lowriderzzz
Your pipe coming out of the top of the retort is pretty small. It looks to be half an inch or so. I would run a 1" pipe to be safe.
If you're after diesel you will need to keep your reflux column hot the entire time to avoid the diesel fractions condensing in it and dripping back down. Do you have heating elements for that?
Right now your reflux column is at a ~90 degree angle to your retort. Fuel would drip down the retort and fill it up until it reaches that small pipe coming out of your retort. Someone else can chime in here but I believe you want to have the reflux setup directly over your retort so the stuff that condenses in there drips back down into your hot retort running at cracking temperatures.
I feel the condenser/reflux is too large for that small retort unless you are able to add feedstock continuously.
I don't see a purge gas setup or an inlet for a purge gas. If you plan on adding plastic continuously you will need that. CO2 or N2 are recommended.
You'll need at minimum a thermocouple and a way to read the output. I suggest a PID controller with your thermocouple if you're heating using electric.
I run my retort at ~450C and I use a catalyst in the liquid phase. When I load my retort I put in a thin layer of catalyst at the bottom, fill it with plastic and then top it off with more catalyst then a bunch of stainless steel pot scrubs.
Once your retort is up to cracking temperatures it will take ~5 minutes before you see the first drips providing your reflux isn't too cold.
I also had a look at aston universities pyrolysis plant this one is a augur (inside reactor) type continuous feeding plant but after watching closely I observe that augur shaft has two rotars which are rotating in opposite directions how is that possible , what this mechanism is and what for please any one explain .
