Why an Wimshurst generator that is believe to work based on "electrostatic induction" is not over unit?
I would say that is because it is based on motion. It uses the motion to change the capacitance of the electrode pairs thus raising the voltage by increasing plate separation... Thus work is needed to separate the plates because the charges will keep attracting between the plates.
I thought there might be a way to use electrostatic induction in a motionless device. To create energy.
Instead of separating the capacitor plates like Wimshurst generator to develop voltage, i thought that you could use the electrostatic induction to induce a movement of charge in a coil of wire. When this induced force moves the electrons inside the wire, a magnetic field will be developed in the coil so the force have become stored energy.
If you induce charge movements by an electric field, (field will not be consumed because there is no transfer of charges) in a wire, the overall charge of the wire will be 0 however across is poles you will have a voltage! Because there will be an imbalance of charge. So one side is positive, the other is negative. The energy that can be created will depend on size and forces, and will be limited by the field. It will be able to cause this electrons to move for a while but than they will stop because when enough electrons are close to the force the force will be cancelled out, thus only certain number of electrons can move. However, this happens at the speed of light, (well actually not because the inductance will oppose the movement of the charges so it will have a limited frequency dictated by the proprieties obviously) and so if you provide for a way to discharge this battery (free induced dipole) x times, for every time you discharge it, you will get a certain amount of free energy. So if you make it to discharge millions of times per second, even if every individual discharge of energy will be small, it can become millions of times bigger.
You can induce charges from both side of the coil since in one the induction is caused by positive field and on the other side a negative field... This would double the effect in my opinion...
Well this is the principle, seems quite logical to me. And for me it seems pretty much with what Tesla did and basic fundamental behind how he wanted to send energy to the all world.
Tesla taked about the relation of electrostatic and magnetic field.
In the sky there is a very high electric field caused by the sun so its there 24hours a day for free he just created a way to use it as a mean of setting up a free oscillation. Is not about electromagnetic transmission, like every single one thought of, is not an antenna. In my opinion is somehow pure electrostatic transmission.
Why magnetic induction, won't induce a free dipole?
In my opinion, is because the magnetic field can induce charge movement (electricity) only when it is moving, or changing flux... thus it moves charges only applying energy (work)...
I have this theory and i would like to prove it, however i'm out of money, so if you want to help me anyway with knowledge or a donation will be great. I'm studying in the mornings to try getting into the physics university for the next year, and i work exclusively on this projects every afternoons and nights, thats why my budget is kind of limited. Copper bars and vacuum capacitors, wire, and other things will be needed witch are not so cheap so for the last time, any help would be good. I still have a link for donation on my youtube videos. If you have knowledge to share is good too because with more knowledge less money need to be spend on some useless tests. just google sebosfato
I can only tell you that if i succeed in proving this theory, the results are going to be shared here.
If you do really care about free energy. Move. Change. Act.
Best Regards
Best Regards
