Simple calculation
The great pyramid was built using aprox. 2.5 million blocks of stone. Each weight between 2 and 5 tons. Accordingly with official egiptologists, the pyramid was built in 20 years. This means 7300 days. 2500000/7300 = 342 block/day. Working totally 24 hours means 14 blocks per hour or 1 block at aprox. 4 min.. Everyday, everynight 20 years non-stop. And after this gigantic work you don't put a sign or other mark to celebrate this creation. Don't tell the story about this. Strange.
Pyramid
The effect of
Ulam spiral - Wikipedia, the free encyclopedia
in the form of square spiral tunnels has not been considered.
See the following link from 18:00 mark.
LEXXTEX - 293 - THE HIDDEN SECRET OF THE GREAT PYRAMID"S CONSTRUCTION UNCOVERED - YouTube
Al
December 21, 2012 is almost upon us. Any thoughts about the Mayan pyramids and their use during galactic alignments such as 12/21/2012?
I would love to be physically there at one of these Mayan pyramid sites to soak up the energy.
Russell Coil
In regards to some attempt to build a Russell coil, I have studied Russell's concepts of gravitation and radiation, My understanding of the step up or process of nature in relation to russells coil is that it would need a input of energy to 'STEP UP" that would also need one of these inside coils to be powered. this will be used to resist the discharge and thus increasing the charge in the windings there is no step up with out sth to push against. that is why it is called a device because it is switched on with input. just like the input of gravity from the sun, and the coinciding resistance to that pressure is what creates the step up in the coils. but most importantly it is the step down is where the energy is found in the coils. the diagram to this is found on one of sucahyo's posts on page 14 of this topic 7 post form the top, ninth picture down.
I would love to do my own experiments based on what I have learned from Russell's books. But have relay no idea about how to wind these coils, any ideas on how to wind a cone in side another cone and at opposite directions,
There should be at least 4 to 5 coils, and these outer and inner coils will need to intersect at 90 degrees to each other if the coils are wound at 45 degrees, this is the angle the two forces we will be dealing with intersect ( Magnetism and Electricity ) althou this device has nothing to do with induction.
45 degrees will also dictates how fat the overall inside coils are, they must coinside to the small ends, small joining to the Apex of the following coil cone.
Also bashar Coil is simply a piece elegantly bent wire and the explanation used to explain how it works is complexly retarded. I would totally erase that form your memory because it is just a model and looks good, but serves no practical purpose. and only has 2 coils.
I wonder if there is any pictures of the Coils Russell Worked on.
If anyone has any info on the Russell Coil Please share,
Peace
I would suggest taking your dog to the vet, and not fooling with a pyramid.
NickZ
1 metre pyramid to benefit my dog's hip vs. the measurements of a Giza!
I'am seriously extra confused about this one, why would a company design and market 1-metre and 2-metre pyramids if they aren't the measurements of a Giza pyramid?
I'am about to spend $140 (cooper tubes) + $146.00 (base connecters) for a 1-metre pyramid (which I hope I can sit under, but it's primarily for my beagle with severe hip problems and a problem with her a loose ligament in her front leg.
I did sit under the 2-metre pyramid and felt tension moving away, so I did feel good energy! But will a 1-metre pyramid benefit my dog's health??
Now I'am being told by people who know that it needs to have the dimensions of 9, according to the Giza.....now if this energy healer and guy who owns a metaphysical store know I'am spending money I don't really have on a 1-metre pyramid to benefit my dogs health, why wouldn't they just tell me the truth?
I'am so damned confused! There's no research on this I can find, and I can't contact Bill Schull!Last edited by J.L.; 10-01-2011, 05:59 PM.
Haan:
Thanks for reopening this thread. We had some interesting ideas here a while back.
To answer your question about having made any electricity from a pyramid. Yes, and no. In an earlier post of this same thread I had mentioned that I would like to wrap an aluminum wire around the whole copper tube frame of my 6 foot pyramid, as a cathode, with the copper tube frame of the pyramid as the anode. This system does work, in the same way that a battery or power cell works. To further improve the voltage, each separate coil sections of the aluminum wire of the pyramid can be wire wrapped as a separate coil that when connected in series with the others, can produces several volts. This I know is possible, as I've done it using only a couple of feet of the copper tube on one part of the 6 foot pyramid. I used a wet cloth as the electrolyte between the copper pyramid frame and the aluminum wire that is wrapped onto the copper tube. But having to maintain the electrolyte cloth wet, can be a bit of a pain, and I'd like to use a dry, solid electrolyte instead.
