  • mbrownn
    Originally posted by tachyoncatcher View Post
    Eye witnesses to the original German generator and also the Lockridge replication reported a odd reverberation sound coming from the generators when the lights were working. If you have ever had a motor producing a standing wave, it will make a odd, reverb sound.
    I have literally heard this, waaa waaa wa wa wa wa waaaaaa is the best way I can describe it.
    It is my contention that the Lockridge unit has a resonant component that must be used for the gain everyone is looking for. The external windings and capacitor plates make sense when you consider this component. Capacitive plates in close, physical proximity to switching magnetic polarity seems to be a common theme to many AE devices.
    I believe I got a gain, the voltage went up, the current dropped and the motor got very hot. The gain was in heat
    @mbrown, if I remember correctly, the slotted case creates a specific magnetic polarity in the case? Maybe this needs to switch? What effect would the switching magnetic polarity have on the external coil? Even JB used a weak magnetic switching, with the capacitive coupling of small coils to create some amazing gain on that ferris wheel device he built. He also used the dielectric of a couple large capacitors for the supposed collection.
    More food for thought.
    Randy
    The split in the case appears to be to prevent a magnetic short and cause two magnetic circuits to pass through one armature. I have considered if the the circuits switch, which is possible, but remain undecided at this point. I am pursuing a different route at the moment but anything is possible
  • mbrownn
    Originally posted by HansKammler View Post
    I research a similar project when I was starting these things in the past,
    called the Captn. Coler Converter.
    it was like this: there was a photo on the net of an replication,
    stupid Papers from british OSI with no clues how to work,
    the examiner was everything but not a technician and the final
    report is like a poem, than a report...
    Stumbled in darkness like an alchimist and try this and that
    and other things to come back to the point "its not working!"
    sadly this project was shelfed.
    I need to look this one up.
    @mbrownn is lightyears ahead of lockridge experim. congrats !!
    Thanks for the complement but I am really 70 years behind
    At this stage I have no clue how this 3 filar coil works and how to connect
    to the rest. The Idea as a impedance matcher maybe.
    yes, we are in agreement here, It could be but there are so many other possibilities too.
    The thing is, if you kick a motorcoil you need a Switch and you have only
    brushes for switching action (transistors were not possible 1945)
    and a Triode arrangement seems a way to complex for Lockridge.
    True
    How to get energy from an resonance circuit:
    to extract energy from a LCR circuit you have to maintain the resonance.
    so if you put a resistive load on it, you have to change the Inductance "L"
    simultan. I do this with a double winding on a Iron rod separated with an insulator.
    the upper winding is the L from the LCR circuit. The lower winding
    goes to an AMP who pushes current in that coil to create a magnet.
    but you have to be sure not to "oversaturate" the ironcore. (if you do this
    you get not enough inductance and the coil goes hot.
    when you raise the power in the lower coil, the upper coil change the
    inductance accordingly. Simple but elegant.
    picture says more than words. I wish more of you would draw ideas, than
    describe it with words...
    The lockridge appears to have this configuration. Remember you do not have to drive that second coil, by using it as an output current flows and impedance changes. In a motor generator configuration like I have done, the lowering of impedance causes the device to draw more current. By drawing current from the generator coil when supplying the device with AC we get acceleration. Acceleration under load. This was using a simplified armature but even worked a little with a standard armature.
    I dont know if your idea about how it works is the same as mine, but you seem to be looking at similar principals
    As for resonance and using it as an LC circuit, it seams to be leading me away from that, but we just dont know.
    I use the reverse engineering approach and let the device teach me, and it has taught me a lot.
  • wantomake
    your source
    Eye witnesses to the original German generator and also the Lockridge replication reported a odd reverberation sound coming from the generators when the lights were working. If you have ever had a motor producing a standing wave, it will make a odd, reverb sound. It is my contention that the Lockridge unit has a resonant component that must be used for the gain everyone is looking for. The external windings and capacitor plates make sense when you consider this component. Capacitive plates in close, physical proximity to switching magnetic polarity seems to be a common theme to many AE devices.
    Randy
    Finally someone to pay attention to the part of this device that will power and cause the self loop needed to run the load and drive the device also.
    Thanks Randy.
    I've built my own test bench version with trifilar 26 awg wrapped around the outside of a capacitor made with wax paper and 4" wide aluminum tape. It fits over the 1950's Delco Remy generator with slotted case and coils (4) with armature.
    I tried ac and dc power through it as LC tank but I'm sure the coil and capacitor aren't matching to resonance. I remember building the joule thief with the resonating toroid coil. Sweet sound. I wanted to understand if the coil can induce voltage in the capacitor. Yes it does. So with the case in the large spool, I tried to produce voltage through the field coils in the case into the capacitor. No luck so far. I did have the capacitor wrapped around the coil at first. BTW.
    I may need to replicate the same setup with copper flashing and much larger coil.
    What is your source that you mentioned eye witnesses in first sentence? I've seen every video made on the Lockridge device. Did I miss something?
    Sorry so scattered,
    wantomake
  • tachyoncatcher
    More Observations
    Randy
  • HansKammler
    everybody on its own
    the more investigators are working together, the more knowledge and
    results we get I know.
  • mbrownn
  • tachyoncatcher
    Observations.
    Hi fellow builders,
    Here are a couple ideas, observations, and notes from my experiments and research. Much will be obvious to most but I include them anyway for completeness. I think many of the components needed for a working device have been out in the open, but not understood as Tesla understood them and the interplay between them. I hope you find these observations useful.
    A pulse transformer (DC) typically has a shunted (slotted) core. Like the case of the device here. A DC transformer will take a DC pulse and turn it into a sawtooth wave form that is biased to the plus side.
