Well... Hmmm...
We can coat the aluminum to stay off corrosion and yes I think Electrolytic caps have a lifespan. They decay like everything else does. They age in effect. When you use a capacitor the way it is designed to work then yes they stay strong. But let it sit for years and they can loose some of thier punch. Age does have an effect on the aluminum but I think electrically it doesn't do a thing to aluminum. This is no mere aluminum battery. We can also immerse the coil in oil to protect the aluminum from oxidation if need be if only used for amplifying voltages. There will be no connection to the circuit to the aluminum itself. It's purpose is the same as Iron would be for magnetic fields, only to focus the electric field. What this effect does I have not tested. Hell it could do nothing but just seeing how a magnet acts when it is slid down an aluminum plate makes me think, there is something going on there. Both fields must be present in a magnet and they interact differently with but show the same effect for each type of metal.
Since a bifilar cancels the magnetic effect when used right it would seem that the other field (electric) is not hindered. This is the exciter effect. Since traditionally copper is used to create the magnetic field it also creates an electric field and if we used the coil in such a way it would only emit an electric field. Once this field is established it takes very little to modulate it but it has a greater force when received close to the source.
Since evidence is collecting that the can of the electrolytic is a greater source of this energy, example Lidmotor's videos, I am starting to think that aluminum can channel this energy with a focusing effect better then most metals. Well that and it is where the conversion is being done besides the Bifilar.
Thats brings up the thought of using aluminum wiring for the coils but I have not even established that aluminum is a key player here. I see evidence that it is but more testing will conclude either way.
Just my thoughts.
