Built my first SGG:
Coil is 24 & 20 swg aprrox 480 turns and steel nails as the core
25 inch Bike wheele with 16 neodymium magnest attached (quite small though - a mixture of circular 10x3 and rectangular 10x5x5
Seems to work but my charge battery is sooo dead (voltage circa 8.5V) taking a while.
Lots of questions, but three to start with
1. To get operation the base resistor pot is fully off (ie 0 ohms and effectively I have had to reduce the base restistor to 7.5 ohms). Clearly not quite right as the current draw is circa 400 ma
2. Magnets - I can fnd no guidelines on magnet size or strength. When I had 8 magnets there was not enough to maintain operation, but 16 works. Am I right is saying that strionger magnets would aid operation ?
3. Although I have cleaned and regreased the hum bearings there is an obvious friction. Freewheel roll time is a max of 2.5 minutes. It seems that lower friction helps (obviously). In this is there an optimum separation of the energised coil as its noticable there is a magnetic drag.
cant resist...Any views on the best transistors (or FETS). I have seen comments that 2n3055 is basic and not the best ?
many thanks
G
many thanks
G
