How to: Magnetic Vortex w/ toroid core
  • How to: Magnetic Vortex w/ toroid core
    Toroidal cores are always wounds with the windings 90 degrees to the circle of the core. They only create a magnetic rotation clockwise or couterclockwise in the core. This this can basically be modeled with as a system with 2 dimensions : field density, and direction of field (in a nice bifilar coil)
    But we can do better than that, and nature does better. Let's make it a 3 dimensional system. Let's put a rotational bias in 1 direction on the ring's magnetic field, with the standard windings. Bifialar to keep distributed capacitance equal. Now have a solenoid coil in the center of the toroid! Make this one oscillate. We now have a vortex, just like when you start one in a glass jar with some water, and look at particulates floating around....round and round in 1 direction....up and down in the middle. but wait! gravity bias needs to be accounted for! maybe a magnet at one end!
    Toroidal cores have been used extensively by jewel thief makers. I suggest this design be used as a jewel thief. If all resistors in the circuit were replaced with inductor coils, around the core, and the oscillating part of the circuit were to be placed inside the torroid, maybe with its own rod core in the center,.....we might have something interesting.....
    Seems like the dc winding around the core could be used for magnetic amplification purposes...
    and if you don't do exactly 90 degree offset from the dc control coil and the ac coils in the center, you can have some kind of partial coupling between the them, with a regenerative effect going back into the outside rotation.
    I am assuming that you are talking about a ferrous toroidal core? Would it not make sense that you will not get a magnetic vortex by using a core of ferrous material since these materials absorb practically all of the magnetic flux? If not using ferrous material, check out the Rodin coil if you haven't already because it seems to describe what you thinking, maybe?? The Rodin Coil and some description of what its about
      well, too bad it's been invented already! i found the patent!
      Oscillating flux transformer Oscillating Flux Transformer
      So saturating a core with a DC current 90 degrees spatially to a coil with a square wave AC signal turns the square waves into sinewaves!!!!!!!!!!!!!
      Transformer circuit with direct current flux cancellation - Patent 3384810 Transformer with direct current flux cancellation
      a pure sine wave inverter is possible with this and a simple push-pull transistor oscillator...that means way way way better resonance can be achieved with cheap solid state design
        Every resonant coil outputs a sinewave, no need for the DC cancellation effort. If you are not aware of that, i kindly recommend you to educate yourself on the matter for instance here : YouTube - Coil Resonance Tutorial 1
        The signifcant size decrease of the core is a plus of the design you mention.
