sorry if posted in wrong section of forum..
Is CO2 welding wire good for coils?
Any wire or metal is good for coils;Originally posted by electronicsounds View Postsorry if posted in wrong section of forum..
- for winding - any metal; it only needs to conduct electricity.
- for core - any metal; but those attracted to magnet is better
Best coil wire (for common people like us) Copper with Aluminum in second place. Best core is Carbon.
CO2 welding wire are of many kinds - and they all conduct electricity. We are using mild steel, 304 & 316 stainless steel, aluminum and copper; thus the answer remains: Yes they are all good for coil winding.
BUT: They are not insulated.
So you will need to work around that with various options.Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
the new way ZPF makes coils
if your looking for an easy way to build a coil may be this will help
Coil Chronicles
Tecknomancer
Zeropointfuel.com
Depends on the type of coil. If the wire itself needs to be insulated then your better off buying insulated wire. If your using magnet wire its already insulated. If the copper wire itself doesnt need insulation then you would just paste it on top. If you need a specific dielectric insulation then thats a different matter. For plain insulation from electric shock and moisture the liquid tape will work.should I wind the coil and then immerse it in liquid tape or immerse the the wire in the tape and after leaving it to dry out wind it?
circuit board lacquer
When I built a tesla coil, I used circuit board lacquer. It has great insulation properties. The wire I used was from a manufacturer of enameled copper wire for transformers. I once worked for a company that built ballast for HID lighting and on some occasions, I was required to pick up some bobbins for certain jobs. I kept the resource and had purchased 47 km of .1 gauge wire, I cant remember the price, but it was cheap.Go Green Go Solar - Save By Building Your Own Solar Panels