    A generator will naturally create a AC output. AC can be converted to pulsed DC.
    A reflected AC wave can create a standing wave. This can be accumulative. Study sound inference waves.
    A resistive load can do work without a clear plus and minus, but rather a potential difference between two termination points and singular point in time.
    A resistive load is part of a resonant circuit but is not variable without re-tuning.
    It has been said that to perturb the ambient (aether, ether, dielectric ...) creates an influx to balance the disturbance. An earth ground is the most direct way to connect to the ambient.
    Ambient gain seems to occur ~400Hz. Harmonics causing higher frequencies? (yes)
    Magnetic flux has inertia.
    A Tesla Bifilar Pancake Coil makes a better receiver coil than a single wire pancake coil.
    Tesla nearly always showed a AC generator in his power transmission circuits.
    Tesla used a earth ground in all power schemes.
    It is my opinion the Lockridge device used all of the above ideas to convert ambient perturbance into usable lighting. I am not an electronics expert nor do I have anywhere near the hands on experience that @mbrown has with this device. I am simply sharing based on my experimental work and research. If it seems half baked, it's because it is. Otherwise, I would post working plans.
    Good Luck,
    Randy
  • mbrownn
  • wantomake
    patience me?
    Hello Hans,
    Taking into account that there is no proof that this device ever existed, and that some unknown friend gave a box full of just parts to J. Bedini that didn't work, also why hasn't anyone from Germany (if still able to remember) come forward with any stories of such device. We had Robert here once who had a friend that remembered seeing something similar as a boy in WW2 Germany. But had no details to give us.
    But I do think such a device is possible. Why? I think Mr. Bedini knows how this device operates as a single unit.
    I have more curiosity and at my age take my time building and learning from it.
    Patience is good but knowledge is better, with all due respect.
    wantomake
  • HansKammler
  • mbrownn
    Mbrownn,
    Yes I would be very interested in your recent bench test results. If you have any Youtube or pictures(beside those on Imhotep forum) that would be great.
    My conclusion of the Lockridge device, from the test I ran, that it consist of motor, generator, and a device that stores and steps up useable voltage for the motor side to run on.
    My conclusion too. but you missed out the transformer effect inside the motor/generator.
    The motor and generating part I was able to see some results. But wasn't able to accomplish the third part- the coil/capacitor combo device. Not yet at least.
    I think we need to get the transformer part of it sorted too before we move onto the trifilar coil. I have done a lot of playing around on this aspect so hopefully we can get it to work in the device soon.
    My biggest problem is my lack of knowledge in this arena of electronic, electromagnetic, and such. So I put this aside to study and build other projects and learn.
    We are both the same in this respect. That's why I have been playing around with transformers.
    The motor/generator side of it I put in the "Interesting Motor" thread as you know, and I have thought of a name for that. Either the Motor Assisted Generator, MAG or Motor Assisted Dynamo, MAD. MADMAG would work too
    So I still have that project collecting dust somewhere so I can learn some more if you have any new findings.
    wantomake
    Be patient, I will be building again soon.
  • wantomake
    recent bench test
    Originally posted by mbrownn View Post
    Hi Hans, the research I did started with no theories or preconceived ideas, basically I got a motor and cut slots in it and then tried every wiring combination I could think of. After not making much progress I decided to rewind an armature with blanks on the commutator so that it pulsed and tried again. Now I had lots of things going on and through a process of elimination I am finding out what works and what does not.
    I have learned many things doing this and come across many problems. Each time I resolved a problem or eliminated a possibility the motor resembled more and more the device John Bedini showed us. I believe it to be an energiser of sorts, but not in the Bedini style. In fact it has no resemblance to Mr Bedini's devices that I can see. It does not seem to work in any way like Mr Bedini described in the video. No disrespect to John Bedini and his work, Its just different.
    I have let the test bench lead me, then looked at the theory to try to understand what is happening.
    Yes I would love to see a PDF of that notebook, but to be honest, we do not know if that was correct anyway. The device itself is teaching me, this is the process of reverse engineering, and so far it has been a good teacher. It does not work like any other device I have seen. Its fascinating, simple in its appearance, but complex in how it works.
    Forget about oscillators for now, that does not seem to be how it works
    I don't have all the answers but have made huge progress. I would be happy to share what I have found if you want to give it a try.
    Mbrownn,
    My conclusion of the Lockridge device, from the test I ran, that it consist of motor, generator, and a device that stores and steps up useable voltage for the motor side to run on. The motor and generating part I was able to see some results. But wasn't able to accomplish the third part- the coil/capacitor combo device. Not yet at least.
    wantomake
  • mbrownn
  • HansKammler
  • mbrownn
    I see what your saying, it could be that excess energy is being stored in the flywheel which when the generator is not being cranked continues to spin the motor. this motor then could act as a generator powering the lights. It does run a long time but there are a few things we don't know
    Why does he keep playing with the 9v battery? how much energy does it take to crank his generator? etc. From the video its difficult to make any real judgements about his hobby device other than it does run a long time with his flywheel attached.
    The most simple motor/generator is just that, with a motor directly attached to a generator. Taking it a step further we can add a flywheel and this allows us to have a longer off time as the energy stored in the flywheel can spin the generator, but in truth we had to put that extra energy in the flywheel first, so there is no gain.
    When we look at the pictures and description of the lockridge, there is no mention of an external generator. That leads me to believe it is in the device and not external.
    By doing this we do get a gain in efficiency as we only have one set of bearings to turn and one set of iron losses instead of two. This I have done and the idea has been used on other things two such as the dynomotor.
    What exactly the capacitor, extra coils, rectifier and diodes are doing is up for debate as no one has produced a functioning device, including me. However I am working on it.
