Orgone and Orgonite meter testing
  • Orgone and Orgonite meter testing
    Guys i am not sure if this thread belongs here or in the health section, sorry if i got it wrong and please move if so i am going to do some energy tests with it tho too.
    Here is the Orgone meter based on Reich's technology
    With in reason ill take request for testing materials I was surprised to learn that crystals by them self generate A LOT of orgone, some even more then orgonite! Will have a report for all soon.
    Here is the stuff we are testing so far
    (crystals, orgonite etc).
    My big crystal there generates a bit... ill have anew report for the orgone course next year. Its cool to see the meter move with out heat, magnetism, temperature or weight, only your field effects it, people still scratch their heads when they see it
    Ash
    Congratulation .
    Please test pancake coil. Pancake coil produce different ice pattern on its side.
    I hope it can show different polarity on different pancake coil side.
    Please also mention if you can detect crystal polarity. Did the meter show same value all around the crystal? similar value?
    Do the meter detect similar polarity on orgonite with SBB coil in it?
      orgone meter
      Ash
      Hi Ashtweth do you have a schematic of that orgone meter?
        Hi Guruji, sucahyo and ALL
        Sadly the meter does not come with a schematic
        Experimental Life-Energy Field Meter and if we open it the warranty is bye bye,but never mind i found some thing which should be able to measure,this is a rotatable system that's already been built by an Italian Carlo Splendore -May work ok
        Hotfile.com: One click file hosting: Carlo Splendore, MSc Orgone motor.pdf
        This meter is a solid state version, apparently Reich used big induction coils or some thing,it also has a vacuum tube.
        @ sucahyo ,pancake coil? Hmm okay i will try and find one,i would love to see what the Rodin coil does with it. Okay will try the crystals on both sides.
        Guys check out the field tests this guy has done with the meter.
        HELIOGNOSIS - The Response of Orgonotic Instruments to Atmospheric Conditions
        Ash
          Thank you.
          Please test "Leon fuel saver" too. See if it give similar polarity to crystal or reverse.
          Also cellphone and TV .
          BTW, what polarity is the orgonite reading?
            Hi sucahyo
            Yes we did this and tested the fusion technology also,(Welcome to FusionExcel International)
            it gave off a mid range field but the thing is,it is metal BASED and ANY metal will give off a field, so what i need to do to test this is get an equal weight and size of galvanized (the best metal for ORAC's) and put into the meter and compare .Metal already attracts orgone and repels it according to Reich.
            Ps,interesting YouTube - fusionexcel3's Channel
              Thank you.
              Please also note the polarity, because I think polarity of orgone is very important.
                While your at it, try aiming a cloudbuster at it, various distances. With and without water.
                Oh, try tap water and spring water please.
                :-) interesting stuff!
                  i played with one of these about a year ago.
                  i had copper foil and paper around a bottle lots of layers filled with water no luck.you need a negative pull in the bottle pulsing mi thinks
                  one thing i like to see is the meter on this?
                  YouTube - Water Vortex / Alive water
                    Hi Bod, CosmicFarmer , sucahyo and ALL
                    Roger that sucahyo will do,CosmicFarmer ok i know the Orgone in the atmosphere drops when a storm happens i assume the same will happen with the CB . Some of the best meters where the ones TJC recommends,Walter Starks,orgonometer,sadly not available any more (reads in microamps) Will do some water tests for you, i bet the fluoride water will be worse then the spring water we drink. Bod, the blue could be the orgone he describes in that.
                    Ash
                      YouTube - Panacea's Orgone Meter Test
                        Thanks for the video. very interesting.
                        Considering the cone produce zero and then your body produce negative reading, then the cone proruce highly positive compare to you?
                        Can you zero the meter with your body as reference and then you try to find something that produce negative reading? Thanks.
                        I wonder if your surrounding is more positive than your body is a good thing.
                          Guys we had some nice flooding here in Queensland Australia (check the news) been a crazy bunch of weeks. Had not been able to do any tests as you cant measure when its raining all the orgone is saturated in the atmosphere and you will read lower then normal so will objects.
                          Ever wonder why irrigation water is the best for plants? . I did do some tests today.
                          The meter has been tested by the manufacturer and James D to be effected by sun spot activity, the moon and the weather.
                          Today i did some as a teaser, i need the weather to be just right to do ACCURATE readings, see here,this guy picked up an Orgone meter and does not even have it insulated.
                          YouTube - Orgone Orgonite Energy Test Charged Water [1080p HD] (Gifting)
                          You need it out in the open and insulated,like on a wooden table and where the sun spots,moon cycle and weather is not hey wire.
                          Its a very sensitive meter, in fact today to measure i almost had to stand
                          fully naked in the house with out all my body piercings , so here i was standing on a wooden chair half naked trying to get an accurate reading dont say i never put in an effort LOL.
                          Here is a snap of the meter squared off on a wooden insulated table with an orgonite piece and another garden piece of orgonite in the background.
                          ImageShack® - Online Photo and Video Hosting
                          Here are some preliminary readings from the half naked chair.
                          "Al';s agent buster"
                          At the X10 reading it gave of "70" units. Now what i have to do is use all X's
                          magnification settings settings and then take it off and make sure the
                          atmosphere still reads in the center,it takes a few days guys but it will be
                          worth it when i am done.
                          The orgone meter is NOT mechanistic,its not as easy as plug in and play like the federal reserve ,which is why i had to stand half naked on a chair LOL. Here is a slightly bigger in mass orgnonite piece which gave off 80 units at the same magnification setting X10.
                          This year we are heavily doing permaculture and alternative medicine OPEN SOURCE INFO,we already have many tests for the meter on the way for PERMACULTURE ....plus we may have sponsorship for the orgone meter aura scan more soon.
                          Ash
                          • #14
                            Maybe there are people who overdone rain calling?
                            I will look forward for your video, make sure you don't stand in front of mirror or glass while making video .
