The Time Machine
The Time Machine
Last edited by antigraviticsystems1; 12-19-2010, 04:19 PM.must first understand the nature .... and then imitateTags: None
You place this Thing on the Ground,Originally posted by leo48 View Post
How does it work?
Leo48
and wait till something unusual will happen.
Thats why its called Time-machine.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Do we need to put bomb with 555 timer in it and then wait something
to happens or what ?"There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
I believe in time manipulation, the thing is that you need to create a zone where the time moves. I believe this can be done manipulating magnetic fields having the traveler a very high charge.
Is well known in the art that you can change the half life of radioactive atoms. For example you can make the half life become significantly small like instead of 10000 years you can make it to become 1 year and so one. And you can also make it extends by applying positive voltage.
To diminish you need negative voltage, from 300KV up to 1MV. The radioactive material must sit on a plate charged with the high voltage
What i'm saying is that if you charge your self up to 1MV negative inside a plastic box, and than create an opposing magnetic field you can maybe come back in time. The idea is to accelerate your charge so the world reference will change.
