Have you calmed down yet my brother ?
Just kidding.But when we start to use timers and stuff we have an overhead to make up as well, although it's only very small at very low power levels it would be hard to make that up.
It's also my opinion that a better result is obtained if the source voltage is kept as high as possible. In my case 12.5 volts or so.
If we want to double something for gain aren't we better off doubling 12 volts than 6 volts at the same current draw ?
To that end I realise that with the coil neg to the Mosfet Drain the coil is not really being pulsed "into" rather "out of" which I think as Greg has been trying to point out to me, is different.
So I was thinking about some things that I think 7imix said like pulsing the coils with a radiant output from something else or pulsing the coils with a cap discharge. That way the coil could be pulsed with 20 plus volts from an original 12 or 6 volt source. Like 6 volt battery to radiant circuit to toroid coils. Or battery to radiant circuit to cap to toroid coils.
But thats not this project i'm just theorising to try to get a better understanding so I can apply myself better.
I'm still not sure i understand fully what is going on with the self charging deal, i'm totally confused about that, i'm hoping it will just dawn on me .
With any luck 7imix will do it like Greg did and explain it to me another slightly different way, if not, not to worry.I've just gotta make a pair of small inductors and I can test my new circuit.
Cheers all
I am confused. You can also tune it without an oscilliscope.
