Help wanted
  • Help wanted
    Hi
    316 grade steel produces almost no brown sediment, 304 grade does, so 316 is the way to go. This is called conditioning, after a while if you change the electrolyte regularly, there will be no brown sediment anymore, the plates will become a bit yellowish, but that is ok. As far as I know those sediments are loosely attached steel/iron particles that get thrown away in electrolysis process.
    The vapor or smoke is electrolyte vapor with high HHO content. If you smell it, it will have a sharp smell and burn your nose. To get rid of it use a secondary bubbler with an airstone, this will leave all the electrolyte in the water of the secondary bubbler and there will be no smoke whatsoever from the gas leaving the secondary bubbler.
    As for the voltage drop, I guess your power supply is not able to handle that much power thus the voltage drop. A battery can supply high powers, but apparently your power supply can't.
    Hope this helps,
    Jetijs
      Stainless steel contains a percentage of iron
      which accounts for the brown deposit or coloration
      which has formed on the Anodes. When Oxygen is
      liberated at the anode surface by means of electrolysis
      it first appears as atomic oxygen which is its most active
      form. It will oxidize any readily available substance while
      in this state, before it forms into a molecule with another
      atom, and the iron of the stainless steel is the most
      easily oxidized substance available to it. Iron oxides are
      brown as "rust" or red-brown.
      Before using stainless steel plates in an electrolytic cell
      they must first be "passivated" to remove the iron from
      the alloy which is near the surface. This can be done with
      Citric Acid or it can be done in a dilute solution of salt water.
      If you use salt water for "passivation" apply power to the
      plates while immersed; at the anodes chlorine will be
      liberated which will preferentially combine with the iron to
      for soluble iron chloride. Apply only enough power to get
      moderate bubbling and let it "work" for two hours. As
      the salt water solution gets "dirty" with coloration, change
      it and continue for two hours more. Once done, (4 hours total)
      rinse the plates thoroughly in fresh distilled water to remove
      all traces of the saline solution and they're ready to be used
      in your electrolyzer.
      Then the plates must be "conditioned" within the Sodium or
      Potassium Hydroxide electrolyte solution. Operate the plates
      for about 24 hours with only moderate bubbling during which
      time the anodes will become coated with an oxidized catalytic
      layer (white) which will greatly enhance their efficiency. Once
      conditioned the electrolyzer can be operated at full power
      and the electrolyte solution should remain clear and the
      plates should not change color.
      Cr(vi) compounds are widely used in the chrome plating
      business are aren't extremely dangerous when handled
      with care. The principal danger from Cr(vi) compounds is
      inhalation into the lungs such as in the near vicinity of the
      chrome plating bath while it is bubbling vigorously.
      You have no reason to be fearful of any Cr(vi) formation
      in your electrolyte solution unless you operate the electrolyzer
      at very high current levels (in excess of 250 milliAmperes per
      square inch of plate area.) At safe current densities the
      chromium within the stainless steel alloy remains inert and
      the electrode plates are not eroded.
      The recommended current density for stainless steel electrode
      plates in an electrolyzer is 150 milliAmperes per square inch
      maximum. If current is limited to that density then the plates
      will last for many, many years.
      The biggest mistake made by most experimenters is "overdriving"
      their stainless steel plates with excessive current flow which
      erodes and destroys them in rather short order.
      Whenever you see any "reddish" coloration to the electrolyte
      solution you know that the plates are being overdriven and
      are eroding. That can be very unsafe.
      The "vapor" formed during electrolysis is an "aerosol mist" of the
      electrolyte solution. Do not breathe this "vapor!" It must be
      removed from the HHO by passing the gases from the
      electrolyzer through a bubbler filled with water before the
      gases are delivered to the engine intake.
        thanks!
        Hello Jetijs and SeaMonkey,
        Thank you for your quick reply.
        You gave me enough info to work on.
        To be continued!
        For you SeaMonkey I have a question regarding the max. amps per sq inch.
        I use 8 sets of plates (110x75mm (4 1/3 x 3 inch) plate dim.).
        This is 13 sq inch effective area per plate -> 2x8x13 = 208 sq inch
        With the recommended 150 milli-amps/sq inch i can safely run approx 30 amps.
        Is that correct or do i have to calculate per pair so 15 amps stays as max.?
        Jan
          To be continued!
          Jan
          Excellent question!
          Yes, it can be somewhat confusing trying to
          determine current density in the electrolytic
          cells.
          In your case each plate is approximately 13
          square inches. Each plate is part of a series
          connection in the "Smack Booster" configuration
          so the Current Density will be based upon the
          cross-sectional area of each individual plate.
          Therefore, with plates that size (13 square inches)
          the ideal current density (150 milliAmperes/sq. in.)
          would limit your safe maximum current to
          only about 2 Amperes for a power consumption of
          approximately 24 Watts.
          (13 X 0.15 = 1.95)
          In order to operate at 15 Amperes of current the
          plate surface area would have to be 100 square
          inches to enable a current density of 150 milliAmperes
          per square inch.
          That is the drawback of the series plate configuration.
          If your plate pairs were parallel connected instead
          (8 Anodes and 8 Cathodes) then they'd be able to
          carry a total current of 15 Amperes.
