The ultimate secret of free energy: Split the postive AND the negative
  • I have stated the case...
    If you want to state your case, state it for or against any of the points
    that anyone is posting. But don't pretend that you have anything to
    teach me when you use a lot of words but say nothing!
    I don't need your help and I never asked for your help thank you very
    much and if I ever do, I'll ask you for it. I don't need or appreciate your
    condescending snide remarks and your holier than thou attitude.
    STATE YOUR CASE but leave me out of it!
    For example, when I post to Lamare, who actually does describe things,
    I argue his points but I leave him out of it. Use your common sense
    and decency to do the same.
    What does your poor example of "your" definition of cop have anything to do with this topic. There is a thread already started with the exact title and problem you like to site that you authored. Yet here it comes again in a thread that was going along great where you have to put the same example yet again.
    I would say the cop of the ball is 1. What gets realized as it drops gets converted very efficiently by the balls material. It Stores that energy in a deformation of the balls structure at some point it can not store anymore and rebounds with what it could store in it's structure based on the composition of that material. You input was to only get it to a desired distance above the ground. Sorry but that was purely donated because as you said it means nothing to the ball. The potential at that point is merely a calculative method that we could predict the outcome if it was to be dropped. Your input has been wasted. What happens to the ball after the point that it disconnects is purely the balls advantage. Since you are not riding in it or on it is pointless.
    You are not attached to the ball so no matter how many times that ball bounces it means nothing to what it took to get it to the starting position or even relates to how it transforms the energy it does realize through inertia when it hits the surface into a resulting bounce back up. Did you even test the ball to see how much 1 joule of energy does to deform it and how much it converts that deformation back into it's inertia going the opposite direction?
    A better test of your example would be to deform the ball from the ground level and record you results. That way you actually give the energy or impart a potential to the ball itself through the deformation of it's structure and then record your results. Just dropping it into another environment does nothing for your input you suggest you are imparting. Take for instance space outside of our planet. The reason things will go forever in the perfect space is that there are no outside resistances. There is no outside opposition to your input. Pushing the ball with 1 joule of force will net a never ending journey of the ball. Does that mean you have an infinete cop. Well from your point of view yes and that is wrong. When that ball does meet opposition that joule will be less and less as it travels but that does not mean that the inertia you provided gets any bigger in fact it will get smaller. You gave it or imparted it with your joule of energy into inertia of it's mass by pushing it.
    Raising the ball working against gravity is not imparting an inertia to the ball or anything else for that matter from your own words because it comes to a rest. Anything that happens to the ball afterwards is only the reaction of the environment when the conditions are met, meaning it has to enter that environment. At that point you have separated from the ball you can not impart any more "input" nor can you take away anything and that is because of that separation.
    As for the cop and regauging you mention. When the ball hits the surface and gets the deformation, <-storage of energy in it's material, the ball stops. Meaning it comes to rest in an instance of time after the deformation. This is where you are supposed to reguarge meaning it's potential minus all the resistances(materials, shape, etc.) on the way is the new potential value. Just like it enters the environment the first time this is where it starts again. How can you include the balls successive bounces if it stops in between each bounce?
    This is why this example is a poor choice for any cop measurements if cop was related to this at all. For all we know movement of any body in space doesn't cost a thing. The establishment of it's inertia cost everything and you were not responsible for it's acceleration nor it realization of it's potential. The environment is responsible and is the receiver if any gain are to be established which I highly doubt there would be gains because the ball stops eventually.
    Aaron as for the comment of holy then though attitudes you might want to look in the mirror. You are not open to new ideas nor are you open to someone suggesting you are in error. If someone points something out to me that I might be in error about I take it with all the intention that the other person suggested it in, in good faith. You on the other hand like to start crap in an unrelated thread which a thread made by you was started already. You want to aregue that then take it to your thread. I did not start this and for some reason you think it is sooo important to bring this bad example up.
    Hmmm... just read back a lot of pages and I was the one who brought it up Aaron. I am sorry about that. But my arguement is still in play...
    • @jbigness
      As for the cop and regauging you mention. When the ball hits the surface and gets the deformation, <-storage of energy in it's material, the ball stops. ... Just like it enters the environment the first time this is where it starts again. How can you include the balls successive bounces if it stops in between each bounce? <======= ????????
      Jbigness, you're putting words in my mouth... you really are. You're either
      on a mission to misinform everyone or you simply have not been able to
      comprehend anything I said.
      By stating that according to me the ball has a cop of infinite if it was
      put in space and pushed - that is YOUR explanation and erroneous
      interpretation of what I said - not mine.
      Only if the ball bounced to the same height each time or higher would
      the cop move in the direction of infinity and if you think anything I said
      has anything to do with that, you're completely mistaken.
