This is it !
  • #16
    Originally posted by Karl_Palsness View Post
    There is a group that has worked on this with watkykjy and what has been discovered really works. This device is very similar to the Pulsinator III device. It is like the first stage Q1. From what I have seen so far the Pulsinator III device is way more advanced and works with better principals. If you are interested in what was discovered by watkykjy then study the Pulsinator III machine. If you where to have people arrive at your home and show you info that they should not have you also would act responsibly and be quite. That is not to bury or loose the technology but not to NOT endanger your family or yourself. There are people still working on this idea and it will not die...so look at he Pulsinator III device and you will see a lot of what was done with the hex in this machine now. As for the threat to people it is real, but if we stand united as one we will overcome. There are wolves dressed as sheep among this group so be careful that you don't get bit. We are living is very exciting times with several huge advancements in OU work taking place...We the people have decided that enough is enough and we will enter the OU part of history very soon. The only question is it to late?
    Karl
    The Great question is: Are we standing united as one?
    i don't think so.
    • #17
      Pulsinator III and Hex Box.
      Karl
      Hi all,
      I'd appreciate it if someone could steer me to Pulsinator III specs. Also, is there reliable info and specs on the toroid ?
      I'm not bad at power electronics. I am still wondering why Microprocessor control is necessary. Tesla didn't use microprocessors you know? Also, is there some interdependence between a battery's ionic resonance and the toroid/circuit or can this drive a different load (not a charging load) or run another load in parallel with the charging battery (load)?
      I've watched watkykjy's parts 1 - 4 of 4 and I'm still not clear on the relationship between the 1-3-5 Box outputs and the 120 deg spacing on the toroid primaries. Is the flux 'banging' back and forth between the firing segments or adding or what ? ... or what is it SUPPOSED to be doing ... in theory ?
      Thanks in advance,
      Greg
      • #18
        Originally posted by gmeast View Post
        I'd appreciate it if someone could steer me to Pulsinator III specs. Thanks in advance,
        Greg
        Greg, take a look at the Use for tesla Switch thread. I have posted the drawing and theroy there. A team of us are still working through the details.
        The concept is "Create it", "Use it", "Store it", "Use it", "Store it", etc.
        We create the energy by pulsing a coil and "capturing" the "Flyback" (spike), then this "Radiant Energy" is stored in the capacitors, then used to pulse the next coil. This coils flyback is used to pulse the next coil, so forth and so on.
        We cannot continue to drain the input batt, while trying to create OU. We must be able to do "Work" from another source", "The capacitors" and regain the energy "The Spike".
        Hope this helps
        Jeff
        • #19
          "previous suppression threats" ? You have got to be kidding ! I am getting so tired of this "suppression threats" crap. As long as everyone who has truly developed a valid OU technology uses this "threat" nonsense we will remain in the dark ages.
          I would WELCOME any threats directed toward my development of a valid OU technology because then I would know for sure that I actually DO have IT.
          I was awfully tired at the time I wrote my first reply and didn't have the stamina to add what I wanted to add. That is; the fact that you are using a toroid as part of your circuit changes things, and I think you may have stumbled onto something. I'd like to know what your charge rate is and some other details.
          Greg
          Here's the problem, for those who have been able to empirically produce results, they, to a large degree, have not carefully thought out about keeping their mouths shut, and only providing the directions and details anonymously. In Bob's case, he's provided every one with every thing they need to produce the effects without precision.
          I have yet to personally get as far as what is shown in those video's but I've produced the effect with out precision. The effect is based on Tesla's high frequency patents. I could repeat this until I'm blue in the face but apparently people are too lazy to spend time reading about what Tesla did.
          Aaron and a few others on here have also described the effect. It's what is obtained from DC impulses. Bob just had a microcontroller setup to take the effect beyond what can be produced with out a microcontroller. There's a paper by N. Zaev on the inductive conversion of thermal energy to electricity. It all ties together. And Bearden has also discussed this.
          Really, there's no other conclusion that can be drawn other than that people want a fully working circuit handed to them. While some of us may have that in mind, we may not have the means to get there (intellectual or physical implediments, money really isn't an issue for this as the phenomenon can be produced with out precision for < ~$400).
          Read Tesla's high frequency work. Read Tesla's high frequency work. Read Tesla's high frequency work. And did I forget to say Read Tesla's high frequency work.
          • #20
            Originally posted by cikljamas View Post
            YouTube - Bob Boyce:Final conclusions
            In this video it seems that this bob boyce project turned out to be a fraud...
            But maybe if we could replicate that toroide, and use it with stingo...
            What do you think about that ?
            Those guys didn't know what they were doing. They couldn't even demonstrate on a step by step basis a confirmation of what they were doing. They posted that video as a result of frustration from not being able to do something that they couldn't follow directions for.
