Great info thanks all. Does anybody use clay catalyst in liquid phase?
Petrol or Diesel?
Alec thats an amazing outfit, Again more questions. What catalyst are you using? The clear liquid below the golden fuel is really strange. If you can separate them weigh a quantity to determine the specific gravity ie the weight in grams of a litre. We might be able to figure out what it is from that.
Is your car a diesel or petrol engine?
I am using pottery and Lime for my catalyst. The catalyst change the color from Black to clear.
My car is a petrol engine. It runs fine (no smoke) on the fuel but it seems to ping a bit.
What kind of pottery. Could you use bricks like thisOriginally posted by Alec View PostI nor shure to understand your set up. Please, draw it. Thanks !
Uploaded with ImageShack.us
This hollow brick has a large contact area as a catalyst and is not expensive
Please, try could it work?!Last edited by otpadnoulje; 09-16-2011, 09:13 AM.
Catalyst
Look at my picture. I am using a gas fired reactor with ash isolation. 3 openings on top. The centre one is the Reflux and the idea is that the heavy chains (the wax) fall back into the reactor. The blue drum on top with the chimney from the reactor and green heat shield is the catalyst with its own gas burner. I put any type of broken pottery, bricks, ceramic tiles ect. with lime powder inside and it work well.
I have seperate and weigh my fuel. The bottom part is 950 gram per Liter and the top part 710 gram per Liter. That make it Diesel and Petrol !!!
The 2 green pipes are my condensers with beer bottels inside and a water cooler between them. From there the remaining gas go back to the furnice. The white pipe with the fan give extra air to make the flame blue.
Thanks, Alec! Nice job! A lot better then before!
I have two more questions.
What is ratio petrol vs diesel?
What is ratio weight, plastic feed vs catalyst?Last edited by otpadnoulje; 09-16-2011, 02:18 PM.
HiOriginally posted by otpadnoulje View PostThanks, Alec! Nice job! A lot better then before!
The Petrol ratio vary from 20 to 80%, even on the same run. I don't know why.
The catalyst ratio, I am not sure. I just fill it up.
catalyst
Hi Alec!Originally posted by Alec View PostLook at my picture. I am using a gas fired reactor with ash isolation. 3 openings on top. The centre one is the Reflux and the idea is that the heavy chains (the wax) fall back into the reactor. The blue drum on top with the chimney from the reactor and green heat shield is the catalyst with its own gas burner. I put any type of broken pottery, bricks, ceramic tiles ect. with lime powder inside and it work well.
I have some question:
How many a liters have you got a fuel for each run the reaction?
The total volume of how much plastic for a reaction run?
I have a suggestion I made in the following diagram
Online Photo and Video Hosting[/url]
Obtained some results in the separation of my fuel is clear
I had actual volumetric efficiency reached 80% of the total raw material input
1Kg plastic conver 800ml liquid fuel
I use clay catalyst is sure how the natural gas passing total reactor through total volume of clay 10s
Thanks all
catalyst
Hi Alec
nature of the catalyst is cracking the chain carbon. If you do so is like you're doing thermal cracking, yield low liquid fuel. you do so efficiency economic is not high, you will notice temperature in the catalyst was 200 C
wish you success
thanksLast edited by congnghiah4; 09-18-2011, 05:18 PM.
I'm quickly finding that clean regrind plastic is fairly expensive in my area and am starting to lean toward raw plastic waste. Is there a contamination issue with labels and a little residual milk or orange juice from milk and orange juice jugs particularly in a continuous process system? I would think this contamination could be vented off at the lower temperatures of the beginning heating cycle of a batch system but I don't know how this could be done on a continuous system.
The contamination is not as much of a problem as it might seem. In a batch system it is actually an advantage. The small amount of water will quickly boil and displace any air in the system. Paper,dirt, oil etc will either char in which case it stays in the reactor, or gasify and be burned off with the other uncondensed gas. Traces of water may end up in the final fuel. If this does not exceed 500ppm it is not a problem.
My chemist friend supplied with some bromine solution yesterday and I tried it out. I put about 2ml of bromine solution into a test tube and added a drop of my best fuel. The brown bromine and golden fuel instantly turned perfectly clear. This indicated that my fuel contains unsaturated hydrocarbons or alkenes. Unfortunately the test does not tell us how much of the fuel is unsaturated.
The reason this test is important is that unsaturated hydrocarbons are unstable and will tend to oxidize and polymerize more quickly than saturated hydrocarbons (alkanes)
