gravity waves found
  • Ok, thank you David
    • I could see the affect pretty well here too. I wonder if it's not maybe an optical illusion due to the spinning.
      Maybe put some white strips of paper on top of the vermiculit in a cross pattern so the distortion can be measured?
      • spinning visuals
        Originally posted by david lambright View Post
        YouTube - new vermiculite video check this one....david
        David,
        It is an interesting effect.
        But it only happens when I watch it spin and then you stop it,
        yes it looks like there is continued motion.
        When I put my hand over to the vermiculite as you spin in and when
        you stop I remove my hand, the effect goes away and it is perfectly
        still.
        • David, could be something, but could as well be the illusion like the shrinking head trick, here is an example:
          YouTube - Shrinking Head illusion
          Not sure yet
          • That illusion is pretty amazing. Our brains really do have a mind of their own :P
            • Originally posted by occy30 View Post
              Are you sure it's an illusion? Or should I ask, Is anything real? Just a thought.
              I made the statement in the following quotes earlier in this thread, but didn't elaborate on what this universal phenomena is. I will now give more details.
              "We should not confuse light and image, because universal phenomena take place everywhere at the same time."
              What is this universal phenomena? It's mind-boggling nobody asked this question. This universal phenomena is "Expansion Acceleration"!
              GB
              • hi
                thanks everyone for your help with this....so far, both bruce and his family, and matt and his family, have seen the optical effects of my device when it is sitting still....jetijs will be getting the device soon and hopefully he will be able to unlock more of what is going on with these devices....thanks everyone for your help...david
                • Unfortunately, at least in the video the effect is purely illusion. Just check the point where the movement stops, take a break and go directly to that part -> no movement. Still cool effect though
                  • Originally posted by jtstatic View Post
                    If you take a break, then go directly to that part, you'll miss the effect due to the universal phenomena of expansion acceleration. Take a serious hard look at that link. You just may be surprised.
                    GB
                    • Leedskalnin's device is real
                      Knocked Mr. Gardner across the room once. Made another guy's arm go numb for a day and a half.
                      Leedskalnin's trick was being able to charge the PMH's while they were closed. The shape of the field lines off of the AlNico ring magnet allowed him to accomplish this. He could keep dumping more energy into them until they exhibited quantum effects.
                      He then would use the device to exert a spacetime expansion on the matter of the stones. This would move the matter toward the state of what we would call dark energy. Similar to the principle of the Philadelphia experiment. The antigravity effect is the same effect of antigravity that dark energy contains. It is not so much a force opposite to that of gravity, but more akin to a bubble of air underwater. The less dense spacetime density (a.k.a. gravitation) exerts a buoyancy effect. The singing of the stones occurs when the surrounding matter and the expanded spacetime matter normalize to the same state of spacetime compression.
                      • a post from smokey2
                        please read this post a new kind of visible radiant energy? thanks, david
                        • 100 million times stronger than thought possible!
                          What was Ed Leedskalnin using the glass bottles for? Was he using this process in reverse to achieve magnetic effects that were 100 million times stronger than thought possible.
                          GB
                          • hi gb
                            here are my thoughts about the bottles: i think he used the bottles to separate the N and S the same way a leyden jar does. also i think they amplified this energy...there is a wire through the inside of one of the bottles, if that wire was radiating N and S, the glass separating the poles, the outside wire getting more of one than the other.......my devices radiate a visible distortion, even sitting still. Ed said this energy, magnets, flows in metal easier than air...the tricky part is getting this energy to flow in separate streams....the fact that this energy is visible, should help finding the flow and separation....my devices radiate when still, when spinning, N & S magnets are flung off...a magnet should catch more of one kind than the other....this energy flows into the metal mass above....if the device is spinning and the magnet at the side is S, N will be thrown off and caught by the magnet...when this happens, S is pushed out the center poles, to flow into the mass above...so in order for flow to occur the N & S must be separated, and there must be a circuit and a means to push the energy around this circuit.....does this make any sense?...david
                            • David,
                              I sent you a PM describing a simple experiment you can do. I hope you find it as interesting as I do.
                              GB
                              • Hi David
                                Got the device today. Unfortunately I got only the rotor part without anything underneath so I can'r test it while rotating at the moment. Will examine it more and show to everyone who will find it interesting. Also I have an apointment to some sensitives and will show it to them aswell. I will be ready to send it to the next one in line on the middle of june. BTW, who is the next one in line?
                                Thanks.
