Pyramid
  • Originally posted by NickZ View Post
    Sucahyo and All:
    I e-mailed the guy that made that last video about the pyramids. We'll see if he answers. I wonder why he doesn't explain the concept better.
    He mentions that there is more information, but he won't post it ,yet.
    Although he has been working on it for three years, it still doesn't work yet. Maybe there is something to it, and that the time is not right for it.
    He mentions that he thinks it should be a team effort to complete a working device.
    Thanks for the link Interesting and quite in line with what I try to get done. It would be nice to get in touch with him.
    As far as stirrer goes; I'm thinking about energizing (charging) water. My propeller was just a quick job to show idea. Propeller should be made of copper and have better shape. Water can collect a charge, store it for short period of time and can be discharged through a spark gap and "U" magnet. If there could be enough hv pulses I'll harness them. I'm open to anything that pyramid may provide and want to explore every corner (literaly ) and beyond.
    I was busy for couple days with other project - TS Voltaic Amplifier which I just finished but pyramid is still on my work bench.
    Vtech
    General D.Eisenhower
    http://www.nvtronics.org
    • Guys:
      I was looking through Youtube and found another interesting video:
      YouTube - Project Camelot interviews Aaron McCollum
      It's about the new Stargate in the Yemen area. Another underwater Stargate or Seagate that was opened by ETs last Jan. 5th, 2010. There are hundreds of international war ships patrolling and controlling the area.
      It reminds me of what will happen to the Great Pyramid, next, since it is also the main energetic focal point, or multidimensional Vortex stargate on this planet, as I had mentioned before.
      Blackchisel: I though that you'd find the previous video link about the Arcturians pyramid mind device right up your alley. I do think that when the time is right the remainder of the missing information will come to the surface. The info is being blocked for now, for our own good. Unless one is very telepathic, even then you may not be able to decode it and figure it out. Interesting he says that it should be like a team effort to build a working unit. I have not hear back from the guy that made that pyramid device video, nor do not expect to, either... but, I had to do my part to try to contact him.
      Sucahyo: People are showing several videos of Japans rainbow clouds formations, before the big earthquake, and the huge vortex in the water as more proof of a Haarp type of intervention, again. UFOs were also seen and videoed flying by...
        That could explain quite recent attempts to "protect" the site of pyramids by putting up fences, denying scientific research requests and restricting certain areas to visitors.
        Thanks for link
        Vtech
        • If you have the time to view the whole video about the Aden Stargate (one hour long, or so) I think that it is time well spent.
          I'd like to know of any updates with that, also, as well as with any news of the Great Pyramid complex.
          • Thanks Dingo and NickZ for the link, still downloading it. Hopefully you can get more information about the pyramid NickZ.
            I also worry about haarp too. I now watch the sky every morning NickZ, for different reason though. I have some concern with neighborhood sky:
            Currently suspecting faulty CB at that area.
            About charging water, I have an idea to rotate can. I am thinking to put a copper tube or wire in the middle. So I tap the middle and the can outside to charge or discharge it.
            YouTube - Water spinner concept #2
            The glue is not strong enough to hold the can, but at least it show that the water do make an air tubular column inside the can:
            YouTube - Water spinner concept #3, results
            • Idea of charging water
              This is an idea of charging water. I can provide translation if you wish
              • Sucahyo and Blackchisel, and robur:
                A 12 volt CB radio using a ground plane antenna may not have the power to make those patterns in the clouds. But, Something is causing those clouds to to look like that. Maybe cell phone tower effects, or...
                Aden Stargate is 7 miles deep inside the earth. There must be a reason to go down that deep, as it would be very expensive to do, very hot, no air, or electricity. I wonder what is the reason it is so deep, and also what or who is really coming and going through that seagate.
                I tried to cut a slit in the side of the beer can on my cement batteries to see if they would conduct better, since the can is insulated with a clear coat of plastic. It made no difference, it still does not generate any voltage, even though it conducts an externally applied voltage through the whole can. It will not charge or hold any charge either.
                I also tried to charge up some pure rain water in my coffee cup capacitor with a Jtc today as it was raining, and I have no access to distilled water. The rain water charges up a bit slower compared to salt water, it does take a charge, but the rain water it did not store any of the charge, once the power source is disconnected, it dropped to 0 volts.
                Spinning the whole can of water may not have the same effect as the double helix vortex, but it's worth a try. I'll try to find a video that I just saw that shows a very elaborate water vortex system, that is somewhat similar to what you are thinking of doing.
                  I wonder if pyramid blade make pyramid shaped water.
                  CB is clouds buster, or some refer as chem buster, a device with some long pipe with purpose of clearing chemcloud. But from what I have seen, the area where the CB owner live has worse sky.
                  Why don't you burn it well? Burning melt the plastic isn't it?
                  Thanks for the info.
                  Yes, It may be different. Because the water do not produce swirl in a swirl.
