Don't Kill Dipole
  • #91
    Absolutely clear ! Thank you. The only other question that comes to mind right now would be when you stated "suspended via a dielectric" I'm not clear on what you meant...
    While contemplating how to create a varied potential I ended up with an idea to drive a pulse motor while shuttling energy back and forth. I don't know if it would actually work, I believe it might. Basically a rotary tesla switch with only the central cap being pulse charged.... see drawing. I don't know if it would be needed to add a pulse to the secondary caps now and then but I suspect you might which could be done through a BEMF on a bifilar winding. Might be an interesting motor in any case...
    I do hope the ground symbols you are using are in fact antennas? If they are not then all you have there is a standard circuit. Remember that we need to not complete to a common ground. It needs to interact with the environment to supply the real charges we need for the load. If you turn those ground symbols upwards they mean antennas. That should be the connection you need to get the desired effect.
    I also believe that some of the circuit is potentially wrong. Meaning the +,-'s are in the wrong area. I have to think about this one a bit to see what you are trying to say with this design. Do not take this as a criticism of your work. Keep at it and you will get it right. Wether it is wrong I need to analyze it for a bit. See if something comes to mind that might not be correct. Do not let my words dissuade you from trying new things. It is the only way that we are gonna be able to crack this.
    • #92
      What we do need also.
      Originally posted by Slovenia View Post
      I'm going to put together a pdf file of this thread. We definitely don't need anything happening to this information.
      I need someone who can go through my work here and put it in context. We have the archiver! Thanks Slovenia! I appreciate this help you are providing us all.
      • #93
        I don't mind criticism, it is a more conventional circuit based on charging and discharging the outer most caps and using the central cap as the potential change. More closely related to the tesla switch. I would love to completely understand how to couple it to the environment. Until that understanding, I can only hope to learn and catch up with someone like yourself. I feel like I entered the class at the last 15 minutes of the hour and I'm trying to understand what happened the first 45..... I'll get there...
        ________
        BDSM BBW
        • #94
          Your Work
          Hi Jbignes5,
          I'd be glad to help you with archiving your work. We can have a special file for that too.
          I'm glad to be of help to you and to whoever else wants what we are looking for.
          Best Regards,
          Slovenia
          • #95
            Jbigness5, your right... it won't work as drawn.... I just realized what you were saying....
            ________
            Grape ape marijuana strain
            • #96
              Also...
              Please understand guys and gals that I by no means know it all. I will never admit to that ever. I have read more then my share of all the greats even Einstein. The one thing that separates the good from the bad is to stay open about all of this. If I say something that doesn't make sense or doesn't fit your ideas that make sense to you let me know. I will try to offer any help to understand this based on my understanding. If it helps you and makes sense when we look at all of the universe then I have done my job I guess... Heh..
              I am seeing a lot of new stuff coming out now that is being accepted because they can not refute it. This is because we are coming loaded with experiments that prove our points. Always question and always experiment. No one will be able to answer your questions on a truthful level better then you doing it!
              I have done a lot of experiments over the years that has opened my eyes up to many new ideas that led to many other discoveries. Everyone has this ability to ask questions. So ask them think how to best figure out the answer and answer your question. I will help you to stay on track if need be but I will not stop anyone going down any road that might lead them to the answer they seek. This has always been my creedo my entire life. I might argue my points but that does not mean they are any more right then what you are seeing for yourself.
              Also, If you are gonna be going down this road you need to re educate yourself like I have done. I know time is expensive but if you are to truely understand this universe then you need to read read read. There is a lot of good useful information just sitting out there to digest. I try to link what I am researching if it rings true to my understanding. It helps to reference where you got this information and it brings a tad bit of credibility to your side of it when you can say here this is where I got it from.
              More later...
              • #97
                Ok
                I just wanted to point that out lol.. Keep at it.. It has merit....
                • #98
                  updated drawing
                  This is an update to my earlier drawing. This one is a little simpler and disconnects the ground until it's properly positioned. I'm going to attempt to build one this week for some simple experiments. It should work with a "window motor" approach driving the rotor with the central cap. Well, at least in theory... it will either go or blow !
                  ________
                  VOLCANO VAPORIZERS
                  • #99
                    I had touched on the network aspect before and here it is.
                    In all the years that I have studied magnetism I got sidetracked along the way by noticing an unusual event. This event was totally separate from the magnetic event I was studying but I though I would take it as far as it would go.
                    I started to get into viewing microscopic pictures of snowflakes and it dawned on me that like normal crystal growth you need a seed crystal to grow the formation that you wanted. Well where is waters seed crystal coming from when it freezes?
                    Check these out. Oh and when I say a pyramid I realized that it is not 4 sided only. There is a 3 sided version as well.
