How to calculate "joint pressure tank"
  • How to calculate "joint pressure tank"
    Dear All,
    I'm looking formula to calculate "joint pressure tank" as picture shown in the attachment.
    I try searching on the internet have not met the formula.
    I Assumed as below:
    Volume Tank A (VTA)
    = 4 x 2 x 2 x 22 : 7
    = 50.28 inch3
    Volume Tank B (VTB)
    = 4 x 1 x 1 x 22 : 7
    = 12.57
    Volume pressure tank A (VPA)
    = 50.28 x 100 PSI
    = 5,028
    Volume pressure tank B (VPB)
    = 12.57 x 50 PSI
    = 628.6
    To calculate joint pressure (not include pipe)
    = (VPA+VPB) / (VTA+VTB)
    = (5,028 + 628.6 ) / (50.28 + 12.57)
    = 5,656.6 / 62.85
    = 90 PSI
    Please correct me if above calculation are wrong.
    Best regards,
    Selamatg
    Hi all,
    Regarding the drawing, there is cylinder tank with 4" diameter x 4" Length (100 PSI) and 2" diameter x 4" lenghth (50 PSI), how many PSI if both tank joined.
    Thanks in advance
    Selamatg
      Originally posted by selamatg View Post
      Hi all,
      Thanks in advance
      Selamatg
      I'll throw in my idea first, based solely on intuition (no formal education on the subject, at least that I remember)
      Since the cross-section of the cilinders is identical, we can scratch X and Y from the formula's, which-ever those may be. Makes it rather simple, I would guess.
      100 psi x 4 = 400 units of stuff
      50 psi x 2 = 100 units of stuff
      6 volume units, total
      500 units of stuff, total
      500/6= 83.33 psi when joined.
      If I got this wrong, I'll learn from the correct answer.
      In school, I usually got away with my method of making it up as I went along. Even if the classes and text books taught the correct formulas, I'd have a perfectly wiped memory of that going into a test anyway. I would have worded it mote convincingly if it were a test, though. I'm rusty.
      J
        Vote to the first result. 90PS.
        VTA*PA + VTB*PB = VTJ*PJ
        PJ = (VTA*PA + VTB*PB) / VTJ
        PJ = (VTA*PA + VTB*PB) / (VTA + VTB)
          You sent me searching for an easier way but it always boils down to using the Ideal Gas Law in one form or another.
          pV = nRT
          Absolute Pressure x Volume = number of moles x Gas Constant x Absolute Temperature
          You could write this as n = pV / RT
          n[tankA] = p[tankA] x V[tankA] / RT
          n[tankB] = p[tankB] x V[tankB] / RT
          n[joined] = n[tankA] + n[tankB]
          V[joined] = V[tankA] + V[tankB]
          p[joined] x V[joined] = n[joined]RT
          p[joined] = n[joined]RT / V[joined]
          Note the formula units are SI units. So you would need to convert your PSI to Pascals and Volume into Cubic Meters.
          You may also find this site helpful: Fluid Concepts