                  Also it became static to the outer wall and brushing the inner rod.
                  This is the opposite of blade version, the water is static to the blade and brushing the outer wall.
                  • Guys:
                    I have gotten a reply from the guy that I e-mailed about the pyramid mind device. I have e-mailed him again, and have invited him to our forum discussion on Pyramids.
                    He mentioned that his device although not made for the purpose of electricity production, does produce a bright light inside, without any source of external power. So, that sounds interesting, and I'm glad that he did reply back.
                    I'll let you know more when I hear back from him.
                    • Sucahyo:
                      In case you haven't seen this double water vortex video, I though you might like to take a look: YouTube - RESTRUCTURED WATER VORTEX MACHINE GEM
                      I connected the secondary of a Jtc to my 6 foot copper tube pyramid today. I slightly disconnected one corner joint at the bottom of the pyramid where one tube is going up, so I can connect a meter there and also the input voltage going into the pyramid. It now stores the charge from the Jt and discharges it in one second. It's acting as if the Jt were connected to a capacitor, of sorts.
                      Input of higher voltages (1000 volts, or more) would be interesting to try, but even with the low voltages that I'm applying now (18 volts from the Jt secondary), I got shocked so hard that it made me throw the Jtc across the room. I was sweaty, salty, barefoot, so I made a great ground.
                      I'm still just trying to learn about how the "capacitor effect" can store an electric charge in metals like aluminum foil, or the copper tubes of the pyramid's frame.
                      • Thanks for the link NickZ .
                        But wow, a lot of many method in one. I think if the order or polarity is conflicting, it can produce less effect than if it use only one method.
                        I use this bellow inserted into water hose:
                        And I get this:
                        I think you should use volt meter next time NickZ, between your body to anything being charged.
                        I hope that guy can join this thread too.
                        • Originally posted by dingo View Post
                          That's cool You made one?
                          Keep your mind on the aether www.PathsToSucceed.com
                          • Originally posted by future pather View Post
                            I agree. Very interesting. Thanks again Dingo.
                            I try to look for more about space time antenna yesterday and found this info:
                            - use 57 degree angle cone
                            - must be insulated copper
                            - need to be above 3 feet high
                            - need to be zapped with AC electricity after
                            - work like orgone generator device after zapped
                            - is the first beginner step for power generator device, a device to learn the concept
                            • Yes, I watched this too. Those two inverted cones do make sense. It reminds me of a coil I have it done once but it is more like a bifilar spiral. You can either pull apexes out or bases out - which will look similar to this one.
                              I can't find anything more about the entire device.
                              @sucahyo Very good idea with shaping nozzle and nice results To me it confirms that vortex shape will increase charging.
                              I keep thinking about Kelvin experiment which I also replicated over 30 years ago. There was 15 -20kV spark jumping across the gap every 30 -40 sec and water was flowing from 3' height. What could happen if water nozzles will have same kind of "vortex modulating" shape. How can we use this knowledge. What if we circulate water without discharging or increase the gap and discharge into capacitor? What if we run water pipe through a cone coil modulated with certain freq. or maybe a trifilar wound cone pulsed with harmonic freq.?
                              I'll try to sort this out and come up with something, if I can. I just tested one cone with small pulse. EMF under is much stronger than over the apex. I pulsed cone from pendulum (approx. 3V) and I can collect almost 3V pulses (bright LED) from the coil placed 2 inches under the cone.
                              Vtech
                              • Future Pather and All:
                                I've just seen his video, as well as some others that he has out now. Thank you for the link, he appears to be the real thing (ET). As well as the device shown. He knows too much to not be what he says he is.
                                Might be the first time an ET talks on YouTube. At least with some useful information. I have been waiting for just such a thing. As I can tune into his voice vibrations, I feel that he is for real, and so it the device . NO BS.
                                I totally agree with the method of space travel. Demodulation... of the body as well as of any space craft. I feel this is the start of a new wave of information, that was previously blocked. The door is opening, to the unseen Ether worlds. Like the Stargate in Aden, and Seagate by Puerto Rico. They are open, and functioning. Soon what is really happening there will be announced on Tv, Youtube, etz.
                                There must be other examples of his antenna coil working somewhere.
                                I wonder what it can produce, and what is the rest needed to make it function. I've seen another video of someone making his 3 foot tall spiral coil device, and tried to connect it to the wall socket. Of course since it is a closed circuit, it caused a direct short. And no further proof of concept shown. In any case it's about time that something different comes along.
                                His device does remind me of the Vortex mind device mentioned previously, and I'll bet it works in a similar fashion as other Aether conversion devices. We need to understand the how and why it works, he says it works like a transformer-capacitor of sorts. I see it as a vortex-Aether conversion device, similar to how a pyramid functions.
                                Again, thank you for the link, it is very interesting and hopefully will take us the take the next step of energy production.