This essentially makes a battery out of the frame of the pyramid, which can produce several volts. Probably as much voltage can be generate as with Thomas Travoger one meter sized pyramid, but possibly not as much current.
I had taken some pictures of that set up, but I have since deleted them.
TPP-Pyramide-Project
Pyramide to produce electric energy.
Here you will find all informations and construction details for free.
All the work will be Open Source, everybody is invited to help us understanding this technology.
But we will need your help to spread the Information to the whole world.
So please read our Disclaimer and read to the Link "Give and Get" bevor you start to leech the Server :-)
G. FANTUZZI
Energy Accumulator
The present invention relates to a device to collect, concentrate, bind and radiate wandering energy which is propagated on a electrical carrier wave, this device being made up by a surface in the shape of regular pyramid, octahedral, cone or surface of revolution, in particular a spherical surface, which are used as mean of collecting and concentration of the wandering or biological energy which is propagated on an electrical wave.
At the interior of the aforesaid surface in the pyramid which can be made out of an unspecified material, metallic or not, are mounted with an electrically insulting formed of copper rollings of helical whorls around axis parallels between them and with the axis of surface. The ends of said rollings exceed teh basic wall of the pyramid and end in feet of copper which join the diffusers.
The aforementioned energy or biological energy which is propagated on an electrical carrier wave, concentrated by the aforementioned surface, induced in excited rollings up by the terrestrial magnetic field and by an optional auxiliary variable magnetic field a flow of energy which radiates outside through the feet of copper in the form of a beam of electric and/or electromagnetic waves.
G. Fantuzzi -- Orgone Accumulator -- French Patent 2264406
Hi morpher, I think you might be onto something there, I'm actually in the process of winding this coil.
It is kind of like the Bashir Coils in that the primary is an upside down conical coil compared to the bottom part of the secondary. But the secondary will have a lot of turns, over 1000 turns I think. I hope to have it finished tonight.
Back to it.
Edit. Here it is. This should be good for a laugh. The secondary is an upside down garden light with 950 turns wrapped on it and the primary is 9 3/4 turns on toothpicks mounted on the bottom part of a Plant Pot.
pulling power
I have to agree... but ...Originally posted by Farmhand View PostAnyway I don't actually think there will ever be a way to take any usable amount of energy from passive coils, in my opinion they need to be excited vigorously with an initial outlay from something a hand turned Van-Degraff machine maybe. High voltages would also be needed for lots of power.
I can't see how it would be possible to pull 200 watts out of just a pair of coils sitting there or even 10 watts to be honest. However if these coils were used in an electro-dynamo-magnetic machine things could be very interesting.
It may be that we need to think out-side-the box a bit here.
I have been wondering about the demos that Hendershot performed,
with all his witnesses. If his device was a hoax, he would have had to hide
batteries or use something radioactive. His device was built by engineers w/o him touching anything ...and was made to work.
I doubt very much that he could have hoaxed his device.
One thing that interests me is that he was looking at improving the so called "induction compass" and stumbled upon a phenomenon
with Earth's magnetic field.
See the fluxgate magnetometers.
There is a primary coil and a secondary coil wrapped around
a ferromagnetic core. The primary is pulsed. The secondary
is used for measuring.
Imagine now using two coils, yes, but interpenetrating cones --
ala BASHAR -- and also having them be LARGE air coils instead.
The advantage to air coils is that B equals H .. and they
are very sensitive.
I'm wondering if the input power, if it was made to exactly
balance the earth's magnetic field in your location ... might that
not set up an interesting oscillation ... and be highly
sensitive to geomagnetic and solar events.
It is true that you can generate power directly from the earth's field,
if you have a spinning coil alone. Wouldn't it be interesting,
to design a device that doesn't need the coil to move?
You instead want to move the field near the coil.
Think "Zero Point". By exactly balancing your created field ...
with the Earth's field ... you create a situation like
artificially STILL WATER on a pond. The slightest
event creates LARGE ripples on the surface of the water.
Once an oscillation is establish and if it can be made to sustain,
pulling power is easy using the germanium AC to DC converter --
full wave rectification.
