  • OK, kedigen, with further clarification, yes, electrical heating with immersion heaters, like electric water heater elements, is a good idea, except you will need electrical feed throws capable of withstanding 425c. They exist, but they are expensive.
    Otherwise you will end up with the kind of fire your photos showed. Thanks for the photos. It should serve as a reminder to everyone here that is precisely what can happen if you are not careful enough.
    I have been running various blends of waste oils and unleaded gasoline in a 1983 Chevy G-20 van with a 6.2L diesel V-8 engine, with a Stanadyne Rotary DB2 IP since Feb, 2007. I have started the engine with no difficulty and no block heater on an 80/20 (WVO/gas) blend down to 0F (-18c). I have found that by blending as little as 15% gasoline in the summer, and as much as 50% in the winter, my engine starts and runs as if it was running on diesel fuel.
    • 12mm is plenty thick enough. Reactor wall thickness is a "trade-off". A heavy thickness will take longer to heat but be immensely strong so extra safe. For comparison, my gas/diesel fired reactor is 8mm wall with 10mm floor.
      There is a saying within the engineering industry in which I work: "Nothing ever broke because it was too strong!".
      The ratiomatic heating was commonly used here 1960s-80's in central heating systems. Popularity declined because of diesel cost increase.
      This type should be perfect for your requirements. They are efficient with built-in safety features. They should be adaptable to thermocouple PID thermostat control.
      I suggest make a miniature model of your proposed design to test theories and assumptions. A 1/8 or 1/6 scale model of say 1.6mm steel would be easily modified, quickly heated on LPG, etc. Just a thought...
      http://diydiesel.blogspot.co.nz/
      • 3mm seemed like a common thickness recommendation from those using electricity heating only. So I reasoned that I would use 5 or 6mm with flame heating. I wasn't able to find a suitable vessel, Then a length of 200mm x 8mm pipe turned up so I made the reactor from that. Honestly, I've not used a reactor with greater wall thickness than 8mm so I don't know how they would perform. I worry that excess heat would be wasted in initial heating because of the thickness and weight. There may be advantages with having a larger steel mass like heat control might become very stable with smooth temperature swings.
        Whatever you choose, please view the machine as an experimental prototype so be ready to make changes to improve the design. I'm on my 6th major revision and already it has had multiple upgrades.
        Good luck.
        • Originally posted by kedigen
          the aluminum oxide insulation to be made with bricks.
          Ermmm??? I use aluminium oxide for conducting heat? zinc oxide is an insulator?
          Rockwool is all you need
          • Originally posted by Excalibur View Post
            jonathan, sorry you're having problems. Good insulation can make a big difference to efficiency. We need good economics for heat especially where energy is expensive. I started thinking about how much heat was required to distill hydrocarbons. I searched out a report from mid 90's.
            Conventional atmospheric and vacuum crude distillation units require about 100,000 BTUs (British Thermal Units)of furnace energy per barrel processed. Since a barrel of oil contains about 6,200,000 BTU's, the required furnace energy amounts to about 1.6 percent of the processed oil.
            One oil barrel= 42 US gallons, which is about 159 liters or 35 imperial gallons.
            So therefore, 100,000 BTU or 29.3Kw per barrel.
            Naturally, the figures are from some very efficient refinery plants where oil companies have been developing their processes over decades. Just how close to that 1.6% us DIY can get will be interesting.
            those figures are for the energy required to distill.... cracking is a little bit more energy hungry especially when using carrier bags as feedstock without a conductive medium in the reactor
            • https://www.middleeastmonitor.com/ne...astic-to-fuel: Bcake:
              • Originally posted by waterboost View Post
                Jetijs used aluminum oxide bricks to make his pyrolysis reactor. See first page/s of this thread. Refractory wiki lists aluminum oxide, silica, magnesium, lime and fireclays as common firebrick ingredients. Actually, I use what I believe is Rockwool on my reflux. I like it better than Kaowool. So, yes you are correct, it is very possible to use Rockwool as insulation with success.
                Originally posted by ladanivaca View Post
                Thanks for posting. It's great to see people doing constructive things to help themselves.
                • nice and simple
                  [QUOTE=Jetijs;123461]The info is already shared, if you don't understand something or have any questions I will answer them, just ask I am aware that if you see this tech for the first time it might be confusing, but that is why I am here, to answer questions thanks for the info i will try
                  • Comment
                    • Welcome piccolo chimico. I rendered your post into English to increase the chance of help from forum members. Please post some clear photos of your plant and the fuel produced. Thanks
                      Hello everyone I'm new to this forum, to start congratulations for the forum you are nice and it is very interesting, having known sin after building my retort. I have some questions for you. I built the reactor with a gas burner double insulated with rock wool high temperature fractionation column 2 plates, pumice catalyst, plate condenser water, vacuum pump and bubbler. time use temperature from 20/420 in 25 minutes precisely, at the end of the process I get the 100/100 product is plastic from oil comes out too dark but not flammable unless it is warm, you give me a help please
                      • Last edited by piccolo chimico; 04-23-2014, 10:32 PM.
                        • Thanks for the picture.
                          Where is your reflux?
                          Please make a schematic drawing of the fractionation column. Also weigh EXACTLY 500ml or 1000ml of the product and post the weight in grams.
                          Does the fuel turn to wax if cooled in a refrigerator?
                          How much vacuum are you using on the retort?
                          More pics??
                          excalibur hello, I am attaching my retort, however, 'the picture is not complete can not be seen with the vacuum pump and bubbler unit. thanks
                          • I have been running various blends of waste oils and unleaded gasoline in a 1983 Chevy G-20 van with a 6.2L diesel V-8 engine, with a Stanadyne Rotary DB2 IP since Feb, 2007. I have started the engine with no difficulty and no block heater on an 80/20 (WVO/gas) blend down to 0F (-18c). I have found that by blending as little as 15% gasoline in the summer, and as much as 50% in the winter, my engine starts and runs as if it was running on diesel fuel.
                            • Comment
                              • foto
                                provo a caricare le foto
