Understanding batteries
When you connect it like that, they will even out their voltage. They usually have different charge at first. When they reach completely same voltage, what to do next?Originally posted by ibpointless2 View PostOne would think that you don’t need to recharge a battery, all you should need to do is just flip it like the hour glass. Going off that idea I did some experiments where I took two 12 volt batteries, I hook both positives up and connect my multimeter across each negative post. It seems that even though both terminals say their negative it creates a positive post and i’m able to get a volt reading.
From what I recall if you invert the positive to be a negative, you will destroy the battery.
If the batteries were equalizing wouldn't the voltage reading be getting less not more. Maybe its not good to do that to them.
I just tried it the other way around connected the two negatives and get .047 volts from the two positives and rising very slowly, one battery is 12.63v the other 12.68v they were charged in parallel by SSG.
Originally posted by Farmhand View PostIf the batteries were equalizing wouldn't the voltage reading be getting less not more. Maybe its not good to do that to them.
It is confusing how this does work. How slow are you talking because i've have only held the measurement for only a few seconds and only kept the batteries hooked up for no more than a minute. My batteries don't get warm nor do the wires that hold them, and the wires are only 28 gauge alligator clips. As for the voltage rising i've have only seen it in the form of the capacitor. I take a cap that has been sitting for a day that reads about .080 volts on it and hook it up to let it charge, it gets to about .174 volts and will stay there in most cases, but the weird part is when i disconnect it from the batteries and the cap will keep on going up, instead of the normal drain i get when a cap is connected to my meter and instead the cap goes up in power. I'm sure its not a memory effect because i left the cap sitting for days before hooking it up.
I don't see how it would harm the batteries, it doesn't matter for me if the batteries do get harm as i got the batteries for free. More testing needs to be done, but what i do know is the greater the difference of the two batteries the more power. I also look forward to your testing to see if the voltage does go up.
This makes me wonder because you get greater power with more difference, so what would happen if i hook my 12 volt battery to a 6 or even a 1.5 battery? This could be very dangerous.
I just tried it the other way around connected the two negatives and get .047 volts from the two positives and rising very slowly, one battery is 12.63v the other 12.68v they were charged in parallel by SSG.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
I really don't know what to make of it, I left them like that for about ten minutes before that they were sitting idle and connected in parallel for hours, I didn't expect to see any change from the batteries by connecting only the positives or negatives, but i see a lot of things lately I don't expect to see. I'm stumped.
Your "gain" is probably coming from the calculations that take place in your meter. Not an actual gain in energy. That's why the loss shows only on the series connection.
As far as the hour glass theory it is gravity that drives the grains of sand. You are inverting the gravity pull relative to the sand. In a battery it is a chemical reaction that drives the electrons. If you want to "reset" the battery you have to reverse the chemical reaction. You can't do that by turning the battery around.
Hi Everyone,
You can get the polarity to flip its + and - by doing this simple experiment take two 9 volt batteries that are pretty much shot in my case the 1 battery had about a 5-6 volt reading on it and the other had about 7-8 volts on it.So I snapped the positive from 1 battery to the negative of the other and likewise for the other terminals and let them sit over night and the next day the higher voltage battery dropped about 2 volts and the other battery had about a -5 volt reading on it(Be warned that the batteries will tend to heat up for the first few minutes).That was the reason for using partially dead batteries.I also notice this same effect when discharging capacitors if discharge them in series using different sized caps Uf values.The capacitor reaction really has my mind working OT because I think that this could be of some importance in my future experiments But for now my latest project is to have a battery's positive terminal go through a bifilar coil and attract a piece of metal on a rotor and exit through a commutator hooked up to a capacitors positive terminal and have the capacitors negative terminal travel back through the bifilar coil in the opposite direction so that the coil maintains the same polarity and returns to the battery through another commutator and the reasoning to this is that I spin the rotor while my cap charges up and then dump my cap to a lesser cap uf value as the next piece of iron comes into close proximity of the next coil and you can begin to get the picture from here
.Now if I could only figure out where that Negative cap value might come into play here
.Ah shucks,Don't let me derail your guys thread.Carry on carry on
-Gary
