time potential
Hi David,
It has been a very long time that the "authoritarian establishment" has
been proactively working at squashing what they wrongfully group under
"perpetual motion", etc... even though perpetual motion is not only
possible it is happening all around us.
The opinion of conservation of energy may be based on an empirical
observation but it is still founded on the premise of a
casual abstract and usage of the term potential, which they never even
understood as being an actual "substance."
They say in isolated or closed systems but conservation of energy
technically does not even exist in a closed system either. A flashlight
turned on is a closed system - yes it is open to gravity, etc... but for
the practical mechanics of it, it is a closed system. The battery breaks
the symmetry of the aether, the aether is polarized and condensed at the
terminals of the battery and since the loop is closed, that condensed and
polarized aetheric source potential flows over the wire and as resistances
occur, the potential is disorganized and dissipated right back to "vacuum"
space - right back to the aether. There isn't other input into the system
other than the potential difference established at the dipole from the
beginning. So it is a closed system but the potential comes into the system
at the dipole's terminals and dissipates right back out of the circuit
from where it came. There is no conservation of "energy" happening here.
Even Mendeleev had "elements" smaller than hydrogen but that was all
covered up. The Michelson-Morley experiment has been disproved by
multiple scientists over the years.
The only thing I can see coming close to being conserved in any of these
systems is TIME.
For example, pure potential is the potential for time to exist but not yet
existing. If there was a section of space with the density of aether
approaching infinite density, there would be no time ticking according to
my model because the density is so dense all motion is resisted, the aether
supplies the potential to a light "wave" but is so dense light cannot
propagate, protons in the mass encounter an approaching infinite
resistance, etc... so basically the flow of time approaches a standstill.
At infinite density, there is absolute equilibrium with no potential differences
and therefore, there is not time (not a thing but a periodic measurement
of movement through the aether). There is infinite TIME POTENTIAL...or
the potential for time to be measured. If someone was in that region,
if they could still physically exist, they would be frozen in an infinite moment but
could not tell but from an outside observer it would look as if everything is
still.
If the region of space had low density aether, there is a corresponding
reduction in the resistance to movement of mass thru the aether and
that faster absolute movement from an outside perspective is that time
is ticking quite quickly. To the observer in that space, it appears normal
to them from the outside, look to be at a certain speed that could
appear to be faster or slower.
In a magnetic coil, potential stimulates the current by attracting electrons
towards the positive terminal. So, we can measure WORK into the system
over a certain period of TIME.
When the coil switches off, all the input is dissipated and new potential
enters the system. Anyway, when we get a super high voltage potential
spike, it is narrow because all the TIME is locked up or conserved as
the potential itself. The pulse is narrow (no time) it is potential and not
work. The ability for TIME to flow is locked up in that high pressure
aetheric potential. It is high pressure or density of aether.
If we take that potential for time to exist and use it to create a
separation of "charges" on a capacitor, the capacitor will show a voltage
or potential difference. If that capacitor is put to a light bulb, it lights.
The separation of potential difference at the capacitor's terminals breaks
the symmetry of the aether, it flows in, the pressure greatly drops, resistance to
movement drops and time can flow meaning that there is an actual
pulse width to this pulse of the cap to the bulb. When the high pressure
aether or high voltage is reduced in such a manner, time can flow meaning
motion and resistance can happen and current manifests.
The notion of what time is has always been wrong as well, of course in
my belief but look at the obvious nature of it. It isn't a mysterious concept
of a 4th dimension, etc... or other complex thing like that. In simplest
terms of looking at it for the sake of seeing it's nature for what it is, it
is a periodic measurement of motion/resistance of mass through aether
from a local point of view which always seems fairly constant but an
outside observer from an omnipotent viewpoint can see slower and faster
depending on the density of aether in each respective region of space.
Long ago, Bedini discussed TIME CHARGE, TIME POTENTIAL, etc... but
most people didn't realize it is literally TIME POTENTIAL (radiant spike)
and the machines are time machines that charge batteries or more
accurately, separate the charges in the battery using the potential for
time to exist. You hook a load to the battery, and you get work over a
certain period of time. Basically, you get the TIME back out of the POTENTIAL as evidenced by the pulse width.
Anyway, wave a displacement of a particle is an interesting perspective - have to
ponder that one.
systems is TIME.
still.
ponder that one.
(See:
. So the material itself need not have substance to have mass. All that is needed is a property to displace space and keep it outside of the interior. Imagine an air bubble forms in the ocean bottom and displaces the water around it. Now imagine the surface of the bubble is frozen solid and the interior evacuated and you have a close approximation of a 2d surface enclosing a 3D sphere with nothing in the middle.
