gravity waves found
David, I have an idea that you may have not considered as far as a tool to make the invisible visible. Have you hear of dicyanine (the older text is spelled without the e on the end)? It is a chemical discovered in the early part of the last century, used to shift light from above and below the visible range in to the visible. I believe it makes both infrared and ultravioulet visible. Perhaps even up to x-rays. There are a few other chemicals similar, that are far cheaper, and easier to come by, one of which is actually in TOMATOES! These chemicals are liquid crystals, and used both as passive and active (with voltage fields applied across them) lenses, and displays. They were origially used to help see and train the eyes to see the human aura. You can buy these lenses in sunglasses form from many online retailers.
ever seen the movie 'They Live'?
I think this is the same thing, or similar
There is one more factor, you. I believe it is a "special talent" that can be shared.Originally posted by david lambright View Postthat is a possibility but it took my dad 2 months before he saw it ..i hope the eye can be trained?
There is an evidence of a device can only be replicated after the replicator meet the successfull one.
So, I think people can see it sooner if they meet you personally. I am not sure if "sharing" via internet if possible. But "sharing" via personal talk should be certain.
I think you already mention that people around you see it sooner than people on the net.
I believe its a form of magnetism in which the whole body is endowed with. An electron is an integration of electromagnetic waves. But, an electromagnetic wave can be of positive or negative polarity. If we were to send electromagnetic pulses between magnets, the waves thus produced would create an ether different from that on Earth. A variation in the distance between the plates would bring about a modification in the ether produced. By changing its polarity so as to oppose that of the Earth, we will be repelled from the planet at a speed corresponding to the difference in polarity between the craft and the Earth.Originally posted by sucahyo View PostAnyone still believe it is magnetism or electricity now?
GBLast edited by gravityblock; 02-23-2011, 03:24 AM.
It interacts with matter itself. It's more commonly known as gravity, but gravity does not exist in reality. Gravity is only effects of the secondary magnetic fields. Heat is a factor which affects this phenomena, not because it is itself an agent causing the phenomena of gravity, but because it influences magnetism and density. Gravity is no more than a wrong interpretation of a combination of phenomena. In my next post, I'll give an explanation to how bodies in space has an orbital revolution without a force of gravity.Originally posted by sucahyo View PostAre you saying it interact with magnet or can be detected with magnet detector?
GBLast edited by gravityblock; 02-23-2011, 05:13 AM.
Herschel and Newton mathematically proved the existence of our magnetic field, within which the Sun and the planets move, when they discovered that the point of equilibrium of the solar system lay at a distance from the Sun equal to three times its diameter, due to the proportion of 1 to 700 in the relative mass of the planets to that of the Sun. It is round this point of equilibrium that the Sun moves. While being attracted by this point, the earth is being repelled by the light from the Sun. It's orbit round the Sun represents the balance between these two actions of attraction and repulsion.
Now, a body in space can only be in a state of equilibrium if two contrary forces meet to support it. If there were only a force of attraction without a corresponding one of repulsion, the planet would move towards the point of attraction. If the repulsion were caused solely by centrifugal force, the planet would slowly spiral in, towards the source of attraction. Without the repulsive force of the Sun, there would, however, be no circular movement. There would be neither axial rotation nor orbital revolution. A body impelled in one direction only does not move in another direction. How could Earth move in orbit in a different direction to this repulsive force? Surely a thrust from one direction cannot give rise to another at right angles to itself?
If the magnetic centre lies between a planet and the Sun, the force of attraction is predominant and the planet is drawn in. However, if the Sun is between the planet and the centre, the force of repulsion predominates and the planet moves out, its path disturbed (this is why planets move in elliptical orbits). As the position of the Sun changes in relation to the "point zero" centre, each successive aphelion and perihelion of a planet occurs in a different position.
Scientists forgot, when dealing with the movement of planets, that energy must have been used up as a result of solar attraction working against the two centrifugal forces mentioned. If no explanation was given as to the source of power necessary to sustain the movement, then it is because the problem was based on false premises. In the theory which I contend is the correct one, this force is derived from difference of energy potential which sunlight sets up by illuminating one face of the planet while leaving the other in darkness. A body which is balanced between two opposing forces (attraction and repulsion) has no weight and moves like a stone whirled round on the end of a string, the radius of its orbit being represented by the string.
There is an internal pressure which causes the nebulae to move away from one another. You may raise the objection that this pressure is also applied in the direction of flight so that the internal pressure coupled with the external one would make them stable and they would not move apart, which would cause their mass to condense. My answer to this would be that energy created outside a galaxy tends to be drawn into the galaxy, condensing itself into material form. Thus we have an internal pressure coupled with an external decompression.
The flight of the nebulae prevents condensation taking place for three reasons: 1) This movement causes the interior pressure to disappear. However, nebulae appear to maintain an acceleration caused by an internal pressure within the Universe. (2) As the nebulae move apart, that space which had been transformed into matter endeavours to return to its former state of primordial space in accordance with the law of rotation of masses in a magnetic field. This reconstitutes the energy that had been used for condensation of the matter, turning it into light, whose wave energy goes on decreasing until the moment of entropy is reached. This is what takes place on the Sun. Leaving aside the reaction that they bring about on the planets, the Sun's discharges into space are, in a sense, matter returning to its original state of primordial space. (3) Light repels magnetic fields. Light from a myriad of suns in the various galaxies produces a very great force of repulsion on all the nebulae, and under this pressure they move away from one another.