                    Pictures are of salt, water in crystalized form:
                    Water:
                    This last shot of the snow crystal shows that in the center there is a odd angle of viewing the junction. Maybe 45 degrees from head on? It does look like if it is a cube in the center that it could be made also with two 4 sided pyramids facing tip to tip with a binding potential holding them together. You have to remember these are floating in a water like substance that is soo fine that these are rough when compared. Also this is a 2d picture of the junction that forms I believe in between junctions or something like that heh...
                    Salt:
                    This last one is very telling of how the lines get formed going out of the pyramid.
                    It is interesting to see that the real structure could be salt and that water can take a snapshot of the junction that it falls onto. You have to remember that crystals grow through fractal diffusion. Meaning that the center is most telling about the actual junction it falls through. This junction is very tiny and crystal growth works through the evacuation of charges from the matter. As the charges get drained away it gets rigid. I suspect that charges are like greasy elbows. When the charges are not there anymore it becomes rigid and the joint expands because the bonding charges are not there anymore. As in the case of water.
                    I have not locked my opinion in as to what the junctions look like because they could be either 3 or 4 sided pyramids or even cubes. It might be a combination of all of them as far as I know. In then case of water I am leaning on a cube. If you look at the snowflakes you will see a 2d slice of some angle of the junction. Most likely 45 degrees. That would make the junction cubic. If you take the center portion of the snowflake and connect the dots you can actually make a 3d wire frame of a cube. I am starting to come to the conclusion that different materials have different configurations of the network as it's structure but not always that way because in the case of salt I have seen both networks of 3 and 4 sided pyramids as the base with the same batch of material.
                    I thought this was a nice diversion from the don't break the dipole discussion. It is very important that we go this route because this is the picture of what we want to work...
                    • pdf file of thread "Don't Kill Dipole"
                      I have attached a pdf file of our thread, "Don't Kill Dipole".
                      The file is current through yesterday, October 10, 2010.
                      • Archiver??
                        Hi Jbignes5,
                        What is this archiver you were referring to? Also, which files were you wanting to have someone go though? I noticed that you have 661 posts on Energetic Forum alone. Thanks.
                        Best Regards,
                        Slovenia
                        • Umm YOU... Lol
                          You are the archiver lol.... Making a file to save is archiving... And I appreciate that.
                          Not all my posts just the ones here. They need to be read and organized according to their context. I am so bad about keeping on track.
                          My thought process is being shifted by a deficiency in b12. I just found out that I am lacking in B12 and it isn't because I don't eat right. I am starting to exhibit MS type symptoms and I fear that if this doesn't get fixed soon I won't be continuing this subject due to not being able to think any more. My whole body is going out of wack. I am shaking like Parkinsons and my left eye is seeing double vision, along with other MS like symptoms.
                          I am gonna go with a B12 deficiency for now as that can have the same effect. They say that vitamins work better then getting it from food so I'll try that for now. It would certainly explain my lack of thought that is in context and the other evidence that something is not right. Don't worry I am on it. If it comes down to it I'll go get tests for b12 deficiency and get shots but for now I think I can get away with the vitamins and if it does not get any better I know what to look for.
                          • I Got It (Archiver)
                            Hi Jbignes5,
                            I thought maybe you were referring to some special archiver type program at Energetic that I knew nothing about.
                            I'll be glad to archive and put into context all your work on this don't kill the dipole thread. I'll look for some other relevant post elsewhere to if I have time and once this archiving job is done.
                            Sorry to hear about the B-12 deficiency. We don't need you to get MS or Parkinsons, so take good care of yourself!!! Your mind is like a steel trap and we can't afford to lose you. We appreciate all you have shared with us all.
                            Best Regards,
                            Slovenia
                            • Yeah it's not looking to well...
                              What started all this is my double vision in my left eye after it had swelled up. It is going away now but it has left a slight doubling of my vision in my left eye. I normally wear glasses and this is messing with me something terrible.
                              When I started researching this morning about this problem The bad news was that it was MS... I show all the signs of MS and have had these signs for quite a while now. Including shaking and heart palpatations. But as I continued reading I also saw that a B12 deficiency can cause the same symptoms so I am betting thats what is the problem.
                              My mother had the same issue and unfortunately it was before they knew anything about B12 deficiencies and they removed the section of here intestines that was responsible for extraction of that specific vitamin. They called it irritable bowl syndrom and removed it toot sweet .. A rather harsh treatment that has her not able to eat anything but purely bland food.
                              If it comes down to it shots will be my last resort seeing that vitamin boosters seem to work because it is not natural it is easier to absorb. I am sure I will be fine but just in case I am wrong about this then it doesn't look good. But I am sure about my research.
                              Thank you for the concern and I know it will be fine either way...
                              • Slovenia
                                Don't you mean... Don't Kill the Dipole (for very long)
                                Excellent thread, thank you.
