Hello, I’m for the most part new to a lot of this, though I have been toying with the subject of magnetic generators on an off for a bit. I was watching a few videos on YouTube and was introduced to the Bedini Motor, particularly the Bedini/Davro setup. As one can imagine I was quite intrigued by the idea and also completely baffled as I know next to nothing of electronics and a wiring schematic resembles what I would imagine a highly encrypted alien message to look like. I did a lot of research on the circuit and also started learning how to read schematics which helps a lot, and went on to buying the materials needed.
Today I began to wrap my coil. The possible problem that I am having though is when I hook just the coil up to a 9v it is not really creating a magnetic field (also tried on a 12v). Now, because I am interested in the Davro setup I will be using a neodymium sphere which in turn would magnetize whatever I use for a core (from my limited understanding), so I am using a aircore. I understand that an aircore will more than likely dramatically reduce the coils strength but, I wouldn’t imagine it doing it to such an extent.
I am using 18 gauge enamel coated magnet wire for both the power and trigger as I really didn’t have the money to buy an entire other spool to make the trigger much smaller. Could this be my problem? I really do not understand how different gauges will affect everything as I couldn’t seem to find any information on the subject other than vague references. While it was hooked up I placed a n52 neodymium disk 1/2in diameter and 1/8in thick with roughly the pull force of 7 to 8lbs next to the coil and it wouldn’t attract that well except for at one end of the coil but, even that was a bit weak. I read somewhere if using the same gauge for both the power and trigger to use 250g per wire which is around 1/2lb. The 18 gauge wire is roughly 200ft per pound so I used 2 wires of 100ft each (not sure of the coil count)
I am going to rewrap the coil as I must have done something wrong but, have a few questions before I do. Is it best to run them in parallel or twist them together? I have read both but, never heard of one method preferred over the other. And since I have the 18 gauge wire, is 9v enough to create the effect needed? And finally since this is my first bifilar coil does it really matter the gauge of the wire used for the trigger as I have found some wire I bought from RadioShack ages ago which contains 200 feet of 30 gauge wire which is the only spool long enough to match the 18 gauge in length.
Sorry for the lengthy post and thank you in advance for any advise you may be able to offer on the matter.