If it is magnetic fields you want to receive and utilize as power ...
you need to devise a way to do that giving you the most gain.
These field fluctuations are mechanical and LOW FREQUENCY,
so a "tuned" circuit would need large inductance.Last edited by morpher44; 06-21-2011, 08:58 AM.
Blackchisel, I think the extra indicators going the other direction to the wind on the Russell coils is to indicate the direction of the opposite, either the opposite coil winding direction, or the Aether flow in the other direction.
Like in this diagram of Walters.
There are the dark vorticies drawn with arrows drawn to indicate a flow to the center, and there are the (dashed line) vorticies with arrows indicating a flow from the center.
Much like with electricity there is a flow in both directions, of course, there must be. The theory being in my opinion if we interact with one of the flows and remove energy say from the outgoing flow, this would cause an imbalance that could only be rebalanced by an increased flow inwards then out again to where the energy was imbalanced. And the inverse of that too I think maybe both flows can be tapped simultainously.
I have no idea what to do with them solid state wise.
Where do we connect the load ?
The Unipolar generator shown by Nikola is very interesting in that, two counter rotating discs produce induced currents when properly orientated in a magnetic field. The current flows from the perifery to the center in one disc and from the center to the perifery in the other.
Maybe this could be applied to the thinking on the Russell coils, being wound couter wise to each other a similar thing might happen.
Page 465 in this document the Unipoar generator section starts, diagram page 466.
The inventions, researches and writings of Nikola Tesla, with special reference to his work in polyphase currents and high potential lighting : Martin, Thomas Commerford, 1856-1924 : Free Download & Streaming : Internet Archive
Also in the Otis Buggy there are twice as many field magnets as Gyro coils, and it looks to me as though the Field magnets are energised as the capacitor plates cut the field of the C shaped magnets also. I think this would induce currents in them.
I was looking for a one wire motor and found this so I share what I found.
CheersLast edited by Farmhand; 06-18-2011, 02:49 AM.
I think the Walter Russell Coils are wound like this.Originally posted by blackchisel97 View PostHi Alvaro, Yes, it is confusing and it almost looks like either Russell or someone else drew these arrows to hide a concept. I have no doubt that it was operational device if he tried to reach the president and got NORAD attention. To me Bashar antenna is only a half of the picture. Beside, I have a feeling that Bashar antenna alone is not "electrical device" (not meant to tap and convert energy into large amount of electricity. There may be potential appearing but it may not be a primary function. If I may use a similarity to ham antenna, stretched 20m above the ground; we can measure potential and quite a serious one during the storm but that's not the purpose of it. It is antenna designed to receive and/or transmit on certain band (freq).
What if we're the receivers or transceiver in this case and Bashar device is an antenna per se, designed to make us sensitive to a certain "band"?
I'm not trying to propagate ET communication here, just a thought.
Vtech
I cannot say for sure though, and i haven't worked out how they should be used yet. Any idea's ?
I think the coils go inside each other.
Since you guy's have such an awesome thread going on here I will link these pic's of Otis'. I like the experiments you guys are doing by the way.
And this was his Buggy.
We can see Otis supposidly used two cone's (base's joined) as a core and wound coils on it, it was suspended by its points and commutators were there at the points. The (dual cone shaped) spinning coils or gyro's passed through the feild of C shaped or horse shoe field magnets the field magnets were excited and produced thrust for rotation against the gyro's which were lensless in my opinion because they were rotating and the field magnets and stator were counter rotating, the energy generated in the gyro coils is stored in the capacitor plates and the central accumulator which excited the field magnets by commutators or through solid state switching. The central accumulator (battery) also started the process.
However the I think for flight the gyro's have a shere hollowed out in the center and are filled with mercury.
That is not important to us, only the mechanism for the production of the excess energy is what I am interested in. But if i make one one day I will weigh it while it runs.
If it stays on the bench that is.
Anyway I think there is definately something to these conical coil configurations, if you look at two cones with the bases joined from the side it looks like a square, but if you look at it from the top or bottom it looks like a circle, if you only look a one half from the side it looks like a triangle. It is a universal shape Otis said in a radio interview " It is the universal shape and it is the shape of the universe". Make's sense.
CheersLast edited by Farmhand; 06-17-2011, 04:02 PM.
