Originally posted by Jetijs
hi jet...great work on your laser cut pieces....1 question..have you tried the single junction ring PMH yet?..steel rod 15mm bent into a 35cm diameter circle with a gap of 3mm at the junction, 40 to 50 turns of .025 insulated transformer wire wound 40mm from the junction...a spark from a 9 volt battery will lock the ring and close the gap..... are you planning to have a gap in your new design, if so, you should get it to lock with one coil, close to the gap....just a thought...any way sorry for my absence...have been working...and i see every body has been busy also!....thanks every one for getting this rolling!...i am home today, so i will try to go back and answer some questions.... sorry for not answering some of your questions before...i felt that they would be better answered by other replicators...that way, when we get the same results the answer will clearer.....david
But Adie - I can't get my head around a centrifugal force unless it's also somehow made of 'something' - some material. But that speaks to my own limitations. Not yours.