            Bob's work is based on Tesla's work.
            • #21
              I was wondering if someone could tell me how long it would take that setup or a setup like that to charge a 1000 Ah battery bank to 14.4 volts. If it can't even do that it is really only a demonstration of what can be done for a while.
              Batteries need to be charged fully to keep thier capacity, if a battery is drained below 12 volts it needs to recharged pronto, from what I can see this could be a viable way to prove overunity there is no better way than to use only one battery in my opinion.
              I don't think i would be happy to wait overnight to recharge a 28 Ah battery to 13 volts from 12.8 volts though, thats not that usefull. My obsevations could be off but I think in vid 4 he says that by morning the battery would be 13 odd volts it was already 12.8 volts. Maybe the accent caused me to missunderstand what he said.
              Am I missing something?
              Overunity device? Sure looks like it to me.
              Andrew
              • #22
                battery test
                I certainly hope that when a verifiable system arrives on the scene that folks will accept it for what it is and not "... maybe a misunderstanding of whats going on ...".
                At the same time though I have observed an effect that I am sure many have observed/experienced involving batteries, especially lead-acid batteries. This effect has sent many scrambling and clambering to declare that "They have IT".
                If you let an 'undamaged' lead-acid battery just sit, the chemical reaction within will strain to reach a 'voltage' equilibrium, and depending upon the temperature, that could range from 13.3VDC to 13.6VDC, even being in a slightly discharged state. If you put even a small current load on it however that voltage will plummet.
                So, when folks are diligently researching away, spiking their batteries with short duty-cycle pulses and seeing their battery voltages rise a little, they get all giddy and declare "OU !". It's just the battery recovering to a 'voltage' equilibrium. This usually follows a preceding cycle of discharge, work or something done to the 'healthy' battery.
                If you suspect your battery has been charged by an OU effect, check the specific gravity of the battery first, and check it against the manufacturer's 'gravity vs temperature' charts before you go pricing your yacht, airplane, new car or new home.
                I've heard of many broken hearts from folks who thought their bedini motors were OU just because of the latter effect.
                Peace,
                Greg
                Greg,
                I started to call that voltage a "fluffy charge" years ago because as
                soon as you used it, it popped like a balloon. The voltage readings can
                be misleading. Yes, it is the potential difference between the terminals
                but is not an indication of the work it can do. And even after loading it
                and "popping" that voltage, it can climb right back up as if it is an
                electret similar to my high voltage shock oscillated caps (when the load
                is removed).
                However, I'd have to disagree a bit on the hydrometer tests as myself
                and others that I know have found them to not be accurate. If working
                with the cheap ones you can get at any car parts store, there are almost
                no two alike that will show the same reading and a small change in the
                reading is a big difference in what the battery can have.
                So for me, the only thing I'd use one for is a general ballpark on a
                scrap yard battery to see if it is worth taking or not but definitely not for
                a precision test.
                There are most expensive hydrometers that are fancy and expensive but
                the best indication of what a battery has is to simply load it and see
                what it gives over x amount of time down to a certain voltage.
                And of course there are those that will complain if the load is too small
                and claim it is unfair (Peukert), etc...
                There is no test that will please everyone! lol
                • #23
                  Hi Guys/Greg, understand where your coming from.
                  I have spoken to Johan before, he loads his battery and has been using it in his child's toy for a while. I also have a good mate who is his friend who testifies to this.
                  Bob states the stuff is dangerous tho, and is not ready or may not release it (idea is to work on creating safe conditions where it can be used) Johan already told me he nearly blew his washing machine up (house circuit) with an "avalanche" when working with the BB.
                  Any how, based on what i have seen, he has loaded the battery more than once, and i believe him.
                  Ash
                  • #24
                    and ...
                    Ok, you've presented your lecture. Now I simply asked for some direction to some resources. I'm not going to read and absorb all of Tesla's work so I can dive into this ... that would take years. I already have a working knowledge of some of Tesla's basics. And by the way Bearden hasn't been successful at commercializing squat, and I'm certain Bedini still pays an electric bill.
                    You said:
                    "Really, there's no other conclusion that can be drawn other than that people want a fully working circuit handed to them. While some of us may have that in mind, we may not have the means to get there ..."
                    Well I do. So stop your preaching and be helpful why don't you ? As usual there is some silver tongued, articulate jerk that wants to scold everyone just so they can read their own posts. You accomplish NOTHING.
                    On second thought I'll talk to Aaron about starting a new, moderated discussion for this topic. That way I don't have to listen to any more lectures by someone that admittedly "...may not have the means to get there ...". I have no damned time for armchair experts, and it sounds like you're one of them. People like you talk and preach but contribute NOTHING to these efforts. Go write a book.
