Plasma propulsion / Lifter / EM Antigravity Mini AirCraft
  • #76
    thank you harvey, very kind of yours! you seem to know everything...
    Light, I Am!
    • #77
      here it is, how i will power my lifter:
      YouTube - COLD ENERGY
      special thanks to harvey, xee2 and mrmagamp! and to all others
      Light, I Am!
      • #78
        Nice demonstration =)
        There is a lot of energy being radiated in that Blue Light
        Also, it would be really kewl to have a thermometer in that water to show that no heat is being produced by the bulb . A good test would be to have several calories worth of energy consumed by the lamp with no calories increase in the water
        • #79
          yes sir. as you wish! i will make the temperature test!!
          thank you harvey
          Light, I Am!
          • #80
            good work man! tell us about the lifter result. What are you going to try? Bushman's method or TT Brown's?
            You can try with a lot of energy sources, here I include some:
            1) High Voltage Direct Current (pulsed and continuous)
            2) Alternating Current (high and low frequency, at low and high power)
            3) Radiant energy
            4) Backward EMF
            • #81
              im going on the Browns effect and plasma propulsion... anyone can help with tripler?? or maybe i should just rise the input voltage to get the 30.000V output?
              bushman effect is not viable solution, because im not seeing humanity doing aluminium highways so the coils crafts can levitate in them, besides the coil will get very hot in a short period, and the consumption is to high!
              please explain that of the input sources better!
              Light, I Am!
              • #82
                If you use electromagnetic energy, you need to raise the voltage while maintaining a required level of current, but I don't know the exact value. This is what I've heard.
                Bushman clearly explains that his own configuration must be changed in order to repel against the earth surface instead of a small conductor. He says that you need to change the voltage and the frequency. He only demonstrates that it's possible to create an effect similar to an antigravity device using a very simple design (the coil and the AC electricity of your home). But he also says that the configuration won't work fine. You need to make some adjustments, but he only says that you need to change the voltage and the frequency, and also that his system is very similar to the Tesla's system for transmitting electricity throught the surface of the earth.
                A friend told me some time ago, that changing the configuration he reduced the weight of the coil, but he doesn't achieve a complete levitation. He wasn't using the aluminum plate.
                • #83
                  Most flybacks for TVs made in the last 10 years will put out 30 KV without using a tripler. You can get an approximate voltage value by measuring the maximum spark gap distance.
                  • #84
                    naice xee!
                    so with 30Kv i should get a spark 3 times more far that with 10kv?
                    the flyback im using puts out DC and im running it on 12V... so IM assuming it haves a diode and im only getting half the voltage output!
                    i have a big one from an old tv (that had maybe 15years) and i think it puts out AC, and maybe will put out the 30KV, but dont work as well as the first one with 12V source... very weak spark!
                    but the lifter will not work with AC, so i have to think better how to figure this out... i was thinking on a voltage doubler/tripler circuit with caps and diodes, anyone know some?
                    Light, I Am!
                    • #85
                      You can find spark distances in P E-55 61st edition of
                      Handbook of Physics & Chemistry. Partial list below
                      (approximate dry air, varies with humidity - pointed gap electrodes)
                      KV > gap(in)
                      5 > 0.42
                      10 > 0.85
                      20 > 1.75
                      40 > 3.81
                      • #86
                        Most flybacks have internal diodes and produce pulsed DC. Lifters work OK with pulsed DC.
                        • #87
                          You can check to see if there are diodes in your flyback by putting a battery and a flashlight bulb in series with the output coil. If the bulb lights with the battery one way and not the other then you have diodes. HV diodes are usually a string of low voltage diodes in series, thus the the forward voltage drop is the sum of the voltage drops of all of the diodes. Therefoe it may take 12 volts or more to get the diodes to conduct. But if there are no diodes a 1.5 volt battery should light bulb in either direction. If there are no diodes you can just measure the ohms both ways with an ohm meter and you should get the same reading both ways.
                          • #88
                            Hyper Morse Code
                            Liquid helium, superfluidity
                            Faster-than-light - Wikipedia, the free encyclopedia
                            Morse code - Wikipedia, the free encyclopedia
                            • #89
                              @all
                              Hi i was wondering if Lidmotor's circuit would be enough to drop a lifter.
                              YouTube - Lidmotor's Channel
                              • #90
                                hello mk1,
                                i think the setup you mention will not be strong enough to lift even a small lifter!
                                but maybe will be good enough to act as a small motor turbine to move the lifter forward (by lifting it with browns effect), because then there is no friction and the plasma is not required to do so much force, its like when you lift someone in a pool, it is much easyer!
                                but i think its possible to lift with plasma, maybe you will need a flyback transformer, and output voltages arround 40/50KV, in this case you dont need the ground near the output, for it to spit a big strong plasma flame!
                                the problem then will be to stabilize the spacecraft!
                                Light, I Am!