In the first instance God supplied the power that brings about the deformation of space and the Sun, by an opposite process, turns it back into energy, thus re-establishing the balance. That is why neither matter nor energy exist, but only deformed space, which is called matter, and what you call energy is nothing more than a phenomenon of transition between primordial space and deformed space.
GBLast edited by gravityblock; 02-23-2011, 04:43 AM.
The precession of Mercury's perhelions, which gave rise to Einstein's relativity theory, is due to the planet's proximity to the Sun. As it moves closer to the Sun, it receives more light, rotates more rapidly and moves through space with greater speed. In the case of Mercury, science maintains erroneously that it revolves once on its axis for every revolution in orbit. What happens is that Mercury has a very rapid axial rotation. This does not take place on the equatorial plane of the solar system, but at right angles to it. Mercury is really a satellite of the Sun and not, strictly speaking, a planet, because only satellites have this peculiarity.
GB
I see. The unmeasureable part of magnetic field.Originally posted by gravityblock View PostIt interacts with matter itself.
Thanks for the theory. I don't have any solid one for the solar system.
I believe in effect of energy other than light from the sun. The one that make device produce power related to sun position.
Do you have any links that explore light repelling magnetic fields? This is very interesting. Great theory by the way. It's going to take me a few days to fully understand it thoughOriginally posted by gravityblock View PostHerschel and Newton mathematically proved the existence of our magnetic field, within which the Sun and the planets move, when they discovered that the point of equilibrium of the solar system lay at a distance from the Sun equal to three times its diameter, due to the proportion of 1 to 700 in the relative mass of the planets to that of the Sun. It is round this point of equilibrium that the Sun moves. While being attracted by this point, the earth is being repelled by the light from the Sun. It's orbit round the Sun represents the balance between these two actions of attraction and repulsion.
GB
The curvature of light is not due to the action of the mass of the Sun, but is caused by the magnetic centre of the system situated near the Sun. Even within a solenoid you can see that a stream of electrons is deflected by a magnetic field. If light were to be deflected when passing close to a mass, this phenomenon could be clearly observed in the vicinity of planets, let us say Mars, when it is close to Earth. Eclipses of the Moon, for example, would provide the best opportunity for such observation. Nevertheless, this curvature was only seen precisely where the magnetic centre of our system is to be found. Therefore, light is deflected by the magnetic centre and curves round the Sun. If we had proper apparatus, we would see that light also curves on the side opposite the centre, as though it were trying to get away from the Sun. The curvature of space is anti-scientific. Primordial space is not relative to any thing and has no form at all. It is neither a curve nor a straight line, and it has no dimensions, it is simply space, infinite in all directions. Wheresoever an observer may place himself, he will always have before him the infinite Universe.Originally posted by occy30 View PostDo you have any links that explore light repelling magnetic fields? This is very interesting. Great theory by the way. It's going to take me a few days to fully understand it though
The greater deflection of light near the poles causes a drop in temperature, whereas at the Equator a strong concentration of light gives more heat. The elliptical orbits of the planets are yet another consequence of the interaction of the two forces. By taking note of a planets distance from the Sun and their volume, we can discover their true density, and this will also give us the magnetic force of its poles. Thus the planet Jupiter is of low density and, having a large diameter, it is more subject to the force of repulsion than that of attraction. If it were true that matter attracted matter in direct proportion to the mass of the bodies, Jupiter, with a volume 1,330 times greater than Earth and 331 times as much mass, should be much closer to the Sun than Earth is.
Rotation is the result of the distance of the planet from the Sun, the overall diameter it presents to the Sun, its mass and the satellites which throw their light on its surface, minus its own self generated light. A comet approaching the Sun becomes flattened. Light is deflected when it comes into contact with a magnetic field (it is not deflected by mass). An electron, passing through a magnetic field, is also deflected. The planet Jupiter, when closest to the Sun, is able to exert a pressure upon it which moves it from its position. Light has weight and gives rise to friction (the weight of light is 410 atmospheric pressure per square mile). Solar light causes barometric pressure. In aphelion the planets move at slower speeds. The pressure of sunlight upon Mercury pushes it 23 million km. away from the Sun. I'll try to find some links when I have more time.
GBLast edited by gravityblock; 02-24-2011, 02:51 AM.
Light is a bipolar force with both an attractive and repulsive component that can be controlled (not to be confused with light's radiation pressure). This not only applies to visible light, but it applies to all electromagnetic waves.Originally posted by gravityblock View PostAn electron is an integration of electromagnetic waves. But, an electromagnetic wave can be of positive or negative polarity. If we were to send electromagnetic pulses between magnets, the waves thus produced would create an ether different from that on Earth. A variation in the distance between the plates would bring about a modification in the ether produced. By changing its polarity so as to oppose that of the Earth, we will be repelled from the planet at a speed corresponding to the difference in polarity between the craft and the Earth.
GB
GBLast edited by gravityblock; 02-24-2011, 03:45 AM.
