Spark Gaps- The missing link?
  • Spark Gaps- The missing link?
    espacenet — results view
    What he did was to use a spark gap and a LC resonant circuit to generate extra energy.
    I have an idea that by using this method it would be possible to make most of my failed projects like the Bedini free energy generator and of coarse the Tesla switch working.
    Of coarse it will take a lot more reading and experimenting with this specific circuit and the correct cap and coil values has to be determined
    If anybody has got an idea on how to construct that specific spark gap , please give some information.
    He also suggest that an interrupter on a transformer could be used to generate the signal from dc to drive the step up transformer, instead of a dc motor driving a alternator.
    That looks to me like a relay in series with a car coil primary that switch itself to produce the output frequency. The same way as I did it as a child to make a shock machine for the old copper door knobs in the school hostel to shock the teacher that came to investigate why we made such a noise!
    That nearly cause the end of my stay in the hostel.
    This below is from patent 121 561:
    Interesting indeed !
    it looks to me like the Ed Gray recovery system : a coil + a cap + a battery in series, and sharp one way high frequency pulses through a spark gap...
      The spark gap is the key. Yes. Spark or arc gaps are one way discharges. No need to pulse it further since it is the vehicle to attain one way pulses. Tesla use a magnetic arc gap to attain higher frequencies. just orient north and south attraction across the gap and walla you have the perfect pulser that depends on the spacing and magnetic strength of the two magnets around the arc space.
      The one setup I am looking into at the moment is a Teslian design.
      Let me show you.
      Treat Periods like they are not there in this example.
      ..................................N
      o-----------0--------O......O-----o(transformer)
      ..................I...............S...........
      ................Cap..........................
      ..................I............................
      o-----------0--------------------o(transformer)
      To the left is a High voltage source with very little current. It charges the cap till the break down of the arc gap is attained or the little conductors of potential get enough lined up to discharge that High voltage across the arc space. The position of the magnets when brought closer to the gap space can and will facilitate faster arcing because of the conductors are readily available from the magnets. This causes a very high voltage pulser circuit that is very very cheap to make.
      What happens on the right after the transformer is another thing. Since we are trying to create a one way flow after the transformer if one hooked and antenna as an inlet and a smaller one as an outlet one creates a separation of potentials that creates a potential falls like action flowing from the lowest to the highest potential. This movement aligns the conductors of the potential twords the higher potential and drags along any available charges that are attracted to the lines that have been lined up allowing the charges to flow into your channel you made by referencing the basic attraction of these charges to the higher potential. Where current comes from is from the local environment rushing to the higher potential of the source which would be the antenna place your load in between the hv source on one side only and you can tap the movement of these real charges.
      You must think the way Tesla did about this. Look at the Tesla switch and one will suddenly see that they can run a load on just the potential difference from only one side of the circuit creating an imbalance. It is the only logical solution to extracting movement of current without destroying the environment. The will cause an inlet and an outlet and circulate the basic forces of everything.
      The antenna is connected to the bottom of the transformer and the larger antenna is connected to the other end. All one would need to do is put the load in between the high potential (hv) + and the receiving antenna to the right of the transformer in my picture. The load will draw as much as it is capable of at maximum capacity using all the current that would be normally be radiated as heat and light as brushes on the antenna or could be explained by transforming the overage of the real charges accumulating on the antenna as a feed back from the environment into the load or redirected.
        Tesla patents, Eric Dollard books, ...
        Guys, I just received my first order from here:
        Borderland Sciences Research Catalog (Powered by CubeCart)
        For a few hundreds bucks I got an encyclopedia about Tesla and Dollard work
        In the tome 1 about Tesla patents, there is a lot about the sparking
        I think it will take me months to go through this staff, and it's just a small part of the material sold on the website !!
        Learning, learning, reading, reading, I love that
        PS: Thanks Aaron for giving the link ! Invaluable staff indeed !
