cast the
                        bait and hook into where the fish feed the bait struggles, the struggling bait
                        sends out a signal in all directions (vibrations) (the smell of the bait only goes
                        with the current) the barramundi follows the signal of the struggling bait to
                        it's source and eats it, then the fun begins. My point is, the bait is
                        irresistible, if everything is prepared the event happens. Live bait sends out
                        an active real time signal in all directions, dead bait just smells.
                        The goal in this case is the enjoyment of catching the fish, if it was just
                        getting the fish then the easiest way is to use a 4 inch gill net. However
                        that is illegal except for licensed fisherman.
                        Your question is very valid. I've heard all sorts of different theories from
                        electron spin, free electrons to creating a "sink" or funnel, even just straight
                        out resonance.
                        I'm going to catch the bait (make the device) set the bait ( set the device to
                        work) then see what happens, If I don't get a strike I'll make the bait struggle
                        differently or throw it in a different place.
                        How that for speaking in riddles. Clear as mud.
                        I think the source of the energy is the "Ambient background" or the "Aether".
                        So obviously we need some live bait for Aether. And we need to keep it
                        struggling and we need to use less bait than we catch with that bait.
                        Sounds easy.
                        In reality the source of the energy is just energy itself.
                        If I were to look at a device that was theoretically producing 100 kilowatts "useful energy"
                        with only 5 watts input, I could safely say that the device was not actually
                        adding anything to the Universe as a whole. And in the same way if I were to
                        look at a device which was using 100 kilowatts and only outputting 5 watts in
                        "usable" energy I could also say that that device was not removing anything
                        from the Universe.
                        These obvious truths tell me that it is entirely possible to harness and use
                        energy in any gain ratio inverse to any loss ratio possible. To me this
                        possibility is what I look for.
                        Losses go to zero and stop but gains don't have that limit. ie. If I have 100
                        units of energy and I am experiencing a 50 unit loss per minute then I get two
                        minutes of energy before it's all gone. However if I am getting a 50 unit gain
                        where does it end ? I would either need to burn off energy (unharness it) or it
                        would unharness itself.
                        To me a 50 unit gain per minute is not Over unity it's just the opposite of a 50
                        unit loss per minute.
                        Admittedly it's all just words. Proof is in the pudding. The recipe and the method are just details.
                        Anyway that's how I see it.
                        This isthe nature of nature.
                        • #57
                          Looking at Don's drawing, it seems that the positive is made the neutral and the
                          negative is the active. I'm sure that's already been noted by most but I thought
                          i would mention it.
                          If we take out the voltage divider resistors and Item #8, which Earth
                          connection would we need to remove for the circuit to make sense ?
                          I would say the connection near item #11 to the far right on the negative is the odd one out.
                          Any other thought's on that ? EDIT: Maybe that Earth connection would make
                          sense if it was 15 meters away from the others and the operating frequency
                          was 4.7 Mhz or something.
                          Uploaded with ImageShack.us
                          It makes more sense to me if I draw it like this. Maybe it's my lack of
                          electronics knowledge but the orientation of the inverter transistors seems
                          strange otherwise.
                          This is a sketch of what I touched on in the other thread about the rotary
                          capacitor idea. Dragon mentioned a three plate capacitor so I'm thinking he
                          had a similar revelation before I did. I was given the idea by a poster in the
                          other thread, this is what my mind came up with as a solution. It's possible
                          I've seen it somewhere before or a drawing or something.
                          The principal is that, as the two rotating plates connected to either output
                          transformer primary winding swing past the fixed plate, a capacitor is formed
                          and energy transferred, as the plate swings past the capacity increases to a
                          maximum then decreases to nil when the other one starts its pass.
                          The primaries are wired to produce AC like an inverter.
                          However a much better way would be to do it without any rotating parts. So I
                          don't think i will be trying to build a rotary setup. A rotary setup would require
                          a complicated build. And could be dangerous. There must be a better way
                          with out using HV transistors for the inverter.
                          • #58
                            Did someone ring my bell
                            I cant help it Im in a good mood today
                            Lets see where to start, skip through this thread
                            • #59
                              out resonance.
                              Sounds easy.
                              from the Universe.
                              The shorted coil as in the pmh is the bait it will get the aether charged and circling the bait.
                              • #60
                                I bought one of these cheap neon power supplies on ebay, so I pulled it apart
                                because I'll be using it from a true sine wave inverter it has a European plug
                                and I wanted to see the whats happening with the AC input ground and
                                neutral wire's. This unit will never be plugged into the grid.
                                I think it cost $15 or something.
                                This is what's inside, it looks like an AC flyback.
                                It's using IRF740 mosfets by the looks of it, (with big heat sinks)
                                P.S. It also has these parts-
                                a CD4536BE, (Timer)
                                CD4536B pdf, CD4536B description, CD4536B datasheets, CD4536B view ::: ALLDATASHEET :::
                                and a IR2153 (Self Oscillating Half Bridge Driver) This looks like a neat little part.
                                IR2153 pdf, IR2153 description, IR2153 datasheets, IR2153 view ::: ALLDATASHEET :::
