Otis T. Carr
  • Otis T. Carr
    I thought I would start a thread about the discoveries of a generally overlooked and suppressed free energy researcher - Otis T. Carr .
    Funnily enough it was Otis that sparked my interst in Radiant Energy, I found some stuff while googling him a couple of years back, very interesting stuff, I have listened to nearly all of his radio interveiws with Long John he mentions Tesla a couple of times and frequently says how the textbooks are wrong ,amongst other things.
    He was of course on a quest to go to outer space, most people at the time thought him crazy, however after listening to him speak it was hard for me to doubt he knew what he was talking about.
    Anyway he claimed that once his UTRON powered craft was spun up to the correct speed it collected energy from the environment and was able to store excess energy in the central accumulator.
    Has anyone here seen these documents? see attachments
    I have more but they are more about the constuction of the craft.
    Farmhand
    P.S. I'm thinking he would have needed some type of pulse motor type cicuit to run his machine. He also talks of rcovering energy from the coils.
    I remember these plans. Brilliant. Did he ever build it?
      Hey. Probably not. Cost a million bucks to build this. The guy made a lot of sense. Once an object is in motion and close to equilibrium it takes very little energy to sustain its momentum.
      And this energy of course can be harnessed (or gathered/accumulated ) by the surrounding environment.
        Oh, he built it and tested/demonstrated it with several people. Ralph Ring was one of those people that was involved with Otis.
        Project Camelot | Ralph Ring and Otis Carr
          And to add to Hairbear's post, in that interview with Ralph ring, Ralph says Carr was a protege of Tesla's. Right after that test drive, the gov't came and took the ship or dismantled it etc.
          I recommend downloading that video from the camelot site, since they allow you to do that, and this is such remarkable information.
          (Ring's experiments are interesting too!)
          jeanna
            Good to see some interest in this. Here is a link to a transcript of one of his radio interviews-Otis Carr Inteview (1 of 2) - KeelyNet 06/03/02
            I really think he was onto something world changing and almost did it. I would dearly like to find out more.
            I have no wish to leave this planet but I think the power harnessing capabilities of his device would be handy for all.
            Maybe some of the guys here that understand this kind of stuff could evaluate the sketches and give thier opinions on weather or not they can make any sense of the woking principal. Of the energy harnessing possibilities anyway.
            The more I learn the more the sketches seem to make sense.
            I can see similarities to a bedini machine, maybe there is a way to add capacitor plates to a bedini rotor to see if that part of his principal is correct.
            When I built my mini three pole monopole I made it on a horozontal plane so that I could just lift the rotor out of the bearings and I made it so that the coil cores were just above center of the rotor magnets, I noticed when it is spinning very fast it gets to a point that the rotor lifts a little vertically and the weight is taken from the bearings at this point almost all vibration stops, I put this down to a mag-lev effect because as the rotor speed increases the magnets spend more time closer to the coil cores. Maybe i'm wrong maybe there is more to it.
            I'm having trouble replicating it for a video because I need some new bearings,
            with good bearings I can make it spin up to 12 000 rpm with 30 volts, the coils do get hot doing it so I cant do it for too long (the cores are held in with hot glue . It also make me feel a bit woozy when it is screaming above about 9 000 rpm but that may be from the acoustics.
              "How to build a flying saucer" by T. B. Pawlicki
              How to Build a Flying Saucer
                This page contains a photo I haven't seen before of one of Carr's larger models under construction.
                  Fascinating!
                  The page with the capacitor stack and linear coil highlights the odd effect I have been researching in regards to a transformer made of capacitive plates and linear coils, it is not an inductive field that is at play.
                  I feel that more energy and time need be spent on the electrostatic nature and pickup where it was left off.
                    Yes I agree madhatter, it would be fantastic to get Eric's expert analysis of the
                    Searle device and the Carr device.
                    The PDF linked in the post below about a Searle device is very interesting as well.