      I said each successive bounce has 13% dissipation - according to the ball
      I used - you are contorting and twisting my words and the context
      that I used them in.
      I have very, very, very, clearly stated, repeatedly even, that on
      each bounce, it goes to a lower and lower height. But each time it
      is bounced to any height, it is 100% factual that it requires a certain
      amount of work in joules to accomplish each and every lift from the
      ground
      . You cannot argue that fact.
      You also cannot argue the fact that if you added up all the joules of
      work that the math says is necessary for the weight of the ball to be
      lifted against gravity to a certain height, it is MORE than what the
      math says is required to lift it initially, period. PROVE IT WRONG.
      Post the math, the height of each bounce, etc... just DUPLICATE THE
      EXPERIMENT and don't give me your opinion. Post the RESULTS based
      on actually doing it, THEN give me your opinion on it and not before
      you're actually educated on what we're talking about.
      This is because even an open system "contributes to the entropy
      of the universe." Each bounce is less and less.
      I have even had
      someone try to state that if it worked the way I stated that the ball
      would bounce higher and higher each time. That just goes to show the
      immature level of mental comprehension and if they really are not that
      far gone in the mental realm, then they are disinformation specialists
      that are simply being overly ridiculous in order to simply make noise and
      drown out the facts.
      You just have to make up for the losses if you want it to keep performing
      the same work for a fraction of what it took to get it going. This is an
      indisputable fact.
      I argue the points, you are the one that tries to bring me as a person
      into the picture. Usually, when someone has nothing of value to add
      or say they attack the person. You brought me into the picture and
      brought up my book that is "set in stone". As if you had any room
      to speak for what my own personal opinion is!
      You have no right to claim how or what I think when you can't even
      analyze the situation properly. The average person would say you're
      talking out your you know what.
      Anyone that has my book has read in the very beginning the following
      sentence:
      "This book is an explanation of my own model of the universe and is
      fairly balanced in philosophy and science. It is an exploration in
      imagination as well.
      " - page 24
      EXPLORATION IN IMAGINATION...
      Set in stone huh? I don't know how many hours you spend searching
      for things that either validate or destroy your very own belief system but
      I actually spend a significant amount of my own time doing just that.
      All of this is an exploration in imagination - at least for anyone that has
      at least one small iota of honesty within their being. That applies to
      EVERYONE.
      A portion of my model is inspired by Tom Bearden and if you want to
      debate some specifics, I have the references in actual published
      academic literature for virtually each and every point and based on your
      comprehension of what I have posted, it wouldn't do you any good.
      You did insult me Jbignes and there is no way around it and it was
      uncalled for. I stuck to the points that you and Lamare are posting
      and never even brought YOU up because I do have something to say
      about each specific point that is mentioned. I hunt and peck for
      line items in people's posts and address each thing with a systematic
      logical method (methodological).
      You simply cannot post something that is contradictory in nature or
      illogical and think it is going to get past the radar.
      I admire and respect Lamare. We're on the same page "for the most part"
      but there are some technical points that I disagree with and I state why
      and have no need to disrespect him as a person. Even though I don't
      agree with all his points, what I appreciate most about him and his work
      is his excitement and passion - and I consider myself to be extremely
      passionate and I think if more people got constructively passionate
      about all this, we'd all make this world a better place much faster!
      I was admiring your passion and excitement too until you chose to
      personally attack me because you disagree with my posts that stick
      to the points.
      So discuss the points and leave the person out of it - namely me, do not
      insult me or pretend you know what ideas I have that are "set in stone"
      or anything else about me personally. You really have no idea.
      And the reason I bring any of the bouncing ball, cop, etc... examples
      are because the moment something is posted and for it to even be a
      valid statement or analysis, the very premise of it is going to be based
      on having the proper definition of potential and energy. And if I see
      something in the explanations that are open for discussion, I'm going
      to bring up the distinctions of what potential and energy are in terms
      that are rigorously scientific, factual and logical. It only takes intellectual
      honesty within a person
      to see it, get themselves out of the way and this: res ipsa loquitur, literally.
      So to the points - you say the ball is 1.0 COP. That means you get
      as much out as you put in and if there are losses, it is made up in
      an exact equal part from free environmental input. If you put in 10 joules
      then you are saying we'll get 10 joules of work out of it.
      Here is an indisputable definition of potential energy of an object at
      a height according to conventional science:
      The best test preparation for the ... - Google Books
      "Thus, a 100kg boulder at the top of a 25 meter high cliff would have
      an
      (potential E) = (100) (9.8) (25) = 24,500 joules
      100 kg X 9.8 gravitational rate X 25 meters = 24,500 joules
      That means if that boulder would be dropped, it would perform
      24,500 joules of work.
