gravity waves found
  • According to Joseph H. Cater's book the Ultimate reality gravity is a simple EM wave in the lower infrared frequency with a wavelength of 1-6mm. I guess if the theory of resonating piece cavities is valid, then I should make smaller the red marked gaps in this picture:
    They are now about 10mm, I don't know what the gaps are on Davids device, but if my device wont show any results I will compress the pieces more to get at least 6mm or smaller gaps, then we will see
    Also I have ordered a 8mm thick steel plate to be laser cut in this shape:
    With this piece we will be able to test how important the locking is. This piece will have no physical contact areas at all, so almost no resistance to magnetic flux. It will be about 200mm in diameter Will see how this works.
    • Jetijs, if you wonder if your eyes are playing tricks on you, just do the visual inspection at 1rpm also without magnetic lock. It seems safe to say that if the colors appear strangely then as well, it was visualy trickery.
      Harvey, on your response to my earth and equator mentions (for which thanks).
      I have heard of earth's bulge (shape) at the equator, however this does in not account for G measuring so closely the same at the poles and the equator, does it? Mach 1.5 at the equator, shouldn't that offer a significant local g reduction? Apply some honey on a miniature globe's equatr and give it a good spin to check ;-)
      Said differently, if a rocket in "empty" space does a 12,000km diameter orbit around nothing in 24 hours, is there a measurable CF in side it? Would the spilled contents of a glass of water inside the rocket find the outer side, or would it just randomly splash around? How fast would a heat shield tile that comes loose move away from the rocket?
      Speculating loosely: A gravitatular attraction difference of that magnitude should exist between the poles and equator, but in my limited knowledge is missing. The earth's presence as an aetherical "dip" seems to negate specific wave length G waves, equalizing it's spin. Or, the spin of the locked magnet (earth) increases G at each distance to the magnetic axis by the same amount it would have been decreased without the magnetic lock, for a non-effect which makes the earth's spin seem absent from a CF point of view. Do miniature earth model (like the desk top variety) exhibit the same effect? Hard to tell with so little attraction. Its mass seems too insignificant to tell any G from it to begin with? Big can or worms. Dozen of books te read, I'm sure.
      • Jetijs, I love your thinking, work, and that new plate design! SO simple, and should be greatly effective if the setup requirements are as David states.
        Somehow having a slab of aluminum underneath seems something to make sure to take into account, which I bet you've already done.
        If you get going with such fancy machine shop work, oh the variety of ideas to be tried....
        Since your 24-halfpipes setup is not "working" yet, perhaps you're interested to try and angle all pieces clockwise by some degrees? Just in case David's effects come from coincidental assymetry...
        • I put this together. Should be pretty close to Dave's. Having some troubles getting it to lock. The entire ring conducts well. Will do some testing tomorrow.
          • here they are...
            ......check out the white ring in the middle?? you can see it better looking down at an angle ......???...??? ..david
            • Hello ALL,
              I had a very fruitful discussion with David this evening. He is a very bright man, who is slightly overwhelmed by his finding of this effect.
              He also has other experiments that are "unique" effects he has found. one such experiment where he uses a PMH to "magnatize" pieces of aluminum foil. He will tell you how to do that, and it sounds very cool.
              He also is developing a more thorough plan to replicate this effect with a second device he is going to build, while documenting every step of the way including individual pieces, part numbers, etc. This, when working, will be sent to me, where I will experiment with it for a short time (three weeks max) and then send it off to another.
              I do think the diameter of the unit as a whole is important. Don't ask me why.
              Also, please notice there is "nothing" under his bent pipes. No alum, or plastic or anything else. But it is screwed into his HDPE rotor.
              Cool stuff! Where will it lead? Time will tell. Oh, if some members go to see his, he will record their visit and reaction to the unit for us, in HD.
              Bruce
              • Click image for larger version
                This is field from a stepper motor. Been playing around with it and I do notice a coldness coming of it and large objects like bricks feel heavier when passed over it. I tried it upside down over a brick on a bathroom scale but didn't notice any change, but I guess the field would affect the scale as well.
                I figure this is the way it works.
                Oxygen is paramagnetic. So therefore magnetic currents, vortexes, turbulence can be induced in air... thereby lowering the atmospheric pressure within the magnetic field. I imagine the turbulence could very well be visible with a design like David Lambrights.
                • check these out!
                  • strange photos...
                    here are some pix ...view these UV pix at an angle??
                    • vickers....too cool [pun]..what is a stepper?....i am not familiar with this but very curious.......david
                      • All. I tore apart a craftsman model 315 sander just like dave used for his rig. I took pictures of the rotor and the aluminum plate, along with measurements using micrometers. I'll put the pics up if anybody is interested. Im not real sure how to post pics,,but i'll try to figure it out. let me know!
                        • cornfused...i am sorry ...i did not read the whole # it should read model#315.277140... i am broke at the moment,but i can try and find you another sander ..i am sorry.....david
                          • Originally posted by Joit View Post
                            Another Idea, since it should be g-waves.
                            Maybe it depends at the Place, and David lifes on a special Place.
                            May something for a Sunday afternoon, to drive few miles, and see, if you can cross a Erathline.
                            Perhaps you are right - I would suggest a trial at:
                            Keizer Little League Park, Keizer, OR 97303
                            It is only a short distance away and has specific geographic significance.
                            • i like that park! we will have to set a date and time no disappointments thanks for your help and i know you will have ideas for me as well...thank you........david
                              • hi all,
                                getting pretty exciting what with someone about to visit David and also the rep's going on
                                David, i just re-watched your video where at the start you show your circular steel hoops being energised & locked...and a thought occured to me.
                                assuming that the iron hoop does NOT show the anomalous effects, where-as the leedskalnin-shaped rig DOES..the difference between them as you said..is the shape.... heres my thought...
                                picture yourself, driving along in a car, youve got 2 bags of shopping on the back seat loaded with apples & oranges... your driving around a nice, constant, smoothly bending road at a constant speed in a circle...what happens to the apples & oranges?........nothing much...
                                now... picture yourself driving the same car....still in a circle..but this time not in a nice constant smoothly bending circle....but having to duck & dodge left and right continually as you go around the circle..... what happens to the apples & oranges now?....they get flung out the windows both on the left and the right.....if you had a never ending supply of apples & oranges..and the car continued to go around the zig-zag circle like i described above....and you viewed it from a distance.....you would see....what?........a continual ejection both outwards & inwards....of apples & oranges.
                                the car of course in this analogy...is the continually circulating flux in the leedskalnin rig...the apples & oranges......would be the...."whatever it is"....thats being ejected from the rig as the flux has navigate & change directions to go around all the broken hoops that make up the circle.
                                Hope this makes sense & helps.