          (8 plate pairs X 13 sq. in. X 0.15 Amperes = 15.6 Amperes)
          Parallel connected plate pairs are low voltage (2 ~ 3 Volts)
          and therefore require a DC to DC Converter to "transform"
          the 12 Volts/4 Amperes down to 3 Volts/15 Amperes at a
          power consumption of approximately 45 Watts.
          Fortunately, DC to DC Converters which are capable of
          doing this are now quite inexpensive and very tiny.
          And by all means, please continue to keep us all informed
          of your progress with this project. There is much to be
          said for the benefits of "hydrogen boosting" of the
          automobile engine.
            Yes, thank you, i now remember how to calculate the current density (was a long time ago i learn it in school ).
            This also means that in principle the Smack Booster design uses a to high current (2 seperate series of 4 plate pairs (4.5x2.75 inch each = 12.4 sq inch/plate = almost similar to the plates i use) and running with 20/2 = 10 amps per serie.
            This is 5x the recommended safe max. current.
            You said that chromium doesn't stay inert using a current about 250 milli-amps/sq inch. The max current should then be 12.4x250=3.1 amps
            When i was testing i measured approx. 7V and 7 amps. I was making some chromiumoxide or ferrochromium (and maybe Cr(VI)) then.
            Back to the drawing table.
            In the meanwhile i will passivate and condition the plates.
            I wonder if it will produce enough hydrogen with the low amps
              It may. Even small amounts of Hydrogen and
              Oxygen will benefit the engine.
              For producing large quantities of the gases the
              series plate configuration cannot be made small.
              A low voltage parallel plate pairs configuration is
              more effective and much easier to fabricate.
              None-the-less, please keep us informed of your
              progress and your experience with hydrogen boosting.
                Ok, thanks for now.
                To be continued!
                  Update
                  I have the plates passivated.
                  Needed just 0.5gr salt / 1 liter distilled water.
                  Was running on 1 amp (0.5 amp per serie) and within half an hour the salt
                  was all used and the fluid brown.
                  Cleaned the plates and did a second electrolysis with the salt.
                  Cleaned the plates again and conditioned the plates by running electrolysis
                  with Caustic Soda (NaOH) for 24 hours with 3-4 amps (1-2 per serie).
                  Temp. was around 36 degrees Celsius.
                  I tested the LPM (started with approx. 7 amps) -> LPM = 0.5
                  Temperature wasn't rising very fast and since my power supply has a max.
                  continu amp.flow of 6 amps i couldn't test for a long time.
                  I compared with other cells and they started with 0.5 LPM / 5 amps.
                  I am now going to build it in my car, see what is does.
                  Maybe someone has suggestions to improve the cell because i need to
                  many amps (7) to get 0.5 LPM.
                  Now it's like the Smack's Booster (2x 4 pair of plates in serie), and i am
                  looking for a DC-DC (12 to 3 volts) converter wich can run a min. of 15 amps. so i can test the cell with the plates parallel.
                  To be continued!
                    HERE is a possible DC to DC Converter for
                    the project you are working on.
                    Mouser Electronics carries these units:
                    Page
                    ... i am looking for a DC-DC (12 to 3 volts) converter wich can run a min. of 15 amps. so i can test the cell with the plates parallel.
                    To be continued!
                      I think you should avoid using salt if you intend to use it on your car.
                        thanks SeaMonkey, looking good.
                        About the salt, i just used that for passivation. Caustic Soda (NaOH) will be the
                        electrolyzer in the car.
                        I will be easy on the salt next time because i have seen some corrosion around
                        the nylon shims. .
                        I tested the cell on my car. When about 11-12 amps i had 1 LPM.
                        I think that's ok with this configuration.
                        Connected it to the air filter and expected something to hear but that wasn't
                        the case.
                        Exhaust gasses though seemed to be pure water (no smell and clear fluid
                        drops when holding my hand to the exhaust).
                        When installed properly i will go to the garage where they can test the
                        exhaust gasses (hope they will work with me).
                        Have to test it running some miles and see if there is any difference in fuel
                        consumption and engine power.
                        Maybe the engine has to burn clean first.
                        Meanwhile i can work on a parallel configuration.
                        To be continued!
                          update
                          I was working on the safety connections in the car and i, unfortunately,
                          discovered that my car does have a O2-sensor.
                          It's a sensor with narrowband output.
                          This means that i have to study the EFIE.
                          This also explains the exhaust gasses in the first place.
                          So now i'm going to make an EFIE first before testing with parallel configuration
                          of the booster.
                          I first need data on my car!
                          To be continued!
                          • #14
                            of the booster.
                            To be continued!
                            Whether or not the EFIE is needed or is beneficial
                            is somewhat controversial.
                            Most who use boosters without the EFIE find that
                            it takes the automotive computer some amount
                            of time to adapt to the hydrogen boosting. Once
                            the computer "learns" how the fuel combustion has
                            changed it then makes adjustments which result
                            in increased miles per gallon. It may take a few
                            weeks for the computer to make those adjustments
                            since part of their "programming" is to not make any
                            changes rapidly until the "trend" is fully evaluated.
                            While we all would like to see instant results with
                            our hydrogen boosters, often we must exercise some
                            patience with the electronically controlled systems.
                            They do respond in time.
                            • #15
                              ok, thanks SeaMonkey,
                              I will try it w/o the EFIE, can do no harm, at the worst there is only some more
                              fuel consumption.
                              I let you know in time what is happening.
                              Gr. Jan