      That's nice and everything but if the boulder was sitting on the ground
      next to the cliff and the question was asked - "How much work would it
      take to lift a 100kg boulder up against gravity to 25 meters?"
      The answer would be 100 X 9.8 X 25 meters = 24,500 joules.
      Therefore, according to all of this, if I lifted a 100 kg boulder to 25
      meters it would REQUIRE 24,500 JOULES IN WORK TO LIFT IT. And if I
      let go of this 100kg boulder at 25 meters, it would then give me 24,500
      joules of work. I put in 24,500 joules of work and got 24,500 joules
      of work worth of lift and when dropping it I got another 24,500 joules
      of work for a grand total of 49,000 joules of work. That is a cop of 2.0.
      IF and that is only IF the "science" and "math" wants to claim that if
      a 100kg object was lifted to 25 meters that it would "store" 24,500 joules
      of potential energy and it took me 24,500 to lift it, that means, literally,
      that IF there was 24,500 in potential energy when I got it to 25 meters,
      IT ACTUALLY TOOK ME ZERO (0 JOULES) OF ENERGY TO LIFT IT TO
      BEGIN WITH AND IT GOT TO 25 METERS WITH ZERO LOSS!! lol
      That is common sense. The math says it takes X joules to lift an object
      to a certain height. IF that is true, then there CANNOT be any further
      joules in potential energy available after the lift!!! If there is even 1 joule
      of work done AFTER THE BALL REACHED THE PEAK, the math is wrong!
      It would then have to be joules to lift + x amount of stored potential and
      that would have to be predictable before hand but we don't say up
      front it takes such and such to lift it and there will be such and such
      amount of work that happens after we let go.
      We know for a fact that joules of work is done when we let go of the
      object after lifting it into the air. We know for a fact it takes a certain
      amount of joules to lift it to begin with. So we know for a fact that more
      work is being done than the math says is required to lift the ball to
      begin with. And therefore, we know for a fact that there is MORE work
      being done by the time the ball rolls to a standstill than was required to
      The distinction I lay down is that the math is right! It is correct in
      only showing how much it takes to lift it. And AFTER the lift, there is NO NEED
      for any of our input to be "stored" - it is pointless and redundant and
      I don't think God would create such a blatantly foolish. Instead,
      you get the lift from your own labors and FREE GRAVITATIONAL POTENTIAL
      comes into the picture to do more joules of work and NONE of that
      gravitational potential was supplied by us, it is free from nature.
      Again, the LIFT of the ball in and of itself - the LIFT IS THE WORK we
      get from the required joules to lift it.
      • @jbigness2
        You say when the ball hits and deforms it "stores energy". Come on!
        That is nonsense! You cannot "store energy", period, ever! Energy is
        dissipation and loss in the system. Watt hours on a circuit is energy
        and is work and dissipation and loss. You are actually saying that
        watts would be storable.
        The ball getting compressed is no different than charging an
        electromagnetic coil. You are creating a potential difference in it so
        that there will be a rebound which can be put back to use and
        reestablish another potential difference. And it can do it over and
        over and each time there is a small diminishing of the potential
        difference (unless we inject only the loss on each cycle and keep the
        full amount of work by only paying a small fee of the loss).
        If you can send a pulse into a coil and get it to oscillate. The peak is
        highest at the start and slowly diminishes on each cycle until it
        dwindles down to nothing. This is like common sense for most anyone
        looking at waveforms.
        I spent a lot of time analyzing the difference between the area of
        waveform below the ground line compared to the top. But just looking
        at the common sense nature of it, it is roughly 50/50. 50% above
        zero and 50% below zero. Obviously a bit less on one side or the other
        in reality but for the most part, it is fairly even.
        You're only getting a 50% bounce back on each side because it is allowed
        to get inversely negative by almost an equal amount but that isn't
        going to cut it.
        For example, my 40 gram ball only goes 17% negative and not 50%!
        So it bounces back up to 83% of the original height on the positive
        side of ground!
        So you can actually add up a bunch of positive work in the forward
        direction from a very small input of the initial lift.
        From the BEGINNING OF WORK to the END OF WORK - that is what
        defines the system of anything that you put in work and you keep getting
        work back over and over until it dwindles down to nothing.
        So the entire system encompasses our LIFT and EVERY BOUNCE until
        the ball comes rolling to a complete stop. From complete rest to
        complete rest. From equilibrium until it reaches equilibrium again.
        From the time we pick up the ball from a dead rest on the ground to
        a certain height until the balls bounces, rolls and comes to a stop.
        EVERY BIT of work there from our lift to the bouncing and rolling of the
        ball until it stops is ALL INCLUDED IN THE AMOUNT OF WORK WE DID.
        And the ONLY INPUT that is considered in the equation is what did it
        take to initiate the system - the lift! That is it.
