Metal Medical Implants and RFI - EMR
  • Metal Medical Implants and RFI - EMR
    Hi all, I've got a question I can't get any information on anywhere else so this is the natural place to ask I guess. With all the very smart and intuitive people here i'm sure some will have something to help me.
    So about 12 months ago I had an operation to remove two ruptured discs from my neck C4/5 and C5/6, they were repaced with metal cage's and screwed into place with 8 titanium screws.
    My problem is that now i seem to have a constant ringing in my ears which feels like it is originating from the implants. Just lately it has become quite bad and I seem to be getting more and more sensitive to higher frequencies, I though about it being from my computer or its power supply but I would imagine that the frequencies there would be too high for me to notice. I thought of EMR but the screws are non magnetic.
    I have stopped using my solid state energisers to try to eliminate things they operate in the Khz range of course. I'm still hearing it loud as ever, I can hear my SS devices up to about 7 or 8 khz with my ears and a bit more with my impants that sounds so silly. And the sound I'm hearing seems to be about 8 to 10 khz. But I really don't know. Sometimes I swear I can hear garbled voices when adjsting the frequency of a SS energiser.
    It seems to be worse indoors but I still hear it out in the paddock.
    Does anybody else have screws or implants in thier spine and if so do they seem to pick up RFI ?
    No one around here believes me, it's a bit annoying so if someone knows of some info online about it could you please point me to it ?
    I am a little concerned it may be causing my incredible head aches. And so it has halted all my experiments involving frequencies above 50 hz, I can make my bike wheel energiser run at 50 hz so all is not lost, the AC power here is 50 hz so I can't get away from 50 - 60 hz anyway, unless I have the power disconnected of course but I don't really want to do that yet.
    Andrew
    Although this is kinda off the beaten path it is relevant.
    Bethlehem Foot Care - Joseph A. Manzi, DPM, DABPS, - Podiatrist Delmar, NY
    About half way down it lets you know that Titanium screws can not receive radio signals.
      Thanks Jbignes5, With all the things i've been reading lately about alternative energy circuits and stuff, antenna's and whatnot, i'm kinda thinking that some kind of signal is causing it because of the way it changes when i'm around different things and in different places. I'm not sure what the cages they put in place of the discs are made of, I assume they are also titanium or stainless steel maybe they didn't tell me what they were made of only the screws.
      The ringing or static like sound is just a bit annoying and very distracting, it may not be related to the headaches.
      Which leads me to ask does anyone without metal implants have this problem ?
      I have had for a long time the normal industrial deafness type ringing but very minor.
      This is different I can feel it, as I get closer to electrical equipment like my computer or LCD TV most other stuff I don't notice a change.
      Anyway i'll use my oscillators but i'll try to stay away from them while they're on.
      Personally I don't think that Radio frequency itself could be harmfull.
        do you?
        Do you take a lot of meds like asprin or other pain relievers?
          Yes I have been taking some lately for the headaches. So that could very well explain it, not asprin though, paracetamol with codine. The headaches cause me to take meds the meds make my ears ring much louder than normal. Makes sense. I hope thats what you meant anyway please clarify if it's not. I will be happy if it not my electrical stuff doing it anyway.
          I'll do some research in that direction now Thanks.
            If implant can be destroyed with spike, try imhotep radiant oscillator, the relay version. Hold both coil terminal with your hand while the circuit is running. It wont hurt but you should notice some effect. Make sure that you switch the negative side of the coil.
              I have a hip replacement that is titanium. I also a from the original accident 15 screws and a strap that was put in place to join the the hip socket back together in the trauma center.
              Anyway.... I get alot funny sensations from it. I have isolated anything in particular that causes it. But I know indoors is the worst.
              The physical therapist told me something about the fact that when you replace a body part you body has to struggle to accommodate the replacement part. It has no nerves to communicate, yet the body will attempt to attach a nerve system function to it. This can cause alot of oddball problems initially.
              Nerves will attempt growth for up to 5 years, maybe more. In the meantime the body feels a certain amount of disoriented equilibrium. Its out of balance.
              I my case the problems has since gone away except on occasion. The worst part was the lack of a pressure sensation in the hip would make me feel like I was going to throw up. I also had tingling feelings in that region of my leg that would come and go. I had never noticed any problems around frequency although there very well could have been.
              In your case the metal may be sending extra electrical signals into into your hearing region of your head.
              There are also other explanations for ear ringing that you should consider. Hearing loss is often accompanied by ringing in the ear. Tinitiuos(Spelling?) is the name for it. I know because my Mother has the problem. And she hears alot of funny things from no where because of it. It set in about the same time arthritis started in her neck.
              You may have a similar condition that arose from the trauma of the neck injury. Arthritis will have most likely started just do the trauma in the disc.
              Thats about all I can tell ya.
              You may approach the doctor or whoever you are seeing about it, differently describe the symptoms, tell them when they came on and discuss the ringing in your ears. The signals may very well contribute to it but then again who knows what signals effect what.
              I hope things don't get to bad on ya though...
              Matt
                I just spoke to my Mother about her problem. I asked her for details.
                She told me the problem first started as arthritis and later she found out through some testing she had LYME disease. The arthritis was a symptom of that. She did have some issues with her neck and a shoulder that was hurt when her Dog knocked her off her feet.
                The Tinnitus in here ears she believes was damage done from the Lyme disease. As well as the Arthritis.
