Is aura necessary for learning radiant technology?
  • #16
    Originally posted by Stealth View Post
    Edgar Cayce reading March8,1928. Good Luck. Stealth
    Thanks .
    Originally posted by baroutologos View Post
    TRANSMUTATION
    Jesus.... what more can we see
    Just learn how to trasmute anything to gold and your whole life problems will vanish in an instant!
    This remind me of what Moray do with radiant power:
    He produced coppers and leads having astounding refractory qualities. Impossible to melt below two thousand degrees Fahrenheit, the lead was the wonder of every metallurgist who received his samples. His coppers were so strong and heat resistant that he employed them as bearings in his high-speed motors. An undisclosed alloy, made by the Moray process, could withstand twelve thousand degrees Fahrenheit without melting. W developed extraordinary metals and alloys.
    This is just like what HHO torcher can do. I regret I don't have 1 liter per minutes hydroxy generator, otherwise I would start transmuting metal right away. It is weird that no HHO experimenter ever interested in transmuting metal.
    • #17
      Learning aura necessary yes!
      I apreciate the question but would have asked it another way.
      Aura to me is like a life or driving force, it seems nearly everyone has a certain amount that they are made of with but few have an inspiration of life. Some kind of special desire to accomplish something greater than normal. That is big aura. some of these people make billions of dollars and some like ED NT and others make knowlege their life's work and desire. I allways had plenty of it but one day i realized I needed more input and started studying. I was 35 years old when I realized that. I am now 51. I hope I achieve a goal befor I die. I know I will never stop searching, This is too intreging.
      I will give you a design for much more than 1 LPM if you like.
      3X5 304 SS - n n + n n - n n + n n - tight fitting in flat plexiglass
      nearly 3 LPM
      ouch! hot.
      If you don't need that much I would cut that in half or go to 3 or 4 N's between plates using KOH 28% max!
      15 to 20 min run time
      you got it.
      h2ocommuter
      • #18
        Sorry, but I can not understand. What is your definition of aura?
        • #19
          Peter Lindemann ethericity
          Ethericity is what Peter Lindemann refer to orgone electricity or electric aura. Peter Lindemann refer to Wilhelm Reich, Rudolf Steiner and Trevor James Constable.
          The entire study of what has been called "static electricity" is just a confusing encounter with the Light Ether as it behaves under certain circumtancsec. When fully understood, so called "static electricity" will be seen to neither static no electricity. Normal electricity always flows from high potential to low potential and usually requires metallic conductors to flow along. On the other hand "static electricity" does not discharge the same way, and readily moves and collects on both conductors and insulators.
          Here is characteristic of ethericity:
          1) Ethericity can be accumulated from the ground or the air at almost any location
          2) It can be "reflected" down wires (this is not conduction)
          3) Flows of ethericity can be interrupted by diodes and Mosfet type devices
          4) Its potential can be raised or lowered in air core transformers
          5) It can be stored in capacitors
          6) It will operate neon style lighting, when the potential is high enough
          7) It can create fields of opposing forces in coils and motor windings
          • #20
            aura
            sucahyo, i think h2o commuter was talking of another kind of aura...
            Everyone has an aura. Everyone has already seen or experienced the auric fields of others. The problem is that most people ignore the experience or chalk it up to something that it is not.
            Mystics from all parts of the world speak of seeing lights around people's heads, but you do not have to be a mystic to see the aura. Anyone can learn to see and experience the aura more effectively. There is nothing magical about the process. It involves recognizing it for what it is and not ignoring the experience. It simply involves a little understanding, time, practice and perseverance.
            that was the defenition i add of aura, and i was based on that to answer in your topic, maybe you should mention that you are talking about electric aura or ethericity.
            but in fact, i think they are the same thing, but with different understandings!
            • #21
              I'm not sure about the "aura" issue, but I do think that Tesla fit the profile from the meyers-briggs test of an INTJ: http://www.keirsey.com/handler.aspx?...5&c=mastermind
              As an INTJ myself, I find that I comprehend things that I can't convey to others very well, even when I try to get them to understand via analogies. INTJ's operate in a manner very unlike other people and usually people get the wrong impression (like we're arrogant, when we're really devoid of emotion, although I have come across some arrogant INTJs at the intjforum).
              Out of curiosity, are there any other INTJs present on this forum?
              • #22
                No, your description is exactly what I mean. See my post at #5. Ethericity is Peter Lindemann opinion, I also agree that it refer to the same thing.
                I propose that people who can see aura can see how electromagnet work, And thus can better tune the rotary attraction motor, no BEMF motor, Bedini SSG, TPU, Steorn replication, etc.
                The reason I ask is because in my country, there are things that called by western people as aura when I think it isn't. The power to move or hit thing from far away for instance.
                I think Tesla is more like a mistreated man then a mastermind.
                • #23
                  sorry
                  Originally posted by h2ocommuter;
                  i misread your opinion of aura. My defenition is the one you can see with your eyes, only a manifestation of the aura defenition of h20commuter that is more like the one you can feel with your heart.
                  so, at the end, we are all talking about the same... eheh
                  hug
                  • #24
                    hug