        The entire work done in joules including the lift, every bounce height,
        etc... is all considered total work done. Our lift is the ONLY input we
        had to expend to get it started. total work divided by our only input
        = the cop of the system, period, end of story. The ball is about
        a 7.0 cop and there is no amount of fairy dust that will change that.
        The only way this idea is wrong is if the math is wrong. The math
        is not wrong, it does tell how much is needed to lift the ball to begin
        with. What is wrong is the meaning assigned to it in order to keep
        everyone hoodwinked to the fact that infinite potential is all around
        us all the time but we are normally hypnotized by the misdirection
        of the magician who points his hand in one direction while the other
        is doing something else. "Move along - nothing to see here folks!"
        Misdirection, they're never been able to hide nature from being nature
        but they sure can hoodwink the masses by specifically engineering
        paradigms that they want the masses to perceive nature by! And ram
        it through the very education system that takes money from them
        through grants in order to produce stuides that supports the grant
        money provider's agenda!
        What a racket!
        And you say the ball stores the loss and the ball
        stores dissipation as it is getting compressed? That is exactly what is
        meant by storing energy and you DID say it stores energy when it is
        deforming! That isn't happening in this lifetime or the next. There is no
        ENERGY being stored. Only dissipation and then a re-establishment of
        another potential difference as a FACT. It is like compressing a spring.
        You're creating a potential difference. It took WORK to compress it.
        Then it gives back work when released for a sum total of more work than
        is required to compress it (talking about compression work and work
        it gave back - add them up).
        The force imparted on the mass of the ball IS the resistance of 16%+
        dissipation with my ball. That force creates a potential difference and
        it rebounds
        As the ball meets resistance, the free gravitational potential is finally
        able to encounter real resistance from the ball itself as the ball is
        compressed against the ground. All that resistance is
        DISSIPATION/WORK/ENERGY. NONE of that is getting stored - it is
        dissipated back into the environment/vacuum!
        At an 83% rebound height (efficiency of the ball) - 17% is losses.
        Probably a fraction of 1% is lost in air resistance at only a height of
        a meter. 16%+ some is being LOST (not stored) by the dissipation of
        impact of the gravitational potential opposing the now slower moving
        mass (protons) of the ball itself.
        That impact compresses the ball to a certain degree (100% of
        gravitational potential - (minus) the losses of 17%) - meaning the
        ball will get compressed to a proportionate degree in order to create
        an asymmetrical potential difference (like a compressed spring) that
        allows it to rebound to 83% of the previous height we lifted it to!
        NOT THE SAME HEIGHT - but 17% less - meaning there is loss and there
        is not way the ball is ever going to bounce to the same height or a
        higher height!
        100% of the potential to cause this ball to come up to 83% of the
        height came 100% from FREE from gravitational potential and NONE of it
        came from our initial lift. What we put into the initial lift is GONE
        when the ball reached its peak or 1 meter in the example given.
        If it takes 0.392 to lift it to a meter. The math says it will have 0.392
        joules of potential energy at that height. The gravity provides the 0.392
        joules of potential
        and encounters 17% loss on the way down and on impact and
        it rebounds to 83% of the 1 meter height or 83 cm.
        Your deformation questions are irrelevant and are distracting from the
        points I make. You start with 100% of the "potential energy" at any
        given height and when you drop it, there is air resistance and impact,
        and that takes away from that 100%. Whatever is left will be realized
        in the corresponding height that came from the corresponding amount
        of compression on the ball. That compression in and of itself is NOT
        a loss of energy. Only "energy" was lost during the compression to
        establish the potential difference.
        And please don't bring up semantics, this isn't a perspective issue, it is
        a common sense one.
        You say there is no opposition to my input. You have got to be
        kidding!!!??
        There is the downpushing gravitational potential which causes a REAL
        MEASURABLE FORCE on the object as it is lifted against gravity (9.8)
        9.8 close to earth anyway.
        You take a 40 gram ball and move it against gravity and you have
        0.392 N of force and you multiply that force by the height and at
        1 meter is 0.392 joules. If you don't understand that it actually takes
        joules to lift a ball against gravity and you claim that there is nothing
        to oppose my input of lifting the ball, then you need to stop right
        there.
        You even admit that when I take my hand away I cannot contribute
        any more input to the ball. Obviously! So any further work is FREE.
        You think you can isolate the rest of the ball's bounces from the initial
        input of what we put in? IT IS THE SAME SYSTEM. WORK IS BEING
        INSTIGATED AND LEVERAGED BY OUR INITIAL INPUT THAT IS ABOVE
        AND BEYOND WHAT WE PUT IN.
        Don't try to pretend that on each bounce is it's own system and that
        they are all isolated from each other and they're all separate systems
        from the input lift to begin with! Didn't you try that before?
