gravity waves found
  • hi everyone...
    just a thanks to all who have been following this thread...plus a warning...smokey2 at OU suggested that the radiation that this device emits has not been evaluated as to what kind and/or strength and it does radiate...i believe.that anyone replicating these devices be mindful of these facts...i will still mail these devices to those people who were interested, just let me know if you still want me to do so......jetijs, your device is ready, i made yours with an internal coil, inside the oxide core, as well as an outside coil for charging...[i will charge it before i mail]...let me know OK......and thanks again....david...also i am posting at OU a new kind of visible radiant energy? ...david
    • Its true that we don't know many thing about the radiation emitted by PMH. But since you never report headache or such, I think it is save.
      Let just compare this with many brave joule thief replicator, they still run their circuit even if it create headache for them and never even bother to know what is going on or wether they can prevent the headache effect. Brave people ...
      • I think If Ed watched that gravity video he would probably say this.
        " We have North and South pole magnets, positive and negative electricity, protons, and electrons, positrons and mesons and alpha, beta and gamma rays. Now why such a confusion? Does nature really need so many things in the perpetual transformation of things, on building up the matter and again taking it into parts? I think all that nature needs is three things, the North and South pole magnets and the neutral particles. Each kind of those three things can act differently with different speed and different combinations, and so they can accomplish different results. I believe the prospective physicists first should learn what magnets and electricity are, then they will have a sound base for their experiments and their calculations." Ed.L
        Don't forget muons.
        Or maybe he'd say this.
        " Gravitation must be caused by the matter in the middle of the earth, and more concentrated than Uranium. When Uranium atoms burst they release the North and South pole individual magnets that held the atom together, then the magnets scatter all around, but when the atoms burst in the middle of the earth, and many burst at the same time, they can only run from the middle to the outside. When the North and South pole magnets are running alongside each other and in the same direction, they have no attraction for the other kind. They only attract if they are running one kind against the other kind. When the magnets are running out of the middle of the earth, as soon as they meet an object they attract it, on account of the fact that in any object there is both kinds of magnets in it. It can be seen by rubbing hard rubber or glass until they get hot, then they will attract sand, iron filings, salt, and other things. To see how it functions, move a salt crystal a little, if it happens to get on a different magnet pole, then it will jump away."
        "The difference between the rubber magnet and the steel magnet is that the magnet in the rubber comes from the magnets that hold together the rubber, and both North and South poles are in the same side of the rubber and the magnet poles are small and there are many of them close together, but in the steel bar the attracting magnet is not the magnet that holds together the steel, but the surplus magnets the circulating magnet that was put in it."
        Ed.L
        Then he would go away doing this
        Scotty.
        • sucahyo!
          thanks for your insight!.....there are some interesting things going on at OU!...you should check it out, if you have not already.....david
          • you are right!
            Don't forget muons.
            Ed.L
            Scotty.
            he did say that already, have you been watching whats going on at OU?...Ed showed us the way and also said something about putting the coil inside the PMH metal.....that works too!...a persistent voltage results!....david
            • Hi Sucahyo
              I made another test this night
              i put my PMH (charged with 30 volts) in the middle of a round container. with tap water
              here the result in pix
              in pix 1 the PMH is showed with the N on the left and S on the right.
              you see the small montain (white intensity) something down the pmh.
              Pix 2 is taken from the right of pix 1 and shows clearly the small montain and more thickness of ice on the left of the pix than on the right.
              pix 3 and 4 are taken as per pix 1 and shows that under the small mountain there are big air bubble, and on the opposite of the PMH the ice is almost transparent, that is to say very compact, and this almost exactly at the same point where the peak of the mountain is on the opposite side.
              So is it possible that the PMH creates a difference in density on his sides ?
              What is happening accros the 2 poles ?
              I will redo a test with the PMH something above the ground of the round container to see what happen under the PMH, i mean if there is a circulation.
              OK waiting for your comments
              good luck at all
              Laurent
              • David, check your PM!
                • hi all
                  results from today experiment with pmh
                  Pix 1 and 2 the pmh is about 1 cm above the ground of the round container layed on a plastic bloc.
                  pix 3,4 and 5 the pmh is layed on the ground of a less deep container with of course less water .
                  Notice the corona of long and curved bubbles in oval form on pix 5
                  Now the pmh is in freezing without charge so i will compare tomorrow
                  good night at all
                  Laurent
                  • Originally posted by Cherryman View Post
                    @ the Icemakers
                    It's hard to get a neutral starting point with water.. Don't forget that you're thoughts or surroundings can influence the ice-structure as well, at least.. according to Dr. Emoto.
                    YouTube - Water, Consciousness & Intent: Dr. Masaru Emoto
                      Interesting .
