SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
  • Originally posted by Guntis View Post
    i'm Latvian from Latvia, but i also know Russian
    i personaly don't know SR aka SpaceReason or SReason i just know his real name and some his forum friends. (i know more info too but i don't post or tell anymore about it, because i have great friend relationship with these peoples and they are very great peoples i have deep respect)
    in core is only inductor coil, the black marked first HV coil on its core are mark where is weak HV field and this part is for modulating coil other part is for output coil.
    there is sinus signal about 50 Hz with 21 KHz modulation and transistors are made only on Amplifier principle for very specific reason "Emmiter Follower"
    P.S. Modulation are strongly in Square wave from HV part
    (anyway don't be messed up with information what i provide, because Tariel Device about what i talking is totaly different Philosophy, but the fundamental principle are the same)
    You know what pisses me off Cosmo? You say the same things I say. I'm the one that came up with the Kapanadze magnetic oxygen claim at overunity and that SR is NMR. What you have been up to with your games detracts from that credibility.
    The SR modulator circuit is unreadable for capacitor values. I built it on a NTE40106B hex inverter and by moving one leg of capacitor C20 to ground instead of across pin 1 and 2, it produced burst packets of about 8 packets positive and then 8 pulses negative. That is not a modulated signal and so the schematic is wrong or not complete enough to replicate.
    I have some pretty advanced equipment to work with and it is not my first day on the job with a with a scope and a arbitrary function generator.
    So here is your chance to gain some credibility. Post a schematic of just the modulator and I will have it replicated in a day if it is correct. Otherwise, you are the one with the ego problem who likes to dangle candy over peoples heads. People are not dying for ego as you claim. They are being murdered for their oil and to reduce population on behalf of the Israelis that control the western world through the banks they control..
    • The wiring of the copper pipe
      In this block diagram the load is drawn attached to the copper pipe in an asymmetric fashion. On the right the line goes to the center of the copper pipe but on the left it goes to the circumference. Do you know if this relates in some way to the physical construction of the transformer? Thank-you for explaining what you know about this.
      • My questions answered
        Hi Guntis, Thank you for clearing this up for me anyway. BTW I think your English is fine. I know how hard it can be to speak or write in some other places in the world and get your point across. I now understand more about the current situation and good luck to you and your friends future work . Steve220
        One thing to keep in mind is, man wrote the laws regarding the conservation of energy, not nature.
        Nature writes it's own laws regardless of what man thinks or does.
        • Originally posted by wayne.ct View Post
          You are wrong about the symmetry. An asymmetric circuit would have one side of the load attached to earth ground and the other side attached to a pick up coil like SR drew in his schematic and Kapanadze drew in his patent. This symmetry breaking technique appears to be one of the things they are trying to "re-define" and bury. Tesla, SR, Kapanadze all the way up to Stiffler used it. Is that your game?
          Note how Cosmo's circuit does NOT break symmetry? He claims it is a SR replication and has pumped out 50 different schematics?
          This is poisoning the well IMO. Feel free to prove me wrong Cosmo. It would take me a day and I have everything needed on the bench.
          Don't hold your breath, it isn't going to happen.
            On the SR schematic that VidBid and SR posted, the transistors to drive the modulator coils were KT829A and it's PNP compliment. Now look at the fMax for that transistor (a darlington power transistor BTW)
            KT829A Transistor Datasheet. Parameters and Characteristics.
            Material of transistor: Si
            Structure of transistor: npn
            Maximum collector power dissipation (Pc): 60W
            Maximum collector-base voltage (Ucb): 100V
            Maximum collector-emitter voltage (Uce): -
            Maximum emitter-base voltage (Ueb): 5V
            Maximum collector current (Ic max): 8A
            Maximum junction temperature (Tj): 150�C
            <b>Transition frequency (ft): 4MHz</b>
            Collector capacitance (Cc), Pf: -
            Forward current transfer ratio (hFE), min/max: 750MIN
            Manufacturer of KT829A transistor: RUSSIA
            Case of KT829A transistor:
            Application of KT829A transistor: Darlington, Power
            I doubt that you will hit 21MHZ sidebands with a 200K heterodyne off the flyback (good luck switching your flyback at that speed) and a 21KHZ sine.
            Spinning you round and round?
            • Originally posted by dom44 View Post
              this might help!
              What's the frequency on the flyback?
              EDIT
              In the image posted by wayne.ct and created by Guntis / Cosmo's umbrellatech, you see a flyback frequency of 200 KHZ. (not realistic BTW)
              In his post previous to that, he claims it is 21 KHZ (realistic) . See how his story and schematics keep changing? This has been going on for many months.
              That is hardly a workable class B amp. You would get massive crossover distortion without an op amp producing the sine wave regardless of frequency and probably burn up your transistors.
              21KHZ is only 1000 octaves away from the Fe56 > Fe54 NMR frequency of 21 MHZ - also not realistic IMO. And then without a HV cold electricity circuit in there it gets even less realistic. Maybe that is why it didn't work for me huh?
              • More plausible
                More plausible
                • Wondering
                  Originally posted by Dr Poppy View Post
                  More plausible
                  Is the copper pipe for the gas? Is this how the gas is activated similar to a Neon tube? Just wondering.
                  • Originally posted by Steve220 View Post
                    No, it is called a quarter wave or 1 turn transformer.
                    If you have the right ferrites and you run two wires through the center, one wire is a resonant driver sine wave and the other is the pick up wire, you will get an almost 100% transfer of energy to the pick up wire.
                    The transfer is not the result of inductance, it is the result of displacement current or lentz force. If there is any resistance on the river side, you won't get any transfer of energy. The sharper the pulse, the better.
                    It's interesting and I had no idea you could do that until I started this project. I learn new things from my failures too.
                    For example:
                    YouTube - Strange Russian special transformer 1/2
                    • Interesting
                      For example:
                      I watched the video and can see how this works. I can't understand what they are saying, but it did show how it worked. I too did not know this. It is kind of like circulating currents in a transformer core, but with a copper pipe. I think he used a drill bit also with the same results, so it don't have to be magnetic. I do understand Faradays and Lenz law. However, I learn something new every day.
                      • My Post from June 25, 2010 about the Device's Push Pull Amp
                        From my post #407 on 06-25-2010, 05:32 AM in my smith kanapadz replication.
                        I missed that one small detail. Now that it is updated. I can move on.
                        It took me a while looking at SR193 to see how the push-pull amplifier on the device was actually wired.
                        VIDBID
                        • Originally posted by Dr Poppy View Post
                          • Coil Construction
                            Thank-you, Dr. Poppy, for your multiple posts in reply. I only seek information so my replication and experiment has the best chance of success. Umbrella is broken.
                            Multiple threads, elsewhere, describe the Kapanadze coil construction. Are they reasonably accurate? Are there errors of which I need to be aware? Thank-you for your thoughts on this.
                            • Hi Guntis! you mean propably Eddy currents and ionisation. BTV ozone(trioxygen) is bad your healt, but negative ion is not.Sorry my english.
                              • I thought?
                                Hi Guntis, I see what you are saying, but I thought that liquid Oxygen was magnetic, however Oxygen as a gas is not. Somewhere on You Tube there is a video showing this action between poles of a magnet. No one seems to know why this is so. I will look for the ionized magnetic reaction from two magnetic fields and see if I can learn something new. Thanks. BTW, your English is fine, I understand it ok.