        You are doing your best to sprinkle pixie dust in people's eyes. I hope
        nobody falls for it.
        This is not my opinion - you simply need to go do your homework and
        stop wasting everyone's time with this total and complete
        misinformation. I am posting facts that are substantiated by
        not only empirical evidence but is so much peer-reviewed published
        academic/scientific literature that I could bury your for years in references
        if you had the intellectual honesty to follow up on it and it is all common
        sense once the distinctions are pointed out.
        @EVERYONE - if you are watching these discussions, please find out
        the facts for yourself. Do a simple search and research the keyword
        in google for: non-equilibrium thermodynamics
        This is what Jbigness is stating:
        He claims that all the successive bounces are a separate system
        from my input and is therefore disconnected from my input - in a way
        that means all the work in the successive bounces can never have
        any connection to the input lift.
        That means that if you put in 10 joules in an electrical system and
        by its nature it gives you 70 joules worth of electrical or mechanical work
        that you cannot consider that circuit a cop of 7.0 and it is not producing
        more work that you put in to it. That is because he claims that after
        you supply a certain input, everything else that happens from that point
        cannot be considered as coming from the input!
        At perfect efficiency, it would take 745 watts to make 1 horsepower.
        So he is saying that if I had some pendulum machine - something in the
        spirit of Velijko's oscillator - and it had some kind of pendulum thing that
        turned some wheels that turned wheels and turned a motor - and if
        I could put a 74.5 watt burning motor on the input and have this
        machine amplify it to have a 1 horsepower shaft at the other side -
        he is saying that all that pendulum swinging wheel turning stuff is work
        but we can't say that the input caused that work.
        That is like saying we lift a pendulum and it starts swinging and all those
        swings after are a completely different system from our initial lift and
        cannon be considered a part of the same system and we cannot make a
        ratio (cop) of all those swings in joules compared to the initial input.
        And he is saying there is nothing to oppose the initial lift! So there is
        no gravity now!
        You state clearly:
        "How can you include the balls successive bounces if it stops in between each bounce?"
        LOL, come on! lol - that is the same thing as when a coil oscillates
        and it swings negative. The lowest it goes doesn't have to be zero volts,
        it can be negative before it swings positive. But when it hits the
        negative voltage in its negative swing, it stops right then just before
        it rebounds positive! AND YOU INCLUDE ALL THE OSCILLATIONS!
        That is the whole point to "free energy" and over 1.0 cop systems Jbigness!
        You can't be serious! That is the whole point - the moment it stops
        right before it rebounds is the beginning of the cycle when it "regauges"
        itself!
        The point to these systems is that we only have to input a very small
        amount of work which is intelligently leveraged to keep producing
        work in rhythmic impulses over and over and over with each time having
        a small diminishing of rebounding because of the losses and between each
        cycle, it comes to a dead stop right before it rebounds - COMMON SENSE!
        If we don't want to just let it diminish, we then supply only 17% input
        when the ball gets to 83% of the original height to bring it back to
        1 meter and we can continue that to the end of time and on each cycle
        we are are getting as much work back as if we had actually lifted
        it to the entire meter again and again and again but only have to lift it
        17 cm instead of a meter - to get a meters worth of work over and
        over and over! WE ONLY HAVE TO MAKE UP FOR THE LOSS!
        • please Aaron...
          If you don't know the simple fact that if I deform the ball that it will return to it's original form when you take the applied pressure off then you are misleading yourself.
          You are not the one responsible for that the ball is. And you are not responsible for that structure rebounding back to it's original form and state. Thats very very simple logic. The ball is the ball because of it's composition. It will react to the deformation all on it's own without any input from you or else it would drop and stay where it is with no bounce.
          It stores the energy in the deformation of it's structure. In all effect converts it to the deformed state and then converts it back to inertia by the elasticity of the material. These are well know facts.
          Again
          "By stating that according to me the ball has a cop of infinite if it was
          interpretation of what I said - not mine."
          It is not erroneuos to change the environment the ball is in to see if what is going on is related to the ball or the environment. If the test fails and of course it does in this case then all of what you are seeing is not inputted by you! You failed to include the environmental costs and additional input(environmental) in your calculations. You lump everything together without knowing anything about the whole system.
          Lets say that in fact it costs nothing to have the ball travel. but it does count when you have to fight gravity on the way up and get a free push on the way down. If you lump them all together that nets zero or near zero, very little when all the resistances like wind are figured out and fighting gravity where that is plausable.
          That is what I have been saying is that the rubber or whatever material the ball is made out of is a very good storage of inertia through the deformation of the balls material. When you deform it, it will push back. This push back is not because of you it is internal to the ball and it only has a capability to convert the forward momentum into potential based on how much that material is deformed.
