2nd set of brushes
I see two ways of mounting the 2nd set of brushes on the 12VDC (P.A.) motor and I've started (but haven't finished) fooling with both.
0) I think I want the motor to turn CW (looking down, brushes at bottom). This seems to give the the most real-estate for the outrigger springs.
1) Snip the 2nd brush board (tin snips work) and drill relief holes to cozy the board into position and glue it to the main board. It seems that this will require adding another spacer or two on the brush end of the armature to "lift" it up enough to compensate for the added height of the glued-on board. This will mean that the case will not close all the way. I don't see this as a problem. In fact, it might be an idea to add "spacers" cut from the 2nd board scraps between the casing the and the brush end when reassembling.
2) Remove the brush casings and pins from the 2nd board and attach them to the main board, drilling new holes. It looks like it *might* be good enough to attach only the front end of the brush casings to the board and simply let the rear end hang over the edge of the board attached to nothing. The spring pins are "riveted" into the board - I'm not sure how to re-attach them to the main board (force fit into a smaller hole, and crazy glue?).
I'm favouring 1, and will fall back onto 2 when I found out if there's a gotcha ...
Odd point - the bearing on the brush end is not fixed, its a round ball held down by spring metal. You can tilt the axle / bearing assembly. Need to check that it is not tilted off-axis when reassembling.
pt
pt
. It happened almost immediately so I wont be doing that again.
