I took a copper pipe about 3 feet long and 1-3/8" in diameter. I dropped a stack of neo magnets through the pipe. Instead of falling through at the same speed as they would normally they floated through the copper pipe taking about 4 seconds before falling out the other end!
The pipe is totally non-magnetic as it is copper water pipe. There in NO attraction at all when you put the magnets on the pipe. I dropped the magnets through a piece of PVC pipe and they fall at your standard Newtonian rate. I also tried this with a piece of T6061 Aluminum pipe about 2 feet long and 1-5/8" diameter and it acts the same as the copper pipe.
I did find that a smaller stack of neo magnets or a single one went through much faster and also that a larger stack would go through faster. From initial tests I find about 1.25" to 1.5" high stack seems to go through the slowest. These are about 3/4" in diameter. This is extremely easy to try and leaves you with the feeling something very unusual is happening here. I didn't discover this on my own but stumbled across it in a youtube video with a guy running some sort of Bedini motor (it was running the whole time he was showing these tests so I was suspicious the motor had something to do with it) while he was demonstrating this effect. But I found out it has nothing to do with the motor as I quickly grabbed some pipes and magnets and 100% confirmed what he had been showing. He stated he learned of this effect from Boyd Bushman who was a scientist for Lockheed Martin Skunkworks and the Boyd knows why this effect occurs but would not tell him why.
Nothing I learned in college physics or electronics brings any thing to mind as to what is causing this effect. Does anyone have any ideas? This would seem to have some secrets of antigravity. My heads buzzing so fast on this now I haven't really even had time to think of the implications or possibilities. Please try this and you will be amazed! Look down the tube as you drop the magnets in and watch them float down. In case I haven't made this clear you hold one end of a copper pipe with the other end hanging straight down and then drop the magnet stack from the top.
The pipe is totally non-magnetic as it is copper water pipe. There in NO attraction at all when you put the magnets on the pipe. I dropped the magnets through a piece of PVC pipe and they fall at your standard Newtonian rate. I also tried this with a piece of T6061 Aluminum pipe about 2 feet long and 1-5/8" diameter and it acts the same as the copper pipe. I did find that a smaller stack of neo magnets or a single one went through much faster and also that a larger stack would go through faster. From initial tests I find about 1.25" to 1.5" high stack seems to go through the slowest. These are about 3/4" in diameter. This is extremely easy to try and leaves you with the feeling something very unusual is happening here. I didn't discover this on my own but stumbled across it in a youtube video with a guy running some sort of Bedini motor (it was running the whole time he was showing these tests so I was suspicious the motor had something to do with it) while he was demonstrating this effect. But I found out it has nothing to do with the motor as I quickly grabbed some pipes and magnets and 100% confirmed what he had been showing. He stated he learned of this effect from Boyd Bushman who was a scientist for Lockheed Martin Skunkworks and the Boyd knows why this effect occurs but would not tell him why.