          A little test will prove this. Deform the ball on the ground by 1 joule. Now let it go if you could find a way to do that and see how high does the ball rebound. Certainly not back to your original position. This will give you a litmus test for it's converting ability. And I bet once you know that you can see it's efficiency to change the 1 joule into rebound strength you would throw you analogy out the window.
          All you would need to do is apply that efficiency to the first drop and check it. I bet they will match. The ball is probably around 70-90% efficient but with all the other resistances they subtract from the balls new potential point or what it can attain on a rebound. So the cop from the 1 joule mark would in fact be 1 minus resistances of falling through the medium of the environment and subtracting it's less then 100 percent efficiency of converting forward inertia to an opposite inertia.
          What it took you to get the ball in the first place to that 1 joule level is nothing but a donation. You have said that the ball does not store the potential which is very true in this case because as balls work you need to have a deformation of the ball to do that.
          You are forgetting that you are not connected to the ball at all. Now the ball does bounce according to it's design but that has nothing to do with the 1 joule you inputted. If the ball was attached to the same mechanism you chose to raise it and it did the exact thing then yes you are staying connected and reaping the work. But you are not.
          Lets try for another analogy and see if this makes sense to you.
          We have a coil. We pulse the coil with real current. What do we get back in the form of emf? Is it the same as you put in? Whaaaa it isn't? Why? It was transformed or converted. When you create a bubble in space and it collapses what is received is pure voltage with very little current... Hmmmm... Or it is very very different then we understand. When we pulse the coil it organizes the field. This organization is current heavy meaning that we are supplying the charges to make the field stronger. On the other hand the natural field or environment is pretty disorganized and not so many charges are there in abundance when compared to our well organized and charge filled supply. What we get back from that field is much different because the charges are not organized and are free flowing. But there is a second half to this natural supply as is in our supply and that is voltage. You ever heard of voltage leads current? thats because it takes some time for the charges to gain the momentum to move if we supply the voltage for an extended time to get it moving. Once moving it self organizes it's path and is attracted to the voltage potential we provide through that organization of the medium.
          Now when looking at the pulse we get back it is no where near the time to attract real charges into our coil. The potential that forms from the bemf pulse is very very short in time. Way shorter then would be needed to start a flow of the real charges in the environment around our coil tword that potential. The potential being the difference of the coils ends. One being very positive and one being very negative from the resulting bemf rushing into the coil from the environment.
          What if we could maintain the potential or difference of the coil and figure out a way to tap or intercept the charges before it got to that coil. The flow of charges I bet would be so high that streamers would be seen going to the tap or interceptor. This is an environmental reaction of the charges effect as it travels through the medium.
          Lets say a tube diode was used because if I am correct the current or real charges would be dense. Since normal means would burn up we need a better capability to separate the charges from the environment when splitting the charges from the voltage potential. Tubes are great for that because they get rid of the environmental losses through a vacuum. Meaning it has less to interact with and can be guided with safety of the components with out interacting with air or other gases as it gets separated.
          Now as in the real world if one adds depth to a river it has the ability to channel more away from the source. We need to uncover a spring or something to make the flow never ending or resupply what we take if it has limited ability to do so itself. Well thats a cycle and if we go beyond that cycle it will dry up the lake feeding the river. In this case it is a little different then my example. We have a source and we separate that source from the flow. We still need to maintain that source but not as much if the river was still connected.
          This is where is gets mighty different then the example in nature but it has the same effect. We found out that the in of charges of a new cycle were being attracted through our diode. we must now have an out. The original cycle of the lake is through any source of water reaching it. Rain, springs that we added and that maintains the source. but it also radiates water in a cycle. So we can look at it like a resupplying source. The river is a tap of that source and when the condition of that whole system are just right it will last a pretty long time from an already self sufficient source. The out must include the harness or load and the outlet. If we arrange the outlet just right it will create a flow between the inlet and outlet and become self sufficient once a flow is established. So we use one cycle to drive another, all using the environment and our system. The environment has always been the supply of free charges. It is the lake that we live in. The sea of motion.
          You want to argue semantic thats fine but the example you gave for that arguement is flawed. It neither describes what cop is or even includes all the variables of the environment. Cop wasn't designed to describe open systems like generating from an already established flow because the input you do not supply.
          Lets look at the analogy of the lake again and see what effects or costs are associated with it flow. Since we added more supply by uncovering a spring we have changed the dynamics of that source if we did not balance that alteration by increasing the streams ability to handle the increased flow it would have changed the whole ecology of that established flow or cycle. For miles it would change the environment and destroy wild life and change the whole ecology to get what we want. This is the case for man. Why spend more to make the miles away ecology which is closely tied to that flow not effected by deepening the channel which carries our increased flow. Heck why not just make a dam but that shifts the damage to the lakes environment.
