Yes Gyula
i mean 20 to 40 ohms per coil
so if i get an average of let's say 30 ohm per coil. So i make the following math
U= RxI that is 200volts = (18 x 30 ) x I or 200 devided by 540 = 370 ma
or200 volt s X 0.370 = 74 watts
My procedure is the following, as i don't know the possibilities of the 18 coils , i do the test on 1 single coil. So i consider that i will have more than 220volts in the final proto. So 220volts divided by 18 gives about 12 volts per coil.
So now i am testing the power on a single coil under 12 volts and i can feel in my hand the different force depending of the wiring and magnets etc.. very simple and practical way. And than i imagine the torque that will produce the all 18 coils sandwicthed together and my aim is to get not too much torque because my setting is probably not able to sustain enormous torque at the present . So i have a fiable working system to make the measurement of the IN. (ian-newmann) multiplyer.
See what Tyson sayd in his previous test , those neomag are capable of incredible power and can deform everything if not properly dimensionned.
Please i will apreciate your comments
good night
Thank's and goog luck at all
Laurent
good night
Laurent