                    Here's a picture of the envelope that can surround a coil which i was reminded
                    of when reading the PDF in the linked post. When there is no other light there is
                    a lot more of it visible. The bottom one I think is smaller. The line on the
                    bottom left is the wire to the capacitive ring. I realize it's probably all wrong
                    but it's pretty.
                      a piece of the puzzle?
                      Farmhand,
                      Wonderful to see a renewed interest in Carr's work. As I scoured the net for related data (a couple of years ago, at least), I came across two things, if I remember them correctly: 1) the Utron had a sphere inside of it, which contained some amount of mercury -- I've always wondered about this... would it act like a constantly changing capacitor (the coil windings acting as the other plate), thus inducing a voltage on the conical coil? (Hey, there's Tesla's conical coils!) and 2) if you look carefully at the available drawings, the middle of the saucer seems to be designed like a Wimshurst machine, something that would generate a very high voltage, presumably to generate a field above and below the craft.
                      I suspect there's much more to the Utron than meets the eye...
                      Chris
                        Originally posted by ChrisW View Post
                        Farmhand,
                        Chris
                        agreed, the model under construction on the site seems to be a visual representation more than a functioning unit. the 'square' utron coil would probably be a single wire coil and base that assumption on the results from the experiments I did with capacitor plates and coils.
                        It's also worth looking into Felcic's work, he developed a very efficient HV electrostatic generator may have also worked with Farnsworth though I'm not sure on that. Felici's patents are full of technical data and very useful information for HV electrostatic generation. his generators were so far advanced for the time that proper construction could not occur because the technology didn't exist to mfg the materials needed for them. I think that with the more modern materials and mfg methods available today a lot of 'old' discarded tech can be re-investigated and experimented with.
                          Hi madhatter, Well I disagree with the model under construction being a visual
                          representation more than a working unit. I don't think he would have bothered
                          with the engineering to make it even counter rotate just for a model. In my
                          opinion that may well be the 6 foot model that I think would be the unit he sent to be
                          tested independently. It has the field magnets and a solid metal construction,
                          I think it's well on the way to being the working 6 foot unit. I'll listen to the
                          radio interviews again and take note of some of the time of the bits I find
                          interesting particularly the part about the thrust tests and so on.
                          I think all of Searls small models are working devices as well I don't know to say for sure.
                          Anyway madhatter I glad to hear you are working on a device which may shed
                          some more light on this subject. Or that there might be something
                          in the presented info useful to you in some way.
                          Hi Chris, Yeah the mercury, I am aware of that, my thoughts were that it
                          might be mainly for stability or the enhancement of gravity generation or both
                          or maybe not. As I said I am more interested in the energy harnessing
                          capabilities than the gravity aspect. But I think they are tied together for
                          eternity, if we want lots of free energy we will need to deal with machines
                          that change weight quite a bit in relation to the earth. The mercury may not
                          be necessary for a static/non flight machine.
                          Yes there is most definitely High Voltage at play, the russian SEG PDF shows
                          the role HV plays in the working of the Searle device, HV in the Carr device is
                          likely for the same purpose polorization.
                          I linked a post that has the PDF about the Russian SEG.
                          Here's another site which may be Searles own site, dunno.
                          John Searl Solution : Russian SEG
                          Figure 5. shows the curves. And the effects are reported.
                          Now for the money men this is definitely worth suppressing.
                          From the tightly controlled physics forum where laws are misrepresented.
                          Russians confirm the Searl Effect!
                          Notice the thread is locked, someone should explain to the moderator how the
                          universe doesn't follow mans laws and he only knows what he knows, but it
                          wouldn't do any good because he is a ignoramus. He looked for and found an
                          lame excuse in an off topic post or link to lock the thread. Active suppression.
                          Is that sentence really a violation of the second law of thermodynamics ?
                          • #14
                            Pod Update FEB 23, 2012 - YouTube
                            Might want to take a look at this guys channel, I think he is working with Ralph Ring, trying to recreate a small version.
                            • #15
                              Did you reply to yourself? Are you using multiple accounts & forget to switch or something?
