  • Comment
    • Hi dosyl,
      sorry for not replying to your PM. Sure, it would be advisable to know the basic chemistry, but I am certain, that if you read all the posts in this topic, you will learn all the chemistry you need for this project. It is not that hard
      Hope this helps.
      Jetijs
      • Tank's Jetijs
        • how to turn plastic waste into feul chealy
          I'M very sory everybody for my english
          dir jetijs
          Your results are impressive with one kg PE you get 0.72 Kg liquid fuel
          Such efficiency is higher than 1 liter crude oil produced in the distillation of the oil company gets only 600 mml liquid fuel
          you use of the catalyst is supplied from china have You got plans to recycle catalyst? Or coke of the zeolites
          thank you
          • hello Jetijs;
            I'm attending to do this project as my graduation project, but when I suggested you idea, my professor said that there should be a nitrogen gas enters the reactor and leave it with gases; so that the gasses formed do not explode at the high temperature at their auto ignition temperature, I did not see you saying anything about it, I really really like your structure and the way you explained everything, but what do you think I should say to my professor ? You did not enter any nitrogen gas, did you ??
            • Hi Rahal,
              please read through all this topic, it has already been discussed multiple times and I hate to repeat myself, well, actually I am just lazy. The short version is - no need for any gasses, why? Read the topic and find out. It is really very much advisable to read all the posts through as most of your questions are already answered.
              congnghiah4,
              I got aboyt 750mL of fuel from 1 liter of shredded PE. But one liter of shredded plastic weights also about 750 grams, so the efficiency is even better. Don't confuse grams with mililiters. The 750 mL of fuel actually weights around 500mL or something like that. You lose mass in the process, but gain volume due to reduced material density.
              Jetijs
              • Thanks Jetijs, I willm thanks for your time
                  hi jetijs
                  The density of PE was 0.92 kg / liter, but the proportion of you such a highconversion efficiency.
                  According to my understanding of the PE segment cracking gasoline. but thissegment is low density.
                  Such conversion efficiency 1 kg> = 1 liter liquid feul
                  Above are the results I obtained from my model
                  Products 25% gasoline 95 octane
                  Products DO 45% compared to the raw input
                  index cetan 55.59
                  gas 15%, carbon residue 5%
                  • fibuslitero at 2011-08-30
                    By fibuslitero at 2011-08-30
                    • Here at last is a picture of my reactor. The bottom part is made from a small propane tank . the rest is made up from threaded pipe fittings. It has 2 pressure relief valves, one directly connected to the reactor and the other at the top of the reflux/catalyst tower. I have fitted a small 400w heater to the bottom of the tower and will soon fit a cooling coil to the top. The reactor is covered by and insulated jacket and heated by a propane burner.
                      • pic with a motor+pump
                        Originally posted by congnghiah4 View Post
                        hi jetijs
                        index cetan 55.59
                        Hello :
                        Your reactor unit is very interesting . No details are mentioned with the pics.
                        One picture#855, U posted seems to be of a pump+motor. Kindly explain about it ? Is it a vacuum pump for doing the reaction under vacuum or nitrogen gas pumping unit for putting a nitrogen blanket during the reaction ?
                        • Polymers plastics PVC nylon PA66 HDPE LDPE MDPE ABS PET uPVC Granules Pellets
                          Thank you.
                          • Temp control
                            Question: Do I need to control the temperature on the condensers (270C, 95C and 20C)?
                            • dir Imakebiodiesel
                              you need to convert WMO into liquid fuel
                              you can use 100% WMO. I can give you a production process
                              efficiency 70% liquid fuel by volume compared to the volume of input
                              fuel in this segment with the proportion 0.82Kg/liter
                              this is my video clip
                              my email [email protected]
                              • hi
                                dir Imakebiodiesel
                                http://img189.imageshack.us/img189/4069/5g8.mp4
                                Hi, thanks for your contribution, you could put the video into another format to be viewed