                      Cool . Is that without anything else that produce energy?
                      sucahyo,
                      It was some colloidal gold frozen in a small 2 ounce glass container.
                      Nothing else added.
                      The camera does not show it well, the spikes radiated from the center in a very tight pattern.
                      It was quite beautiful.
                      It is far different from a regular ice cube being frozen from using tap water or distilled water.
                      IndianaBoys
                      • Originally posted by rave154 View Post
                        indiana........FINE work !!!
                        can you do a control sample.....the same technique.....but using something innocent.....umm......i dunno what to suggest........a leaf maybe?
                        rave154,
                        Carried out that experiment awhile back and thought of the picture when I saw the frozen ice concept being presented.
                        I can say that tap water and distilled water did not produce the same effect at all. Do not have the pictures of that, only kept the colloidal gold frozen cube one.
                        Thanks for the comment,
                        IndianaBoys
                        • hi
                          David,
                          I've been thinking (I know, that can be dangerous )
                          Wouldn't you agree that if there was any true distortion of visible light the Schlieren Photography would have identified it?
                          This is one reason why I think it has something to do with the green dot phenomenon. I think perhaps the rig is absorbing some fundamental frequency but all of the harmonics for that frequency are present so our brains, insert the missing frequency which it concludes needs to be there.
                          While the green dot illusion is caused by POV in the eye receptors, I think we also have a similar effect in the visual cortex. It is the same process known as the 'missing fundamental' in sound. We hear frequencies that are not in the original recordings when the harmonics for those frequencies exist. And I think we see colors (frequencies) where fundamental frequencies are missing.
                          Also, the ability to see this phenomenon seems to rest on the training or sensitivity of the observer.
                          Just by chance the other day, I was watching this video:
                          YouTube - I Did What I Could With My Gas Mask - George Formby
                          and I couldn't help but notice all of the 'heat wave' effects on the wallpaper behind the cats. That is just a still shot that was recorded, but the distortion is unmistakable for any observer because the compression algorithm in the video makes those things really stand out.
                          So we must accept that whatever the visual distortion is around your rig that is affecting the visual perception of tens of people viewing it thus far, must not be detectable from the Schlieren Photography. So we need to discover what can do that - affect the eyes but not the mirror.
                          Evidently, whatever it is - when it is recorded, evidently some viewers state they are able to see it in the video as well. I would love to have this ability, but regardless of how I try - Nada I've tried the blue light in the dark, the looking in the mirror etc. I've even let my 3 element rig with an absolutely strong magnetic field in it sit for several days and I observed it in all sorts of light. I even tried to encourage my brain to see the various colors and patterns by inducing colored light with changing patterns through the device (see:YouTube - Triplet Colors) hoping that if there was any condition I was not familiar with, perhaps my brain would learn to spot it. So far nothing.
                          I am hoping to find some soft tubing today and within the next few days construct one of your rings and perhaps that will help me. Also, CatLady has agreed to let me view one of your rigs when she gets one to evaluate so I am still hopeful
                          was the formby image animated?...you know, an ED style PMH emits this same radiation, even with a steel U and keeper...just energize one and watch it. if you rotate the PMH slowly, you might start to see it, very, very subtle, like in the peripheral at first, then when you realize what it is, you start to see it easier and easier.....did you see the OU posts?...i am not sure if toner vs. oxide will work....the oxide works, with an aluminum tube....i am sending jetijs the device with the internal coil, sorry jet, but today, wed. aug 25, 2010 i will put it in the mail, i had to work late.....i wonder what would happen if someone wrapped a rodin around an oxide core device or now about using ferro-fluid inside a hollow aluminum toroid and THEN putting a rodin coil on it!.....i know you can get a magnetic lock/flow with off the shelf FF......a small C shaped steel with 3/16"gap, 20 wraps insulated wire, submerge gap in FF and energize...the FF will bridge the gap or magnetic lock, that is the lock/flow i refer to....smokey2s posts at UO might shed some light or radiation'....the fact that Tesla saw this type of effect is significant also.......david
                          • jetijs!
                            under $5.......is what it cost to mail the device!....so now we wait...i hate waiting!....the oxide core device i sent you is alittle different from the rest...i hope you like it...let me know when you get it, show it to as many friends as you can, you will get results....still nothing from TPUbruce.....stay in touch....david
                            • Hello David and all...
                              I saw Bruce online at OU.com again today for a couple of hours. Its just frustrating that he finally made contact then asked for Matts address and then no response once again. I hope this never happens to you again David when you send out a rig to a forum member.
                              Cat
                              • hi.....
                                where did solrey go?...i know he has been following both threads, just to get a chuckle i suppose, anyway i just wanted to say hey..........david