          This is what man does. All for the sake of a few dollars. Massive changes in the ecology like that can make a few species move or even die out. Why? Because they don't care about that, all they care about is the potential to make money.
          • here is an interesting read...
            Quote "Actually, all electromagnetic devices are drawing energy from the
            vacuum (whether the engineers recognize it or not), but that ability is severely limited by the use of symmetric circuits and loading (as prescribed by the revised Maxwell equations) which cancel out much of the source energy."
            The reference:
            • @Jbigness
              This is the kind of goof-ball response that is completely ridiculous and is
              100% proof that you are either not willing or able to comprehend anything
              I said. Or, you have some other agenda to post this garbage in order
              to disrupt a real conversation. Only a fool will fall for this. You obviously
              cannot be taken seriously in an manner whatsoever and I hope that nobody
              does.
              Compressing the ball is the same as a spring being compressed and as I
              said
              , that is creating a potential difference. It will then rebound, which IS
              what it means to return to it's original shape. You obviously choose to
              ignore anything that I actually did say.
              Again, to infer that I said something as stupid as what you are claiming
              is so pathetically laughable that I'm at a loss for words and you obviously
              have no idea what COP is even a ratio of - originally intended for heat
              systems, it is a proper ratio between all the output work compared to
              what we had to pay for. That takes about a 5th graders level of math
              in order to divide those two numbers.
              That is fine, it goes to show that you blatantly refuse to read anything
              I wrote and is a complete waste of time to have any meaning discussion
              with you.
              Please don't reply to me or make any more reference to me as you are
              completely dedicated to twisting my words and misleading people by
              making false claims about what I said.
              • Latest PDF Update for This Thread
                I have attached the latest PDF update of this thread.
                  does.
                  with you.
                  Not that I didn't see that coming Aaron the post I did above is in support that you are not including all the input and are not understanding that the flow that is already there is not associated with you in the least bit. It has a lot to do with the ball which is a converter of that momentum as it hits the ground. If you somehow figured out how to include the ball in your "system", which it is not, then you might be able to claim there is a cop to that "System" COp is directly related to the system you are trying to compare it to a likewise "system"
                  I also refer you to the definition in which it was intended to compare:
                  The coefficient of performance, or COP (sometimes CP), of a heat pump is the ratio of the output heat to the supplied work.
                  You have transposed the ratio and expect it to say the same thing. You have also changed the terms and expect it to mean the same. Obviously when confronted with this you think I am personally attacking you and I am not But you love to insult me don't you. A little holy then though wouldn't you think?
                  And here is where this comes from:
                  Coefficient of performance - encyclopedia article about Coefficient of performance.
                  These definitions are very very specific as to what it is to define and thats the ratio of the output heat when compared to the input of work. Since these type of heating or cooling devices operate on a motion of the fluid inside of a tube it takes a force to move that fluid and pressure as well to get a desired output of heat from that same process to be radiated from the same tubes.
                  If one was to look at the system of a heat pump one would come to the conclusion that it is a overunity device and I assure you it is not. That input comes from somewhere else and just because you think you caused that energy to form you have very little to do with that other then provide a channel for it to interact with your system if that was the case in the falling ball example you defend so dearly.
                  The only one who is trying to deceive people or appear to do so is you in my honest opinion. I have merely tried to show you that you are not including all the inputs to that example and then say hey i get more then i personally inputed. Really.. You omit things because we can not currently explain what gravity is and how it operates then say it appears that its output is more then the input which you fail to include the extra input in your computations which I will include for you now as the term (x). So any extra work you perceive actually needs +(x) to the input which should make no more output then is in.
                  • stop wasting people's time
                    Saying the ball is not part of the system is exactly saying a motor is not
                    part of the system that a battery is supplying potential to. Battery is
                    our lift (input potential) and the ball is the device that does the work.
                    Only a mindless imbecile would believe such nonsense that you are
                    spewing here.
                    You need to go do some basic homework before you waste anyone else's
                    time with your childish prattle.
                      spewing here.
                      What connections do you have to the ball my friend? what connection do you have to the output in your case? In your case you have admitted that the input you do provide does not affect the ball in any way. Then you magically claim the output as yours.
                      As in the case of the potential of the battery it is connected to our motor through wires. What are you connecting to the ball? Your thoughts? The only one being childish is you. That is evident by the insults you are slinging. I provided references to my conclusions and they support my arguement not yours.
