who knows...but the two slots seem to match the story....any bodys guess really unless someone has access to a model t to confirm otherwise
gravity waves found
Model T
This is not the first time I have heard this story.About 10-12 years ago, I worked with a man who claimed to have replicated a magnetic motor with a Model T flywheel. He collected old cars and parts. I never saw the replication, and when I went to work for another company, I lost contact with him.The company we worked for has since closed,so I have no way of getting in contact with him.I will look through my files and see if I kept something on it, when I can.If I can find any more details on this,or can find him, I will post it here. Good Luck. Stealth
i will do whatever it takes...
just got in ..my rig;..a craftsman sander model#315 with the stator removed...the rotor is intact..the aluminum counterweight is used,the offset bearing is removed ..so basically i use this for bearings...the disc is cutting board?..11.5 cm dia. by 1.75 cm thick..the pipe is galvanized sch.40 actual dia. is 4.25 cm and 3 mm wall thickness...i will try all your methods testing etc. i will go over what ive done and will disassemble in a video...you guys are so close...gonna go make a video ..i will be here all night...but this wave form is what you all have been searching for, be patient, you will not fail......david
David I'll try to be very polite about this...
DO NOT DISASSEMBLE IT!!!
Whatever you do do not disassemble a working setup EVER. Only misery ensues out of it trust us. You are better off building a secondary setup. Before you send this out to people make sure you have trusted people confirming these effects either on video or on this forum.
also something that you may not be aware of on the model t is that the flywheel with the coilpack rotates while the magnets are fixed and are stationary on its mounting plate.This also fits the story about the cow magnets being inserted via the bell housing...
disassemble.....
do not fret...i only took the rotor off of the sander......it still works ...the demo is after the dis assembly i wont hurt it , though i have ....just to be sure.......davidOriginally posted by broli View PostDavid I'll try to be very polite about this...
I couldn't agree more!Originally posted by broli View PostDavid I'll try to be very polite about this...
I couldn't help but think of this after reading that:
Jonny 5IVE Says "NO DISASSEMBLE"
It's nice to see everyone looking out for each other here.
try holding a neo magnet near the plane...afoot or so away till you feel like "vibrations"...then try the steel etc,,,,,,,,,,davidOriginally posted by cody View PostDavid i dont understand what i am doing wrong. My ring is locking together fairly strong now but i still dont see anything. What do you suggest?
David,
thanks for making that last video, 2gig !.i know the hassle of making and formatting and then of course uploading big video files is and i hate it, so thanks for going to that length.
when you had the camera in the over head view with the quartz, i "think" i could see what you were talking about, however, it might have been the spinning pipes sections playing tricks on my eyes....
in order to counter this, could you cut out a piece of paper or thin card, outside diameter the same as your rig, inner diameter the same as your rig.and stick it on top of the pipes, so that when you look down, all you will see is white ( white of the cutting board & white of the paper on top of the pipes )...this way there will be less "normal stuff" to interfer with the camera optics.
do you own a chess/checkers board by any chance?
once you have covered the rig as suggested above, you could start it spinning, hold the rock in one hand as normal...then with the camera in a top down view, slowly bring the chess board in so that it half covers the rig, that should give a nice contrast for any effects to show up on the camera.
if no chess board, then quickly draw some dark,straight, thick'ish lines on a piece of nice white paper...for the same contrast effect.
Thanks for your efforts
David. D
There is something strange about the way the rock is moving from 4.50 in this video;
YouTube - potatoheadist's Channel
As David is saying, it feels as if it has given up its mass, the rock looks as if it has very little mass. Too twitchy for something that heavy surely?
Cheers,
s.
I think I see what you're saying. To turn the rock THAT quickly as it just rolls out of his hands, would require MORE inout at regular conditions, that gravity would normally be able to exert.Originally posted by sturgeon View PostThere is something strange about the way the rock is moving from 4.50 in this video;
Cheers,
s.
Me, I don't doubt David, even if the cam doesn't like to pick up what he is seeing. We should be BAFFLED, even if all of this is totally real, that the waves at times actually pass through our visible spectrums. If the visual spectrum were an octave on a paione, just the keys between two closest C's, then the total optical spectrum would form a keyboard wrapping from the earth, around the sun and back. at least, according to Richard Hammond in an awesomelt filmed recent BBC series "Invisible Worlds".
I'll rate it as sheer luck, that David's device is able to any degree, to show visible to the human eye distortions, let alone make them show up on Youtube.
What I wonder now. David hasn't had to re-energize his device for several days he says. Would there be a way to energize it to a greater degree, or is there only so much a locking magnet can take? Like a maximum capicity? If the device could handle higher current, it migh give off greater visual effect?
Anyway, the aluminum bottom piece and the remaining galvanization on the pipes where they don't touch, seem like possible clues to me. The aluminum might function as a mirror for the waves? Sorry if that comes across stupid.
Brain fart. What about trying a christmas tree ball in the field? What materials do those come in? If the air inside could be heated, who knows... Just dangle it from a thin somewhat fire proof piece of fabric cord, or a bit of thin metallic wire made into a spring barely strong enough to suspend the ball.
I hope soon someone will be able to up David's invitation.Last edited by Cloxxki; 05-16-2010, 10:26 AM.
CloxxkiOriginally posted by Cloxxki View Post
No, I can tell you with certainty that once the PMH is 'locked' and field is in motion, you CANNOT up the ante and try rev the field. You don't have to take my word for it but do some research on the simpler Leedskalnin PMH or build your own. You just have to understand the physics of it and after sitting down for some while, much of the mysticism flies away. Look at it like a electromagnet. I assume you know about permeability, inductance and saturation. If this is the case you will then realise that the PMH (in any shape or form) has it's limits and once 'energised' (or saturated) cannot be powered any higher. These are simple facts.
TP
