Renewable Energy Sources
  • Renewable Energy Sources
    Hi friends, I* am student of PHD ,I want some topics* on Renewable Sources.As I am preparing a presentation on all type of engrey resouces . I have searched alot* on Renewable Power,* and I got few content. Please help me to complete my presenatation. I have also searched some topics on google.com as I got few site but i am getting confused that which one provides me the best information : these are links of some sites pls suggest me. Renewable Power| Renewable Sources| Renewable Energy Sources – CustomerFirstRenewables and Renewable Power News.
    I am by no means an expert but if your just looking for types of renewable power i can list some sources.
    Wind, - windmills
    Water, - hydroelectricity from Dams
    Solar, - photovoltaic cells, heating water to make steam to drive a generator
    Geothermal, - heat from the ground, with a source of heat you can heat homes and water (big in iceland)
    Biomass, - NREL: Learning - Biomass Energy Basics
    You may want to try and utilize any and all, or you may just want to focus on one and have a strong topic.
      Bottled Fuel
      The technology to obtain high pressure air from a low pressure source.
        URLs to help you start
        There is a short list of helpful links on my blog, go to Our Friends Links and Helpful Links | Solar and Wind Energy Blog
        There is a multitude of resources, maybe these can lead you to others.
          What alot people fail to understand and would probably disagree with, based on the narrow minded view of consumption, from academia is...
          All electrical energy is renewable. Try that for thesis and see how far you go.
          But its the truth. The pure truth.
          You do not need a grounded circiut to create a flow of energy. A high and low potential and adequate storage are all you need. Search the Tesla Switch.
          The reason the ground is used after the load is to mathematically calculate energy consumption. After that is a complete waste of all energy. Everything that does not get used gets thrown away to the ground.
          You should do research on Lorentz and his recalculation of the Heavy Side Component. Lorentz was the man who made the ground mandatory in all circuits. Allowing this to be the standard for all future research into energy was the single largest mistake ever made.
          Look at the environment around you. The need for cheap poisonous energy is solely because we have not learned to use electrical energy the same way we use Thermal energy. We have not taken the clue from nature that everything can be used over and over.
          And still while we are near a panic to find a cheap source of energy. This one simple little tool is ignored by the academics who hold the future of energy hostage in there ignorance.
          You might be able to publish a thesis on a true renewable energy and change a mind or two.
          Brave enough?
          Matt
            Bloom Energy | Be The Solution
              It is really cool to read an article about renewable energy, so I bring this article. Click the link below. Check it out.
              solar power generator
                At what discipline are you conducting your PHD?
                I hold an MSc in Electrical Engineering and studied quite a lot of free energy stuff. Some of the most interesting papers from the field of Electrical Engineering are these:
                Prof. Claus Turtur: http://www.wbabin.net/physics/turtur1e.pdf
                He shows how there is an energy circulation both in the electric and the magnetic fields, which means these can in principle be tapped for free.
                Prof. Konstantin Meyl: http://www.k-meyl.de/go/Primaerliter...or-Maxwell.pdf - He shows some flaws in the Maxwell equations by deriving them directly from Faraday.
                Dr. Charles Kenneth Thornhill : Dr Charles Kenneth Thornhill
                He shows that because there are flaws in the Maxwell equations, Einsteins general relativity is based on a flaw, basically the flaw that Maxwell postulated the fields to be caused by charge carriers, while we know from QM that it's the fields that cause the matter and not the other way around.
                Eric Dollard: Bestandsoverzicht van /pdf/Eric_Dollard_Document_Collection/
                Especially his paper on the Tesla Coil is excellent:
                Paul Stowe a.o. :
                I am working on a paper/article myself, based on the theories from the above papers: Article:Free Electric Energy in Theory and Practice - PESWiki - my email address is mentioned there, should you want to contact me.
                You may also want to check out my collection of patents:
                Bestandsoverzicht van /pdf/Patents/
