my smith kanapadz replication
  • Length of the Wire
    I did forget about it, but i think too,
    that the turns from the Coils are importend, and little less the lenght.
    But it maybe dont hurts to try to get both the same, lenght and matching Numbers of turns.
    • Are you planning to build one? if you do, would you mind email me what you did or did not encountered any problem, I will do likewise.
      • Yes, i do plan to build something like it.
        I can email you some details when you want it.
        Right now i try to find a way to make HV from a Dc Source.
        I can get 2000V with a irf840 right now, but pulsed, so it is no AC HV.
        But it works to feed it into a Ferritcore with 2 short Coils with thick wire,
        and make a 5W Bulb to light.
        • That is great Joit, send me anything you have, I can learn a lot from you, either send it through this forum or private email if you like.
          • I have been experimenting with using a heavy "spring style" inductor, of no core, probably 6 ga. wire, coiled in a spring. This sits inside a 1" pipe. About 5-7 turns. On the outside of the pipe I have about 150 turns of 18 gauge. I then have a cardboard tube that sits over top the whole works, snugly, with about 2000 turns of 26 gauge wire. It's a modified slayer circuit using an MJ802. (30a/100volts/200 watts)
            • kcarring
              I dont think it works well, when you have your HV Coils with the Primary and Secondary Coils.
              I still found more Material where it says Resonance and impedance must match, and are critical, even like the Lenght and weight of the Wire from both Coils.
              I will post it later.
              Still not that simple, if you dont follow few Rules.
              • From the Picture above in this Link, we may been wrong to assume, there are 2 Tubes.
                The bigger one is mounted on the PVC Tube with something like Collars.
                The inner Tube is moveable, and has thicker Wire as the outer Coils,
                but they pretty (exactly) match in Weight of the Wire, and the Lenght from L1 is a quarter (1/4) from L2.
                Thats why he mentioned, that it is a tesla Coil System.
                L2 is only in the middle 4 Turns unwound, somewhere i did read, that L2 is connected across, but at the Picture it shows, that they are both connected at the middle for another Phase(?).
                Look for the Schematic 'Don Smith Device 3' in the following Doc.
                I cannot copy the Part out from this Document, you have to scroll down and look for it.
                Its at 3/4 at the Line, "One Part which Don stresses..."
                So, for to build it, you need a Driver Coil (L1) with the same Weight of L2,
                but thicker Wire.
                It seems for me at the Moment, the Turns of L1 are not to critical since it works like a Divider for the generated Voltage.
                For now, i got a cardboard tube with equal thick Wires, L1 with 5 Turns, L2 with 2x18.
                driven from my Coil shown in my other Video, where i can generate HV.
                At all, i could get at L2 the same Voltage what L1 did support without Diodes.
                Just no Amperage, and without Diodes.
                May thats why they are in, to block the Back Current and why my smallest driver Coil now did burn and have a Short,
                even when it did not goes very hot, but i think it been the Sparks anywhere, and the isolation was damaged.
                I have to rewind it, and change L1 & L2 to different Wires but same Weight and L1 to a quarter Lenght of L2, and may try to adjust them with a Capacitor.
                For Diodes i still have some By255 or 1N5408 Diodes left, what i connect in Serie.
                They are rated for 1300V or 1000V, and there are even other HV Diodes like BY4 or BY16 rated for 4000 or 16 000V. I am only not sure if they are usefull to forward little amperage like 20-60mA without big losses.
                Btw this did happen, as i connected my Diy adjustable Cap to L2.
                • Thanks Joit, for guiding me into this, I think you meant page 3-25 instead of 3-4, I read it through but I am going to read it over again in regard of the turn winding and the lenght of the wire for L1 and L2 coils, I am short of wire right now perhap by next week I should have all the wires I need.
                  He mentioned that if you positioned the primary coil L1 (slide in) the middle of L2 then you will generate an amperage as large as the voltage wow!! this is something I never knew before. he didn't mentioned whether L1 has CCW or CW?
                  I still got confuse how he calculated the wire lenght for example 1/4 wavelenght divide by 247 by the frequency in Mhz, I will get back to you again on this matter when I am ready to rewire my L1 and L2 after I got all my wiring, I believe the wiring I need is 10 AWG and 12 AWG, the #10 is for the L1 and #12 is for the L2, he also mentioned the L2 was wound with a spacing and that will gave a better magnetic field.
                  • My bad, Wrong Link!.
                    Thats the right one, i will replace it also in the previous Post
                    • SR Device Replication ?
                      Looks like a working replication of the SR device.
                      YouTube - РЕПЛИКА СР.wmv
                      • It will be nice if some one in this forum can figure out the wiring diagram of this SR replication and share it with us.
                        • vidbid did explain it allready at Post #58
                          For the Wires at Don Smith, it seems for me more, that L1 is #10, but L2 is thinner like AWG #18.
                          For the Frequency i would have to look at the Doc too, but i use a 555 timer Circuit, a regular Transformer, what i pulse, can make HV at low Ah with it, and can play with certain Frequencys and Duty cycle. I dont worry to miss there something, because i can slowly come closer to where i want to be.
                          Its anyway not to critical to be 'close' at the right Settings, because you will see, when it what works better. The mainly Function is not like, it is only a small Range, where something work, you still have tolerances all time.
                            Is it possible that Kapanadze's work and SR193's replication are based on Czech patent #284333.
                            The original patent: http://spisy.upv.cz/Patents/FullDocu...284/284333.pdf
                            The Russian translation: http://www.001-lab.com/001lab/index.....0;attach=4112
                            English translation of Russian translation:
                            March 1976
                            CZ 284333 B6 CZ 284 333 B6
                            The method of energy production by converting Fe 56 Fe 54 were nuclear magnetic resonance equipment for the implementation of this method
                            The generator creates the effect of nuclear magnetic resonance, magnetic field and electric current to the iron nucleus 56 Fe, then part of the current obtained in the transformation of iron 54, comes back into the nucleus, while the remainder of the flow from the device, which allows you to turn off power and automated process operations before the exhaustion of Fe 56 Equipment for the implementation of the method is a generator with a core in the form of rods 12 / Z Fe 56, the structure / 1 / induction coils / 6, 7, 8, 9 / from the input source / Li /, with the necessary circuits and output . The device is equipped with a power supply circuit got back to the bar 121 Load conveniently equipped with an output current of the rod / 2 / into two parts, one of which is connected to the regulator / 14 / OFF / LI /, and the other associated with the release of the device.
                            The method of energy production by converting Fe 56 in Fe 54 nuclear magnetic resonance. Equipment for the implementation of this method
                            The invention relates to a method for production of electricity through the conversion of Fe56 Fe54 by nuclear magnetic resonance, when the effect of the magnetic field and electric current leads to the transmutation of the isotope Fe56 and electrons with energies obtained by transformation of the isotope (10?) Collected in the form of electricity. At the same time addressed a means for the application of this method as a generator with the nucleus 56 Fe
                            and so on..
                            To read more, use Google Translate to translate above Russian translation.
                            Google Translate
                            • Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
                              • Originally posted by scratchrobot View Post
                                I'm interested how we could confirm that ideas ? Fe56 into Fe54 transmutation is not described in scientific papers imho.
                                How we can prove it is "there" ?
