I just tried two bingos with negative to the negative, charging big 12
batteries, and result is :
one bingo : 750 mA input / 500 mA output (67%)
two bingos : 1120 mA input / 750 mA output (63 %)
Then i tried two bingos with negative to the positive (negative to the negative
somehow does not work)charging small 1,2 nimh batt. and the result was : 350 mA input / 600 mA output ( ? %)
Sucahyo, i think that we might misunderstand each other cause
i am not sure if you were aware that i charge AA batteries and big 12 V
batteries with (in both cases) big 12 V battery, so it could be the reason
for great (or maybe not such great) discrepancy between your and mine
measurements since you got your input/output results by charging small
1,2 V batteries with same kind (1,2V) batteries ?
In a few hours i ll try to see same measurement results with stingo, after
charging process (charging new 1,2V batteries) is finished ...
. But since the max output is in the pot range I think it still valid.
, so i am ready to fulfill your desires again, but