                    This was fun ... short and not so sweet.
                    Later ...
                    • #25
                      Maybe i am stupid, maybe i just do not understand english so well,
                      but whatever it is i would be greatfull if someone explain me what
                      do these words means ???
                      Does this mean that Bob is got killed by people in black because he
                      provided everyone with every thing ? If it doesnt, then i do not understand
                      these words too...
                      Well, i am not lazy to spend time reading about what Tesla did, but it
                      would be very,VERY nice if you was so kind and give us just a little bit
                      of your cake that you already made, because Tesla died long time ago
                      and you are still live, if you know what i mean...
                      Yes, you forgot to say Read TEslas high frequency work
                      • #26
                        Well I just watched video three again and I did hear watkykjy say 13.8 or 13.9 volts by morning so I must apologise, I am sorry that is impressive, I imagine something like that could be tuned very well. The way the toroid is wound is pretty neat too, is it possible to make three phase power with that ?
                        I don't suppose serial connecting the three primaries in a toriod like that but do it backwards would do anything different ? I mean like connecting the positive of one primary to the negative of the primary behind it on the core. I don't know much about these things but I think I will wind a toroid like that but without a secondary for now to experiment with.
                        Thats three 120 degree sectors the three pimaries cover. I wonder if I can get 300 winds on each. O wow the possibilities of the transformer primaries uses alone could be many. Is the transformer of Bobs design or was it designed already. I think i've seen one somewhere else but I can't remember where. My head hurts. The new year will be interesting.
                        cikljamas, gmeast you guys are straight up, gotta admire that.
                        • #27
                          Farmhand, i just watched video four and after i calculated results are
                          much different then yours...It got to be you just heard something wrong...
                          Video for last a little bit more then 2 minutes and during that time battery
                          voltage rised up from 12.79 to 12.81 V...It means that two minutes is
                          enough for two 100s of volt to rise up, it means : 2 multiplied by 100 is
                          200 minutes...200/60 is roughly 3 hours for two 10s of one V...which means
                          that if you multiply 3 hours by 5 you ll get 15 hours enough for battery to
                          rise up for 1 whole volt, and 30 hours to rise up for whole 2 volts...
                          And man at the end of the video four clearly said : In the morning battery
                          is going to be FULLY charged...
                          Thanks for your admiration, we got to be straight up if we want to get
                          somewhere (over the rainbow), we do not want to offend anyone, we
                          just want to make some devices to make us happy, not even to put big
                          companies in jeopardy, because this kind of devices are far, far away
                          from being able to do such an effect...That is why those tales about
                          men in black in this context is exaggerating in my opinion...But why ???
                          That is still mystery to me...
                          Regards !
                          • #28
                            I don't think you will get a lot of information at this stage. Bob does not want this out now.
                            Bob Boyce Hex Controller - Overunity.org.uk
                            See post 3 by Bob himself.
                            Here is another thread about it on this forum
                            • #29
                              Hi cikljamas,
                              Yes I was again confused it was between 50 seconds and 110 seconds in video four I was talking about not three. If you have another listen he says something like "in the morning the battery is 12.8, 12.9v" then quickly corrects himself to say " 13.8, 13.9v" and that he "has never really seen it go much higher than that".
                              I have no doubt there is something very interesting happening there but, if he went to the trouble of showing four video's in public, why not show the battery connected at that voltage, 13.8v ? If it so dangerous why show it in public at all ? It's not hard not to list a youtube video for public consumption.
                              I really do think OU claims should be a bit more revealing than that, I seen a lot about the circuit and toroid but I didn't see any battery charging itself at 13.8 volts. We can't be expected to just "believe" these things. I don't like to be sceptical though.
                              To cut a long story short I am not overly interested in OU myself, but it pains me that it may be needed to free us all from energy related problems.
                              I don't mean any offence, I just call it as I see it.
                              • #30
                                Hi cikljamas,
                                What to say except that your approach and way of thinking about this
                                matter is absolutely correct and right.
                                It is stupid to believe any thing of this or any other kind just because
                                we are so anxious to finally see some real OU device, and that is the
                                reason (being so anxious), i think, why we (or at least me) often feel temptation to believe something that is not yet proved although seems
                                so promising...But on the other hand, if we are too sceptical it restrain
                                our minds instead of keep them opened and ready for things that i
                                believe already exists but for some reasons so difficulty comes to daylight.
                                Really strange matter...But i hope it is going to change very soon, to many
                                people are interested and work hard to that matter of concern,and what is
                                most important it is more and more obviously that OU devices are not just
                                achievable but already achieved...So...Our victory is coming for sure !
                                But, someone stressed one interesting point : Is it going to be too late ?