                      I again refer to the Doctor Fred B. Wood:
                      "The major barrier to overunity electromagnetic energy technologies is the perception that such
                      technologies are not possible physically, that one cannot get more energy out than is put into a device, and
                      that such technologies are akin to so-called perpetual motion machines. None of these perceptions are
                      scientifically valid, but serve as a barrier nonetheless. As noted, overunity only applies to traditional
                      sources of energy inputs and outputs. Conservation of energy is preserved, because the energy input
                      drawn from the active physical vacuum equals the energy output of the devices (less any small losses
                      within the device). Overunity electromagnetic energy devices do not get more energy out than is put in,
                      when including the energy drawn from the active physical vacuum, and are not perpetual motion
                      machines in the sense that a continuous flow of energy from the active physical vacuum is required."
                      • please Aaron
                        Thank you Lamare for starting nice talk so I join after reading many posts!
                        Aaron you mention pendulum but pendulum is different formula from lifting a ball. Doesn't matter because same end result. Pendulums do more work than needed to start it. Is everyone blind? Your explanation makes me lose sleep because you make more sense than anyone else I read like in complete different category! I read Tom Bearden long time but difficult to make sense. Now make sense after reading your posts. Please keep posting more and stop wasting time with jbignes5. You know better. He has attention deficit disorder and can't focus on anything you write. He waste everyone's time and is out of his league.
                        I can't click on the smiley pictures. I click but nothing happens.
                        Lamare, you have the fire like Aaron keep up the good work brother! I have hard time following your explanation but I try.
                        Pentarbe is like fire too with infinite "COP". Can anyone guess what it is? Maybe I start new forum on it to help people understand.
                        • It only takes one word from Lamare...
                          If lamare thinks I am being anything but sincere in what I am saying then it is his ability to ask me to leave this thread. For which I would do promptly. When we were having a discussion about the subject of this thread it was very on topic.
                          So Lamare it's up to you friend. What you say is my command when dealing with your thread.
                          • Originally posted by Jbignes5 View Post
                            What can I say? I have seen so many things the last couple of years that I didn't understand at first and even thought were full of B.S. Like for example those channelings that talk about "raising the frequency" and such and so dimension or density. One of the most difficult things on this planet is that people use different words to say what they mean. What I see here, for example, in the discussion about potential is that not everyone means the same thing with the same word. And that gets into a useless yes/no discussion, which is the same kind of discussion that makes that our community is being rejected by the scientific community. Take for example Joseph Newmann. He has written a big book, which I'm sure does contain a lot of good points if only you are prepared to try to look at what he writes trough his eyes. What does he mean with his words and how does that fit in with your useage of words that describe the same things?
                            You know, it's about the content and about the principles people are trying to share here and one way or the other we all have to try to understand what people are talking about instead of trying to force our own opinions upon someone else. Your truth is not my truth and we have all been given the freedom to chose what our truth is like.
                            So, what I try to do is read trough whatever someone writes and see wether or not it makes sense to me or not. Some things I just don't get, so I just leave them for now. Maybe later I understand them, maybe not. And maybe someone else understands it and makes a point, so I can connect things and understand them later.
                            That way I try to learn as much as possible from what is being said here. And make no mistake: there has not been one person on this planet yet that has been right all the time. So, there's always something to learn for everyone who is willing to....
                            And I am very curious how this flame war turns out. I'll be just watching and see who learns what.
                            • Lamare
                              Seeing as how you have a duke aroo goin on.
                              something came up today that you [and all]should see
                              Post 1435
                              Chet
                              BE that change !!
                              • Ok.
                                Really as you said my thoughts on this and where I have formed them thoughts are from what I have learned from my research and limited experimentation in this area.
                                Although I believe Aaron is well versed in some of the areas that I have extensive research in. Albeit most of the areas that Aaron has versed himself in ,Gray and the likes, these guys are all based off the original work of Tesla.
                                here is the reference:
                                John Bedinis' EV Gray power conversion tube - 06/05/01
                                I doubt they know the way that I suspect is the reason for the tube which turns out to be much different then what they come to but it is only the direction of the "electron flow".
                                If one puts a substantial potential on the "antenna" it would attract charges to flow into vanes(corona) or follow the formation of the dielectric medium to the source. These are the highways that get formed and originally Tesla figured out that if a potential could attract the dielectric medium to form these roads then there would be a portion of the charges that go through the grid on its way twords the source or potential and could be stripped and conducted away from the source.
                                I really am now understanding the method that Tesla used eventually. Seeing that in his first attempt at looking at this event he used outward pulses. Those pulses were of course unidirectional and only went out. Well if one could affect the medium in an outward method then why not in an inward method. An inward direction would do more to focus the charges and make them more dense and better capable of higher charge collection with an increased ability to handle those charges. This means he both draws the dielectric medium and charges to become denser to better handle the increased load.
                                Take a good read of the responses that Peter and Bedini are referenced to and Talk about the circuit. They see the tube as being a layden jar. Hmmm... curious....
                                As for the flame war I'm over it already. I said my peace and now onto better topics.