                Since she has gotten rid of the lyme disease it has not gotten any worse and the arthritis has subsided.
                I just wanted to make sure to include that because I know you work around animals. She was never bitten by a tick. The Doctor she used for the Lyme Disease said you can contract Lyme disease from animal saliva and blood. She believes she got it from her dog.
                I thought that might be something you would want to rule out.
                Oh and I had the spelling wrong Tinnitus. Wikipedia link for ya.
                Matt
                  Sorry I keep posting but here is a quete from wikipedia.
                  As with all diagnostics, other potential sources of the sounds normally associated with tinnitus should be ruled out. For instance, two recognized sources of very high pitched sounds might be electromagnetic fields common in modern wiring, and various sound signal transmissions. A condition which mimics tinnitus is RF hearing (radiofrequency hearing), in which subjects have been tested and found to hear high pitched transmission frequencies that sound similar to tinnitus.
                  Link to RF hearing
                  Dr. Matthew Jones
                    Thank you so much Matt, Lyme disease, I need to rule that out, that is a real possibility. I work very closely with the animals including the processing to the freezer. I do have arthritis in my neck from the injury.
                    I stopped with all meds and no improvement yet, it's kinda strange like I can feel it more than hear it. What you said about the nerves trying to attach makes sense.
                    I can only imagine that all different type's of wave energy passing through me will interact in a different way with the metal implants than with the rest of my body, I would only assume that a small amount of energy would be continuously imparted on these implants and with the close proximity to my spinal chord who knows.
                    It's not all that bad just very annoying and distracting i'm sure it will improve, I would rather the ringing in the ears than the two ruptured discs that I did have.
                    Now I check out what you've given me Matt I have to go to town to the Doctor today so i'll make some notes from your post.
                    Thanks a heap.
                      Hi Sucahyo, I think we have a small mis-understanding, these are good implants, unless of course they took the opportunity to slip a RFID chip in my neck while they were in there," I wouldn't put it past them"
                      Anyway I have tried what you said with the Imhotep relay setup, "I call it the scream box" because of the sound it makes, it has dual relays. It feels not too bad.
                      I'm starting to think now that my bunkhouse may be a big Orgone accumalator, the walls and roof are all sheet steel and the inside is lined almost completely with pine tongue and groove boards with only 3 inches space between steel and wood.
                      It would explain why my very rough devices work so well. Last night i built a three transistor SS Bedini to restore a car battery and when I check the In - Out this morning I measure with same clamp meter, 600Ma draw from source battery and 800 Ma out to the charge battery. On a good battery it charges like nothing I have seen before. I'm not sure if thats good or bad yet. I scoped all three transistors collectors and all are functioning as they should with a nice SS h wave but the spikes are going about 30 volts above the two batteries voltage's combined. I'll try to get a scope shot uploaded after I do my chore's.
                      Today i'll try to fix my computer with firewire connection so I can upload video's again.
                      Cheers Sucahyo.
                        Andrew, maybe you get some replies or directions here: High Pitched Ringing In My Ears - Psychic and Medium Experiences
                          Thanks a heap.
                          THis is a link to a guy who has done most of the research on Lyme disease
                          Bowman's Thoughts and Things: Great Article about Chronic Lyme Disease
                          Its an amazing disease caused from a PROTOZOA. Half bacteria Half virus.
                          There are 17 different strains of it and only one is detectable. The rest have to have test by that guy Bowman to detect the waste product it leaves in the body. He used to have an institute for testing but I can find the website now.
                          Read up on it even if you don't have it. It freakin scary how bad they believe lyme disease is world wide.
                          It genetically engineered disease. It first was discovered in the early 70's in Old Lyme, Connecticut, US. Out side of Old Lyme they have genetic testing facility for biological warfare.
                          Long story short all the kids between 11 and 19 had a chronic arthritis they labeled Adolescent Rheumatoid arthritis. Turned out it was disease that got loose from the facility.
                          Canada estimated that there population in 96 was infected at rates as high as 65 percent of the population. I can't imagine what America is being its alot warmer. We'll never know because the insurance companies will supress it to no end to keep from having to pay the bill.
                          If it turnes out you might possibly have it, which I hope you don't, look into Jim Humbles MMS. It will take care of it and treat your body better than antibiotics.
                          Matt
                          • #14
                            I see. If you don't feel anything bad, continue using the relay, maybe for 7 minutes a day. If you don't see progress in a week then stop.
                            That can be a problem if you have pollution around you.
                            That is very interesting .
                            • #15
                              Well, it seems I can rule out lyme disease they say it does not occur in Australia, my instinct tells me not to believe it though.
                              After looking over the website digitz linked I took a zener card test the first one I concentrated on and got it correct then I just guessed and got many more wrong than right. Then I took the esp test and got 64 % I think those tests can be dodgy when there are multi choice answers to choose from. Anyway if I am psychic i'm not very good at it, it's not helping me much.
                              As long as it doesn't mean i'm going "psycho" thats the main thing.
                              So after clearing my head I did some calculations of the in - out of my new SS device and realised that the dead battery i'm restoring was only holding 4.5 volts and when converted to power in power out it is only roughly 50 - 60% efficient. not too bad for a desufator i suppose.
                              Sucahyo there isn't much pollution here so in your opinion there is no problem with the construction of my bunkhouse, i'm in the country.
                              Regards all
