I believe I have come up with a new type of perpetual energy production.
My idea is using ocean water pressure. The deeper you go into the ocean the higher the water pressure. My idea is quite simple. Put a tube or pipe inside of another pipe in order to keep the inside pipes surface pressure the same as the surface pressure.
I image you would have to anchor the pipe to the ocean floor because it will want to float.
The purpose of the inside pipe is, it is to be opened at an optimal depth. When the inside pipe is opened the water will rush up the pipe much like an when oil was struck in early versions of oil drills. If a hydro-turbine is put a the surface of the pipe the gushing water can be used to create electricity.
Does this make sense?
How am I wrong? or am I correct?
Really.
I am next to clueless if this is actually a possibility.
Really.
